Old 09-16-2017, 11:05 AM   #251
buffydores
buffydores's Avatar
Re: 1978 Russet Metallic 4x4
I'm not interested in going through the hassle. I want to know why it's clocked. I don't think it was an accident. Either it was the rebuilder or mechanic. Just want to know if there was a good reason for the change. But I'm not jacking with taking it back. That housing is designed to be clocked for different situations. Previously the output was way up high. It's just not a big deal.
Old 09-17-2017, 07:51 PM   #252
buffydores
buffydores's Avatar
The NP203 transfer case showed a leak at the speedo cable. I unscrewed the cable and then the sleeve, and of course the speedo gear comes to see me.
The problem appears to be the sleeve. There's an internal o-ring like scrubber that seals around the shaft of the speedo gear. A new sleeve is AC Delco Part #326561. It's a discontinued part, so I'll have to get one mailed to me. If you look at the second picture, you can see the groove inside the sleeve where the scrubber seal goes. Mine was non-existent.
Old 09-18-2017, 12:21 PM   #253
buffydores
buffydores's Avatar
I talked to the rebuilder. Apparently, that is a new rear output housing. And not surprisingly, they're not all the same. As a confirmation of the correct installation, the breather tube is indeed mounted up high on the housing. Now I just have to wait a few days to get the sleeve. I went ahead and ordered two sleeves because the seal tends to wear out, and I don't want to try to hunt one of these down ten years down the road.
Old 09-18-2017, 10:31 PM   #254
buffydores
buffydores's Avatar
Here's the plaque installed. Lighting sucks in the garage.
And backed up so you can see the sticks.
Old 09-19-2017, 01:41 PM   #255
phillipm
Looking killer! Thanks for sharing the pics.
Old 09-19-2017, 08:47 PM   #256
buffydores
buffydores's Avatar
The rear armrest is a nice spot for the fire extinguisher:
ARB Fridge Freezer nice and securish:
Old 09-21-2017, 02:38 PM   #257
phillipm
Man the Fridge is cool but takes up so much room! Are they carrying your luggage for you on this adventure?
Old 09-21-2017, 02:46 PM   #258
buffydores
buffydores's Avatar
All I need is my canvas duffle. All my other gear is packed in the various compartments. But indeed, they do have a luggage vehicle. This is what the back will look like while driving. The cooler is carrying valuable alcoholic treats and other tasty morsels that warrant valuable real estate. There's also the back seat for soft gear if needed. I'm still waiting on my sleeve. I'm not terribly patient. I'm driving it hard next week and then onto the trailer the following Sunday.
Update....sleeve is in. I'll pick it up a little later and get it installed. Heading down south tomorrow with my boys to fish for specs and reds. We're pumped.
Old 09-23-2017, 10:39 PM   #259
buffydores
buffydores's Avatar
So I buttoned everything up and found another leak at the rear seal to the transfer case. Apparently, no one took the time to actually press the seal in. So after a little wrenching and hammering, all the leaks are addressed. Now I'm just driving it as much as I can over the next few days and then looking over everything over and over again.
I just purchased a fancy VIAIR 400P Automatic Air Compressor for tire refill duty. I don't want to be the guy waiting on support trucks to transition me back to the road.
Besides my final selection of hand tools and supplies, I think we're close.
Old 09-24-2017, 10:53 PM   #260
buffydores
buffydores's Avatar
Again, I admit, I'm a novice at prepping for overland adventure. The organizers apparently have a whole support staff of trucks and mechanics coming, so technically, I don't need anything. But.....that just doesn't feel right. If I can handle most basic stuff, I'm not gonna act like I've been neutered of ability and rely on somebody to show up. That would be throwing away part of the fun of back country adventure. So above are my basics. It's not all of my stuff, but most of the hand tools. Chime in with any opinions on the matter. I'm all ears.
No leaks have showed up. I'll keep pushing it. While testing the brakes, looks like I don't have enough clamp to lock them up. Any ideas there. They're good, just not enough to lock. They also pull a little right with full pressure, so I suppose my left brake line is showing it's age.
Old 09-25-2017, 01:37 PM   #261
phillipm
Like you said, since they'll have people there too I'd just bring things that may be either unique to your truck, or things that you'd just feel comfortable knowing you've got. For the brakes I'd normally say you're probably not going to be going fast enough for it to matter, however if the traffic line is close together that could be bad!
Old 09-25-2017, 03:09 PM   #262
buffydores
buffydores's Avatar
I adjust my driving patterns to the performance of the vehicle. So wide berths for me.
