Old 01-21-2019, 01:22 PM   #251
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 64 Stepper Project
Originally Posted by roll_the_dice View Post
I just read your entire thread! Such a beautiful build and attention to detail. Great job.
Hi, thank you. I havnt visited this lately. I'm playing around with which size trans cooler lines I should use either 3/8 or 5/16. I know the factory size in the day was 5/16 but I'm thinking maybe the 3/8 will be better. I'm going with a 200R4 and it uses 1/4npts threads on the cooler outlet and inlet and I found this Dorman 800-754 that I can use inverted flare for there and already have the radiator connection for the 3/8 tube inverted flare there.
Or I can go with AN6 hoses all the way.
Also thinking of buying a crimper to crimp ferrules for hose ends instead of the push on units. I can also use that for the power steering lines if I want.
Need ideas on mounting the trans cooler though.
Old 03-09-2019, 07:27 AM   #252
The Rocknrod
Moderator
Installed the Retrosund radio and it works well.
Old 07-03-2019, 12:32 PM   #253
cmseaver
Master Chief, that is a beautiful truck! Outstanding work! Can't wait to see more pictures and see it finished.
cmseaver is offline   Reply With Quote
Old 07-03-2019, 12:40 PM   #254
The Rocknrod
Moderator
Thank you. When I get home with my booty (from work) I can finish this project.
Old 07-03-2019, 07:23 PM   #255
knomadd
knomadd's Avatar
Looks great! Keep it up.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 08-05-2019, 03:09 PM   #256
The Rocknrod
Moderator
Bought the Exhaust Manifolds and Valve covers (chrome) plan to get the Mooneyes air cleaner and get it chromed. Have to clean up (smooth) the exhaust man before I get it jet hot cast iron gray.
Old 08-05-2019, 03:40 PM   #257
The Rocknrod
Moderator
Chrome Booster in the house.
Old 08-11-2019, 02:00 PM   #258
The Rocknrod
Moderator
Received the chrome hood hinges but I may send them back,one is pretty loose.
Old 09-18-2019, 07:43 PM   #259
The Rocknrod
Moderator
Purchased the Mooneyes Air Cleaner and had it sent to El Paso Plating direct. Should be there tomorrow afternoon.
Found a 17" Seven blade fan to mate up to a fan clutch clutch.
Old 09-27-2019, 07:42 PM   #260
The Rocknrod
Moderator
So the Mooneyes air cleaner was returned from El Paso Plating. They did the top and the bottom.
Old 09-27-2019, 08:01 PM   #261
roll_the_dice
roll_the_dice's Avatar
Looks great in the pictures...how does it look in person?
roll_the_dice is offline   Reply With Quote
Old 09-28-2019, 08:33 AM   #262
The Rocknrod
Moderator
My wife loves it. I'm out of state working.
What really surprises me is that I bought this from California Car Cover on the 16th. They sent it to El Paso Plating who plated it and sent it home completed in that amount of time.
Old 09-28-2019, 09:06 AM   #263
roll_the_dice
It does look really good!
That is super fast. I haven't had anything done yet, but I plan on using them also.
Old 09-28-2019, 09:21 AM   #264
Indian113
Indian113's Avatar
Can't wait to see that air cleaner installed! Bet your getting anxious yourself.
Indian113 is offline   Reply With Quote
Old 09-28-2019, 09:27 AM   #265
The Rocknrod
Moderator
I did due to a recommendation I read on this site. So far so good.
That's a fact. I'll be home Christmas to fawn over my booty.
Should be at my $$ goal for the truck completion by then, but then I have to work probably another year out here to be set for a while.
Old 09-28-2019, 09:34 AM   #266
The Rocknrod
Moderator
Another pic of the top. I like the cast aluminum, not billet. However I don't like to polish the stuff, so...
Old 10-27-2019, 11:24 AM   #267
The Rocknrod
Moderator
So I'm looking at the Hedman 69830's with 3/8" flanges. I see they have fit well on newer trucks, any comments on if they will be a problem on ours? - http://67-72chevytrucks.com/vboard/s...d.php?t=353842
Old 11-16-2019, 03:15 PM   #268
The Rocknrod
Moderator
So I bought a pair of these and sent them home (still on the road). They are 5" or 5.25" long perfect for a key fob that wont scratch the dash.
Old 12-30-2019, 10:09 AM   #269
The Rocknrod
Moderator
While I was at home for Christmas I changed out my hood hinges and brake booster. Had to set the booster to master cylinder dimensions, but it all worked out.
Old 12-30-2019, 10:48 AM   #270
66farmer
66farmer's Avatar
That is super clean
66farmer is offline   Reply With Quote
Old 12-30-2019, 12:17 PM   #271
The Rocknrod
Moderator
Coming from you that means a lot. Yours is a killer truck!
Old 01-13-2020, 05:07 PM   #272
88Stanger
88Stanger's Avatar
Nice work sir! I look forward to your updates
88Stanger is offline   Reply With Quote
Old 01-13-2020, 07:16 PM   #273
The Rocknrod
Moderator
Thank you. Me too.
Old 01-28-2020, 05:08 PM   #274
The Rocknrod
Moderator
Got a goody in the mail (new never used).
Old 02-01-2020, 05:51 PM   #275
cookseyb
Great job from one Power Plant road whore to another!
cookseyb is offline   Reply With Quote
