01-22-2015, 09:09 PM | #251 |
I'm trying....
Re: 70 Blazer Frame Off
First coat of primer going on....neat to see it all one color for the first time in a long time.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-22-2015, 09:20 PM | #252 |
Awesome!
You know for some reason, I am really drawn to your build, even though I don't usually get into the 4x4's. I can't keep my eyes off of it though.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-22-2015, 09:27 PM | #253 | |
I'm trying....
Thanks....it's because our trucks are bros...70 St. Louis Blazers separated at birth. I'm sure if my truck needed a kidney or a bone marrow transplant, your truck would be the perfect match. Luckily those were the only two things that were good on my truck...so you're safe.
01-26-2015, 09:14 PM | #254 |
01-26-2015, 09:31 PM | #255 |
I'm trying....
Thanks. Don't know about the top yet. We're still considering several options documented previously on the board...but mainly it's Zolatone vs. a bedliner of some sort. There are a few really good top repair/repaint threads on the board that have made different techniques work...we've still got a little time to sort it. No doubt I'll post it as soon as we figure it out for sure.
01-27-2015, 01:29 AM | #256 |
The speed of this build amazing! Keep it up
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
01-27-2015, 10:20 AM | #257 |
I'm trying....
Thanks Mike. I guess it has been pretty quick...but nothing ever seems that way when you're in it. No new pics since she's in her 50 Shades of Gray period. Primer, guide coat, wet sand, repeat.
01-27-2015, 04:54 PM | #258 |
I have someone doing my body and paint work and you're way ahead of me still. If I attempted my own paint and body I would be looking at 2018 to complete it lol
01-27-2015, 05:13 PM | #259 |
I'm trying....
Don't be fooled Mike...I'm not doing my paint and body either. If you go to the first page of this build thread there's a red Nova convertible on there. The guy who painted that is doing this. It's his shop and he let's me wrench on it...play with axles and brakes and motors and hunt down parts...and do things I might have an aptitude for...but it's all him now, until we get to some more assembly. He let me wet sand on it a bit over the weekend, enough to reinforce the fact that I don't care for paint. There's no joy to me...it's only anxiety...if you're not perfect, you're always judged by the 1% screw up...you can't take any pride in the other 26 outs you got...that last bunt single haunts you. Let me tell you, I'm super glad Eric is on the gun and not me....maybe I should say under the gun
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 01-27-2015 at 10:33 PM. |
01-27-2015, 05:32 PM | #260 |
hahaha.. I bet he is.. That's cool he let's you wrench at the shop. The guys at my body shop let me come in and sand blast and check on the progress. They should be done with media blasting this week and I'm picking up my frame from the powder coat shop this Friday.
And I know what you mean by that 1%.. That's whole reason I decided to strip the front axle back down again and have it powder coated like the rear axle and all the parts under the hood so it all matches.. I knew it would have bugged me so I made the decision to do it right. It was costly and time consuming experience but I did learn from it.
01-28-2015, 08:22 PM | #261 |
I'm trying....
A lot of effort going in to getting the window to top fitment fully sorted before the top comes back off. As you know the driver's side was beyond horrible. The track that holds the top to glass weatherstripping had to be moved and some of the top finish lines modified to accommodate that move. The top drip rail on this side was massaged as well to make it match up with the windshield drip better and mirror the passenger side. Glass to top fit is much better...seeing as you can no longer fit your to-go order through without having to roll the window down...but a little more refinement to go yet.
01-29-2015, 02:50 AM | #262 |
Mine was primer for years. Window gap looking good. Keep at it. The end is in sight. I wish I had the money to Hand mine off to a good body guy. Eventually I will get a professional paint job. But for now it's rattlecans just to keep it looking decent from a distance.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
01-29-2015, 10:51 PM | #263 |
I'm trying....
Very happy moment when I got home and checked the front steps. Thanks a bunch Tim (TruckSeats). Side panels look outstanding. Looks like TruckWorld does a great job, but from my point of view, it seems like they might be difficult to deal with. Thanks Tim for making this happen. Hopefully the seat covers will be here soon too.
01-30-2015, 03:53 PM | #264 |
I'm trying....
JUST TO BE CLEAR...vendor TruckSeats (Tim) has been great. The manufacturer, TruckWorld, has been difficult. Their quality is great, but turn around and communication is not. It seems to me that Tim has a hard time going between impatient customers (me) and a difficult manufacturer (TruckWorld).
02-04-2015, 09:44 PM | #265 |
I'm trying....
After an extra couple of days fiddling with windows and weatherstripping...finally got to the point where the top could come back off and begin the process of preparing for some color. There is a strong possibility that once the top goes back on, it'll never come off again...(at least under my watch)..I know, heresy right?
02-04-2015, 09:46 PM | #266 |
I'm trying....
A neat little nugget inside the passenger's side hatch hinge.
02-04-2015, 09:48 PM | #267 |
does Truck World have a website? I'd be interested in seeing if they have rear side panels for our Blazers
02-04-2015, 10:00 PM | #268 | |
I'm trying....
TruckWorld does great work...but they are in no hurry. I tried to order my interior last summer because I knew they'd need a big lead time....but apparently the "scroll die" broke the week before I called...literally. Tim wouldn't even commit to take my order(read:my money) until late fall because he had no guarantees. Now it's February and I've got my side panels...but have no idea when to expect my seat covers...but as you can see by the preceding pics...I've got a little time yet.
02-04-2015, 10:15 PM | #269 |
I wonder where he gets them from. Fortunately, for me the only interior that needs replacing is my rear side panels and carpet. I assume these are made in the USA? (AKA China) lol kidding aside, If it takes that long then their quality must be good.
02-04-2015, 11:01 PM | #270 |
I'm trying....
TruckSeats gets them from TruckWorld...they are made in the USA. Quality is very good.
02-04-2015, 11:07 PM | #271 |
Carpe manana
x2 - quality is better IMO than OEM. Lots of real stitching involved and they use the correct walrus grain vinyl.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-04-2015, 11:40 PM | #272 |
I should probably request my order now if it takes that long
02-04-2015, 11:43 PM | #273 |
Carpe manana
Mine took six weeks...
02-05-2015, 01:29 PM | #274 |
You are doing a great job! This thing is going to be one heck of a nice rig when you get it done. Looking forward to seeing more.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
02-05-2015, 02:55 PM | #275 |
I'm trying....
Thanks...I hope so...and don't worry you will.
Tags |
1970, blazer, k5 blazer, restoration, silver |
