Old 09-23-2016, 10:39 PM   #251
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Plus Five
Check out 3m paint defender..http://www.ebay.com/itm/NEW-3M-Paint...591860&vxp=mtr
Old 09-24-2016, 10:16 AM   #252
donandal
Re: Plus Five
That sounds interesting...
it says removable, does it peel off later if you
want to reapply it?
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 10-01-2016, 02:33 PM   #253
donandal
Re: Plus Five
started putting the box back on the truck
53 Chevy Pickup
Old 10-01-2016, 02:37 PM   #254
donandal
Re: Plus Five
I made these brackets for the rear tail lights earlier.
also installed the tailgate...
53 Chevy Pickup
Old 10-01-2016, 02:43 PM   #255
donandal
Re: Plus Five
some more,
53 Chevy Pickup
Old 10-01-2016, 11:11 PM   #256
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Plus Five
Cool job on the light hardware!
Zoomin is offline   Reply With Quote
Old 10-03-2016, 08:41 PM   #257
donandal
Re: Plus Five
put the rear bumper brackets and covers on, and installed the license plate holder and side skirts.
also installed the license plate lights.
53 Chevy Pickup
Old 10-03-2016, 08:43 PM   #258
donandal
Re: Plus Five
some more....
53 Chevy Pickup
Old 10-03-2016, 09:37 PM   #259
lynx5653
lynx5653's Avatar
Re: Plus Five
truck is looking great
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 10-04-2016, 09:57 AM   #260
MIKESAD50
Re: Plus Five
WOW! alot of really nice mods and very nice work. Going to beautiful when done.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 10-04-2016, 07:26 PM   #261
donandal
Re: Plus Five
Thanks everyone,
I'll be putting the rest of the box and fenders on soon,
then I should be able to start running wiring again.
53 Chevy Pickup
Old 10-05-2016, 07:10 PM   #262
donandal
Re: Plus Five
installed the rear bumpers and backup lights
53 Chevy Pickup
Old 10-05-2016, 07:13 PM   #263
donandal
Re: Plus Five
backup lights
53 Chevy Pickup
Old 10-08-2016, 07:37 PM   #264
donandal
Re: Plus Five
put the rear fenders and running boards on today!
53 Chevy Pickup
Old 10-21-2016, 02:10 PM   #265
donandal
Re: Plus Five
I started installing the dash components so i can move ahead on the wiring.
I made this LED turn signal and high beam indicator some time ago, so I
took the PWM dimmer apart, extended the wires, and installed them.
53 Chevy Pickup
Old 10-22-2016, 02:54 AM   #266
Nut Case
Nut Case's Avatar
Re: Plus Five
Donandal
I'm in awe about your modifications and execution they're fandamtastic.
I need a few details on photo's 2-4, what they are and how they're to be used.
Thanks in advance
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 10-22-2016, 06:27 AM   #267
donandal
Re: Plus Five
Thanks.
Photos 2 and 4 are pictures of a LED dimmer i bought, took apart,
and lengthened the wiring to use for dimming the LED's I'm using
for turn signal, high beam, and brake indicators.
A typical headlight dimmer won't work to dim these LED's, so I used
a pulse width modulator style I bought off EBAY for about $3.00.
I'm using the rheostat to dim all four LED's simultaneously, thru their
common ground wires. The dimmer knob will go just to the right
of the steering wheel. The rest will be hidden under the dash.
The LED's are just too bright for night time driving for my taste without
dimming them.
53 Chevy Pickup
Old 10-22-2016, 06:30 AM   #268
donandal
Re: Plus Five
Picture three shows both an original one, and the one I extended.
I bought two just in case...
53 Chevy Pickup
Old 10-22-2016, 02:54 PM   #269
donandal
Re: Plus Five
I installed the LED dimmer and the dash board extensions, A/C
louvers,and A/C controls.
53 Chevy Pickup
Old 10-28-2016, 08:03 PM   #270
donandal
Re: Plus Five
Not much to report.
I've been wiring up the Air conditioning and the headlight harnesses.
While I was planning the wiring for the gauges, I realized I didn't
remember which opening is for the speedometer and which one is for
the gauges.
I see pictures with the speedo on left, and pictures with it on the right.
Any thoughts?
53 Chevy Pickup
Old 10-28-2016, 10:02 PM   #271
solidaxel
solidaxel's Avatar
Re: Plus Five
I have them both ways and I like the speedo on the right, my eye goes to it easier
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-28-2016, 10:40 PM   #272
JSavoie
Re: Plus Five
Not sure if this can help or not but here it is:
JSavoie is offline   Reply With Quote
Old 10-29-2016, 11:28 AM   #273
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Plus Five
I agree - the neat thing about custom stuff is locating things where you like them.
Old 10-29-2016, 04:35 PM   #274
donandal
Re: Plus Five
That does help...
do you suppose the speedo was on the right because the steering column
was slightly offset to the right from the factory?
I centered mine when I put in the newer style column.
53 Chevy Pickup
Old 10-29-2016, 06:45 PM   #275
JSavoie
Re: Plus Five
Others will certainly be of more help than me 'cause I'm still just compiling datas/info on AD trucks and preferably panels and suburban as I plan on buying one to make a restorod with it. I only happened to have a PDF on 1953 ADs. Should you need it, just drop me a line in private with your e-mail address so I can send it to you.
JSavoie
