Old 11-09-2018, 02:27 PM   #251
joewell80
Re: No Limit Trailing Arm Rear Suspension
I love the No Limit Trailing Arm Suspension so far, the ride is much better than expected. Great product!
joewell80 is offline   Reply With Quote
Old 11-11-2018, 12:59 AM   #252
gringoloco
A guy with a truck
gringoloco's Avatar
Beautiful truck!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-11-2018, 03:22 AM   #253
smbrouss70
smbrouss70's Avatar
I agree! Very nice!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 05-30-2019, 02:07 PM   #254
jerry.t
what is the towing/ hauling capacity with one of these kits??
jerry.t is offline   Reply With Quote
Old 05-30-2019, 02:13 PM   #255
jerry.t
N/M i found my answer .
Old 05-30-2019, 04:14 PM   #256
robnolimit
robnolimit's Avatar
As this is designed to be a bolt-on performance upgrade from the OE, (and it is awesome for that) the load capacity is greatly reduced. With a 250 lb spring, I would say 500 lbs would be the max. But this could also be appx 400 lbs tongue weight. If you went up to a 350 spring (it would ride a little stiffer empty but still good) that would give you appx700 lbs load and 500 tongue wt.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 05-30-2019, 06:39 PM   #257
jerry.t
i have been watching your youtube vids for some time now, and really wanting to use your stuff, but it will be on a 1 ton truck, that will be towing a 28' enclosed trailer. and wasnt sure what the springs would handle. going to have to scale my tongue sometime i guess. it will be a while before i get to that point of the build anyway. and thanks for the reply
Old 05-31-2019, 08:54 AM   #258
robnolimit
robnolimit's Avatar
In that situation, I would do a heavy duty 4-bar with air bags. That would get you the best in ride quality and towing capacity.
Old 06-02-2019, 09:27 AM   #259
hubba033
hubba033's Avatar
Ive been looking for a new trailing arm setup and really like both the fat bar and the oe arm setup. I already am running slam specialties bags how can I use these bags with either of these setups? Thanks for any help
72 C10 swb LS 5.3 LSA Blower/4l60 performabuilt
01 Pontiac Trans Am WS6
hubba033 is offline   Reply With Quote
Old 06-06-2019, 09:09 AM   #260
robnolimit
robnolimit's Avatar
Our trailing arm system is really built for coil-overs. We do have a bag/shock version of the FatBar, but it is designed for a tapered-slider style bag, not a double bellows. Not sure how much you want to hang on to those bags in the big picture.
Old 06-06-2019, 01:19 PM   #261
hubba033
hubba033's Avatar
I need to keep the bags for hauling atvs and other parts. Will my bags work with the fatbar setup? Thanks
Old 06-06-2019, 03:10 PM   #262
SCOTI
SCOTI's Avatar
Slam bags are typically the DBL convoluted style. The Fat Bar uses the 'sleeve' style bag. To use double convoluted bags where sleeve bags are intended to go requires investigating clearances, set-up dimensions, understanding possible performance differences vs what was spec'd, & possible fabrication changes.
So, is there a possibility of using your current bags in a kit where they weren't intended/spec'd for use? Sure. But only you or your builder can answer that question. Ideally, you need a Truck Arm kit that can utilize bags or coil springs in the original location to use the DBL Convo style Slam bags.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-07-2019, 08:55 AM   #263
robnolimit
robnolimit's Avatar
It's possible, but as Scotti said, that's now in the 'custom build' realm. I can set you up with a trailing arm or FatBar kit with some parts deleted and some other parts added to help, but then it's not really a packaged 'kit'. Some custom fab required.
BTW, the F9000 slider bags hold 1500 lbs each at 100 psi. So, 3000 lbs total - the appx 800 lbs of sprung weight on the rear axle of the truck leaves around 2200 lb load capacity. I used these bags on the JT for years, towed trailers and hauled parts with no issues. And, they don't feel like jelly when the truck is empty.
Old 01-21-2020, 09:55 PM   #264
Chevy Punk
Rob, I would like to use F9000 bags on the rear of my 72 lwb in the stock location on the trailing arm. I would like to have a softer ride than my current 5” springs but be able to haul more on demand. Do you know what the effective spring rates would be related to air pressure? What pressures do you run in the rear of JT and how tall are the spacers or brackets that you used to mount the bags? Thanks!
Chevy Punk is offline   Reply With Quote
Old 09-19-2020, 01:28 PM   #265
Speedracer39
Speedracer39's Avatar
I have a 72 C10 that is a leaf spring frame and I’m looking at purchasing this kit with coil overs. But I am measuring everything to see it it will work. The only part of this kit I have doubts is the panhard bar mount that bolts to the drivers frame I’m unsure if my boyd tank or c notch will be a problem. Can you give me the measurements of the mount so I can factor that in. Thanks. I have included a pic of what I need the dimensions of and my frame
Speedracer39 is offline   Reply With Quote
Old 10-10-2020, 06:48 PM   #266
AllGoNoShow
Do they even make this kit anymore? I don't see this on their website....just the four bar rear suspension (or 3 link) version they sell.
AllGoNoShow is offline   Reply With Quote
Old 10-11-2020, 03:09 PM   #267
Speedracer39
They had it listed when I posted this. But it is gone now, Looks like possibly it didn’t work out as well as they had hoped. I’ll check out the ride tech website
Old 10-13-2020, 11:05 AM   #268
biketopia
Yea I'm wondering the same thing. I had it up and was looking over my options and was contemplating going all in on this for my truck and now it's not on the site.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-13-2020, 08:41 PM   #269
70inbville
Still available in conjunction with their wide ride kit. Wish Rob would chime in and let us know what is going on?
70inbville is offline   Reply With Quote
Old 10-15-2020, 10:05 AM   #270
robnolimit
robnolimit's Avatar
Yes, we still make and sell this kit. It is available in a chassis pack or separate. I will check on the web site. Sorry for the delays. As always, you are welcome to call the shop 865-940-1503 for instant information.
Old 11-20-2020, 03:33 PM   #271
biketopia
Rob are you guys doing any holiday sales? I tired calling the shop the other day and kept getting a busy signal.
Old 09-01-2021, 04:29 PM   #272
cjohnson6772
cjohnson6772's Avatar
If someone didn't want quite as much drop, could the Vikings be subbed out for an inch or two taller coilovers?
cjohnson6772 is offline   Reply With Quote
Old 09-01-2021, 05:38 PM   #273
SCOTI
SCOTI's Avatar
I recommend calling for a faster response time.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2021, 02:04 PM   #274
SkidmoreGarage
The Vikings come in different lengths, just give NLE a call. They have enough knowledge that they can confirm whether your concern is real and order you the right part.
You select the coilover length for the ideal amount of travel at ride height given your suspension mounting points. You don't want the shock to be your travel limitation, and generally you want to maximize stroke (longest shock possible). Increasing the static ride height doesn't always alter your bump stop and shock mount location, and therefore may not decrease your shock length as you may expect.
SkidmoreGarage is offline   Reply With Quote