Also, after running it about fifty miles, I started to bleed transfer case fluid like a stuck pig. It took me awhile looking at it with the good folks at Foreign & Classic today to figure it out. It was the improper clocking of the rear output housing. Here's what I think was happening. Because it was clocked, the air vent tube was not directly on top of the housing. As the housing filled up with oil, the air vent hole would get submerged in fluid. Now the air couldn't escape. As things warmed up the air expands creating pressure on the fluid pressing the fluid up the vent tube or out the seal or the sleeve. Since oil was being refreshed into that part of the housing, the oil level didn't lower to where the air could escape, so it would keep pushing oil out. So, we clocked the rear housing to where I remembered it, and lo and behold, the vent is pointing straight up and we're no longer bleeding oil. Feels good.
The twin stick starts to rattle a bit at speed, so I'm gonna piece together an isolater that will also prevent inadvertent shifts of the 4x4 levers.
Old 09-26-2017, 12:27 PM   #263
buffydores
buffydores's Avatar
I made this little isolator with my orange HDPE I had leftover from the tailgate. This does two things: (1) prevents unintended transfer case shifts (2) eliminates rattles from the shift levers. It's a little obnoxious, but it works perfectly. I hate rattles. It pops right in and out.
Old 09-27-2017, 02:54 PM   #264
buffydores
buffydores's Avatar
Lookie there. Properly clocked output housing.
I can't reiterate enough what fun this thing is to drive. It takes things like train track crossings like a dream. We're ready to go folks. I'm gonna park it tonight and start detailing in preparation for the haul on Sunday.
Old 09-27-2017, 03:10 PM   #265
phillipm
So he didn't have it on right, or this way just works as well?
Old 09-27-2017, 03:23 PM   #266
buffydores
buffydores's Avatar
They didn't put it on right. Super easy to fix. This way, the air vent points straight up and releases air pressure no matter the oil level. This is how it was designed. He had never had this problem reported to him. I'm not exactly sure why. The best I can figure is that my high speedo cable configuration, as a late production NP203, was not nearly as common as the earlier NP203. And in fact, my later model NP203 is generally stronger with the heavier differential carrier(instead of the stamped carrier) and chain setup. Perhaps he sees very few of these, even with his extensive experience.
I've since looked at a whole bunch of examples of NP203s installed on the trucks. Apparently, my rear output housing was native to the last two years. Before that, the speedo cable exited near the bottom pointing out towards the driver's side. Pretty exposed. The '78s and '79s look like mine, nice and high, out of the way.
Old 09-28-2017, 11:57 AM   #267
aggie91
I'm just glad to be here!
aggie91's Avatar
Glad to see you got it figured out. Maybe after your adventure you can dress up the "Stick Holder"...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-28-2017, 08:44 PM   #268
buffydores
buffydores's Avatar
Thanks Karl. I might round off the edges more. Originally I considered attaching some of my orange pyramid rubber, but after making it in HDPE, I was satisfied with the simplicity.
Ran into one last issue. The fuel nozzle was ejecting as the tank topped off. The vent hose was too small. Fixing that in the morning.
Old 10-02-2017, 01:33 AM   #269
buffydores
buffydores's Avatar
The 2017 Copperstate Overland
And so it begins.....
Still need to add some straps over the top.
Final assortment of gear. "Help me Jimmy Buffet Margaritaville Cordless Blender, you're my only hope." I think that's how the Star Wars quote goes.
Old 10-02-2017, 10:07 AM   #270
68Timber
I know the pieces fit
68Timber's Avatar
I thought a little bit of gear-stick rattle when you let off the gas was part of the charm? Congrats on getting it sorted and prepped for the trail, looking forward to the pictures!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-02-2017, 01:12 PM   #271
phillipm
Man I'd be worried the flapping of any part of that tarp would do more damage than driving it across the interstate...
Old 10-02-2017, 01:38 PM   #272
buffydores
buffydores's Avatar
Yep. Me too. It has a padded car cover underneath. Too late now.
As an update, it arrived safe in Scottsdale. There was some minor paint rubbing on the leading edge of the hood that I'll buff out with my orbital, but that's it. On the way home, it's traveling uncovered. It will be dirty. No need to protect dirt or let it get rubbed in like sandpaper.
Old 10-10-2017, 01:34 PM   #273
buffydores
buffydores's Avatar
I'm just counting the days waiting to get this started on Saturday........
Old 10-10-2017, 02:10 PM   #274
aggie91
aggie91's Avatar
Enjoy your trip. Take plenty of pictures so that we can be jealous of the fun you had!
Karl
The LST Challenge:
Old 10-10-2017, 06:20 PM   #275
buffydores
buffydores's Avatar
Will do, Karl.
