Old 09-09-2015, 09:18 PM   #251
yj4000
yj4000's Avatar
Re: Blake's 67 GMC stepside build
Nice work Mark.
Ryan.
yj4000 is offline   Reply With Quote
Old 09-11-2015, 09:26 AM   #252
reaper71
reaper71's Avatar
Thank's Ryan..
Pic #1. Here is the tail light mount idea I had during mockup.
Pic #2. Some holes welded up that will not be used.
Pic #3. The new bracket after it was cut, drilled etc.
Nothing fancy here but once painted should look pretty good.
Pic #4. LED light mounted.
Mark...
reaper71 is offline   Reply With Quote
Old 09-11-2015, 02:45 PM   #253
RockinKees
RockinKees's Avatar
Nice and simple Mark!
Great work!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-11-2015, 05:04 PM   #254
rusty76
rusty76's Avatar
I like it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 09-15-2015, 09:51 AM   #255
reaper71
reaper71's Avatar
Pic #1. View from rear.
Pic #2. This is the inner section that was bad. The remaining portion around the bed was all good and would not be replaced. (customer has requested the inside be shot with bedliner and color matched) and then it will have wood floor.
Pic #3. after repairs done.
Pic #4. Tailgate finally in Epoxy.
Mark...
Old 09-16-2015, 09:34 AM   #256
reaper71
reaper71's Avatar
Well the 3rd pic didn't load...
Pic #1. The tailgate in epoxy.
Pic #2. Bedsides with Epoxy.
Pic #3. 1st round of blocking.
Pic #4. Another view of bed rail, shows the amount of work that will need to be done to make it straight.
Mark...
Old 09-22-2015, 09:50 AM   #257
reaper71
reaper71's Avatar
Pic #1. Passenger side rear.
Pic #2. Just showing the multiple dents and dings that need addressing.
Pic #3. After Hammer/Dolly work and a round of filler.
Mark...
Old 09-22-2015, 08:17 PM   #258
Advanced Design
Advanced Design's Avatar
Love the spray area...and the trucks in the background!
Advanced Design is offline   Reply With Quote
Old 09-23-2015, 09:47 AM   #259
reaper71
reaper71's Avatar
HaHa! Thank's Doug..
I normally spray inside ,but had to much other things in the shop so out it went.
Old 09-24-2015, 09:41 AM   #260
reaper71
reaper71's Avatar
Pic #1. Quick shot of tailgate and all it's low spots to be addressed.
Pic #2. closer look.
Pic #3. other side.
Pic #4. First round of filler.
With the amount of work needed to fix this thing it might have been better to buy a new one, but was already invested in it to much so no going back now!
Mark...
Old 10-20-2015, 10:03 AM   #261
reaper71
reaper71's Avatar
Been awhile since I've posted on this one..
Been super busy on rebuilding the back end of a 78 FJ.
Pic #1. Few small spots around outer section need some tlc.
Pic #2. Tailgate in Highbuild again.
Pic #3. Bedsides needed some poly filler.
Pic #4. center needed some attention.
(at this point it would have been better to just buy a new tailgate but didnt relize it was this bad )
Mark...
Old 10-20-2015, 04:52 PM   #262
rusty76
rusty76's Avatar
Looks good to me
My build thread
Crossmembers CC
Old 10-21-2015, 09:41 AM   #263
reaper71
reaper71's Avatar
Thank's Rusty...This was alot more work than I had figured ,but it was already too far into to just stop and get a new one sooo, on we go.
Pic #1. The cowl all ready for some blocking.
Pic #2. Front side of tailgate needed some attention.
Pic #3. The front panel needed repair work as well. The flange was rotted off so I would remove all bad and replace it.
Pic #4. Front panel was stripped as well.
Pic #5. The 3rd pic was wrong one This is the flange
Old 10-23-2015, 09:57 AM   #264
reaper71
reaper71's Avatar
Pic #1. Patch going in.
Pic #2. Epoxy primer.
Pic #3. Cowl
Pic #4. Front panel in High Build.
Pic #5. Cowl in High build.
Old 10-23-2015, 06:12 PM   #265
Advanced Design
Wow, lotta nice work you did to save the tailgate.
Old 10-24-2015, 04:19 PM   #266
RockinKees
RockinKees's Avatar
Looks great Mark!
As always!
Cheers!! Kees.
Kool Guyz CC
Old 10-26-2015, 04:43 PM   #267
reaper71
reaper71's Avatar
Thank's Guys
Old 10-28-2015, 03:35 PM   #268
reaper71
reaper71's Avatar
Pic #1. Front panel after 1st round of blocking.
Pic #2. here you can see how much this old Farm truck was USED..
Pic #3. Tailgate after more blocking was done and another round of High Build.
Pic #4. This is the rear section that holds the bed together. This thing was in need of some love..
Pic #5. since it was so bent up and and you cant really get in to Hammer and dolly it, I made this piece to be welded over it to make it nice and flat..
Mark...
Old 10-28-2015, 08:18 PM   #269
Advanced Design
Are those little mig tacks around the perimeter? Good solution for a rough panel.
Old 11-03-2015, 10:14 AM   #270
reaper71
reaper71's Avatar
Yes they are, will be welded solid then smoothed.
Old 11-03-2015, 10:23 AM   #271
reaper71
reaper71's Avatar
Pic #1. More tacks to keep it from warping.
Pic #2. All tacks done ready for final welding.
Pic #3. This was after final weld and metal finish. Much Better!
Pic #4. The braces that support this panel in the back were all rotted and mangled so I made new ones.
Old 11-03-2015, 12:30 PM   #272
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Amazing build!
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-04-2015, 10:26 AM   #273
reaper71
reaper71's Avatar
Thank's man!!
Pic #1. The new brace set in place ready to be welded in.
Pic #2. The back panel in Epoxy.
Pic #3. Panel after it was shot in High Build primer.
Pic #4. The front panel ready for wetsanding.
Mark...
Old 11-04-2015, 09:47 PM   #274
yj4000
yj4000's Avatar
Lookin' good!
Ryan.
Old 11-09-2015, 10:23 AM   #275
reaper71
reaper71's Avatar
Thanks again Ryan!
