Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-27-2017, 10:34 AM   #251
Deer_hunter_088
Deer_hunter_088's Avatar
Re: 68 C50 Looongbed pickup build
Originally Posted by Stephen717 View Post
Good luck on the job Noah, and gunk is always nice when you have a hose or pressure washer to get it off with.
Thank ya. i figured if i can have two trucks, one a classic, and a beautiful girlfriend, then i can go out and get a job.
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 01-30-2017, 11:00 PM   #252
rkn463
rkn463's Avatar
Originally Posted by Deer_hunter_088 View Post
I applied to a local grocery store, so i can keep my s10 runnin, and slowly restore my k10. hopin i get the job
Warning, Unsolicited advice follows: When you go to work for someone, treat it like it is your own business, don't waste, always try to look for ways for your employer to be more efficient. You'll be a manager in no time! Ask any of the old guys here...
Now for the weekend update:
Saturday was spent working on the fence project
Originally Posted by Advanced Design View Post
....were you putting up wire fence?
Here you go, the red line is the North boundary of my property. This represents around 2200 feet of fence. On my side lies the remains of an old dry stacked stone fence. It is about the only piece of physical history on our place. Because of this I wasn't willing to push it out of the way with a dozer so I'm manually picking up rocks and throwing them back on the pile. Along with that a lot of chainsaw work. Did you know you can get poison ivy when the vines don't even have leaves??
After throwing rocks for several hours Saturday I finally got to work ion the truck. Time to put the front clip back on. I started by pulling the truck out of the shop and turning it around where I could get to it. Check out that battery hold down!
Next I grabbed the front clip with the Bobcat and moved in to position.
I took a look and there was a lot of rust on the lower part of the fenders so I scuffed it up and hit it (poorly) with some rust reformer.
Size:  40.5 KBName:  ccc.jpg
I took a break for supper with my brother and sister in law and when I was finished I found out that I had run out of steam for the day so I went to bed.
More to come...
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 01-30-2017, 11:26 PM   #253
rkn463
rkn463's Avatar
Sunday morning I got up and finished connecting the park brake that I had modified last weekend. Once the cable was attached and the mechanism bolted in the park brake works perfectly. I still need to tie the cable down with the clamps from the 89 and I will have to relocate the dimmer switch by a couple of inches since it is now tucked up under the park brake lever. After that I set the front clip on and threaded in a couple of bolts. By then it was time to go to church.
Following church I tried setting the radiator in the 4-core lower mounts that I had moved to the new position. Oops, the drain petcock hits the power steering box! I removed the petcock and now the radiator clears the steering box by about 3/16th of an inch.
Today I dropped off the radiator from the 89 to be re-cored with cut down tanks. They said it will be ready on Thursday
I will still need to get new radiator hoses, hopefully finding something to fit wont be to big of a challenge. I will also have to re-engineer the battery tray as a modification that I made a few years back is encroaching in to the area where the wider radiator needs to sit.
I must say that as little time was spent setting the front clip back on the truck, it registered as a huge accomplishment; it put the fire back in me
In making this post I realized I haven't done as well taking pictures, I'll try to fix that next weekend.
Have a good week everyone!
-Richard
Old 01-31-2017, 12:00 AM   #254
Advanced Design
Advanced Design's Avatar
Yep, that is a big fencing project.
Poison ivy vines with no leaves is not to be ignored...learned that logging in woods many years ago.
Good progress on the truck!
Advanced Design is offline   Reply With Quote
Old 01-31-2017, 10:09 AM   #255
Deer_hunter_088
Niceeee. tried workin on mine this weekend. instead i just sat in it. i think itl be up for sale soon
1998 S10ZR2
Old 01-31-2017, 05:27 PM   #256
Stephen717
Stephen717's Avatar
don't say that. you'll regret it if you sell it. I've wanted back the 73 camaro my dad sold since he sold it. and as for work all I did was take out the side markers that were from a 68 and tail lights and reverse lights that were from a 67
Stephen717 is offline   Reply With Quote
Old 02-01-2017, 11:26 AM   #257
Hewfil1
Hewfil1's Avatar
don't say that. you'll regret it if you sell it.\
x2
Hewfil1 is offline   Reply With Quote
Old 02-01-2017, 03:27 PM   #258
Deer_hunter_088
Might be sellin the bed, i dont like the 65 step bed. i want a period correct bed or a gmt400 step bed. but Ive always wanted an ole 3rd gen camaro.
1998 S10ZR2
Old 02-02-2017, 11:46 AM   #259
Hewfil1
Hewfil1's Avatar
If the bed isn't swiss cheese I'll take it
Old 02-02-2017, 12:18 PM   #260
Stephen717
Stephen717's Avatar
so an 1980s camaro or late 1970s? because the third gens didn't start until 1982.
Old 02-03-2017, 10:15 AM   #261
Deer_hunter_088
i want the 82 style, because ilike how they look, but an 80-82 i wouldnt mind.
1998 S10ZR2
Old 02-03-2017, 02:20 PM   #262
Stephen717
Stephen717's Avatar
That's cool. I've always liked the second gen 71s but I wouldn't mind having an 89 firebird
Old 02-05-2017, 12:13 PM   #263
Deer_hunter_088
quite a far drive lol.
I want one to build to go FAST
1998 S10ZR2
Old 02-08-2017, 12:57 PM   #264
JohnJ@RideTech
JohnJ@RideTech's Avatar
This thing is cool!
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 02-09-2017, 10:27 AM   #265
Deer_hunter_088
Originally Posted by JohnJ@RideTech View Post
This thing is cool!
Im waiting for his weekend update, and you live in Jasper Indiana?
1998 S10ZR2
Old 02-09-2017, 10:30 AM   #266
JohnJ@RideTech
I actually live in Owensboro KY but commute to Jasper for work. I noticed you aren't that far away from us.
John J.
Sales/Tech
Old 02-09-2017, 10:41 AM   #267
Deer_hunter_088
Not at all man. mention the mount carmel aces at work i dare ya. we are Jaspers rivals, beat em by 1 point.
1998 S10ZR2
Old 03-14-2017, 03:26 PM   #268
Deer_hunter_088
okay wheres the update bud?
1998 S10ZR2
Old 03-27-2017, 11:45 PM   #269
Stephen717
Stephen717's Avatar
It's been almost 2 months man. You've got us on the edge of our seats with excitement for you're latest update.
Old 04-02-2017, 12:48 PM   #270
rkn463
rkn463's Avatar
Sorry for the lack of updates, I've been really busy with the fence project that I mentioned a while back. Very little has happened with the truck which has been very frustrating. Right now I'm still trying to get radiator hoses worked out. I would never have thought that hoses would be a problem... But they are!
I'll try to get an update with pictures in this week.
-Richard
Old 04-03-2017, 09:08 AM   #271
Deer_hunter_088
-Richard
At this rate imma get mine done before you bud
1998 S10ZR2
Old 04-03-2017, 09:30 PM   #272
rkn463
rkn463's Avatar
So I did get the radiator, but there were issues…
I will still need to get new radiator hoses, hopefully finding something to fit won’t be too big of a challenge.
Haha… HA! Oh the pain. Lower radiator hose for a 68 with a 366 is discontinued. Seems it would be a simple matter to fab something. No, not really.
OK, this part would be no big deal, if I just had some free time to work on stuff.
Right, that put the fire in me, somehow it doesn’t seem that way when I think it has been two months with almost nothing to report.
OK, so here is a video of what I have been working on https://www.youtube.com/watch?v=edJnnJvq81Q
A bit of background, we need a new fence between my neighbor and myself. The quote was 12K dollars. I ain’t down with that. We worked out a deal where he paid for materials and I do labor. He had his side dozed, my side has an old dry stack wall that I was unwilling to let get pushed aside so I’ve been doing manual cleanup each Saturday since deer season ended (that is when the truck progress slowed to a crawl). Anyway that description of the project is an oversimplification but you get the idea. As I was moving rocks out of the way I started re-stacking…. The video is many weeks old, I finished the cleanup last Saturday, next weekend we start building the fence. I'll try to get a new video of the current status next weekend.
-Richard
Old 04-03-2017, 09:32 PM   #273
rkn463
rkn463's Avatar
Not convinced....
Old 04-03-2017, 10:44 PM   #274
rkn463
rkn463's Avatar
Here is a comparison between the one that came in the 68 with the 327 and what a stock 68 with a 366 would look like, also 2-core vs. 4-core!
I did gt the radiator that week and I needed to move the lower mounts and replace them with the wider ones for the 4-core radiator. No big deal there. Here are a couple of pictures showing the original small mounts and the larger ones in position.
Size:  48.7 KBName:  AAC.jpg
After mounting them I set the radiator in and the width was off by about a quarter inch (too wide). I pulled the passenger side out and hogged out the holes so that i could set it properly (thought I had pictures but apparently not).
I set the radiator in and found that the core was tweaked... With it sitting properly at the bottom the top wasn't square to the core support. I paid a lot for it and was quite upset but rather than start over I decided to just make the mounts work, they would have to be custom anyway.
About that time it struck me that there was an outside chance that I could have a set of 4-core upper mounts with a front end I bought for parts. I went and checked and sure enough that truck had come with a 4-core but I hadn't grabbed the top mounts. So... I would need to fab up the upper mounts using parts from both the 89:
And the 68.
Thanks for not giving up folks! More coming later this week...
-Richard
Old 04-04-2017, 09:16 AM   #275
Deer_hunter_088
Not convinced....
lol now that i got a job, and its summer, so imma get this done so i can show up to homecoming or prom and be like "I TOLD YOU SO" to all the haters.
1998 S10ZR2
22.5 wheels, c50, disk brake conversions, hydroboost, pickup
