Old 08-01-2017, 12:51 PM   #251
jweb
jweb's Avatar
Re: What did you do to your truck today part IV
Originally Posted by rvrfoot View Post
Mocked up my new door.Attachment 1675651
Are you happy with the way the new door fits? I have been thinking about buying new ones.
jweb is offline   Reply With Quote
Old 08-01-2017, 03:23 PM   #252
rvrfoot
Yes I'm happy with the doors I don't know if you can see within the pictures but the fit is pretty good around the edge happy with them I'm going to try to get the fenders now I got a whole complete bed and everybody said don't buy it I bought it I'm pretty happy with that besides the headboard the tailgate pretty nice
rvrfoot is offline   Reply With Quote
Old 08-01-2017, 03:30 PM   #253
jweb
jweb's Avatar
The only new parts I have bought were fenders. I tried 3 different brands and they were all about the same. The biggest issue was the welded in piece at the front of the fender that lines up with the grill surround. All of the fenders had a large gap compared to stock, almost like the welded in piece was too small. The piece also didn't line up well with the grill surround due to this.
Maybe there's a way to fix it but I found stock fenders with rusted bottoms. Seemed easier to patch them then trying to cut up new fenders.
Old 08-01-2017, 03:35 PM   #254
rvrfoot
Thanks maybe I'll try looking for used fenders mines full of Bondo everywhere
Old 08-01-2017, 03:38 PM   #255
rvrfoot
Also if I try new ones there's two places that are pretty close to me Brothers trucks in Corona and car and truck shop in Anaheim I live fairly close if they don't fit I can take it back you probably have to do shipping
Old 08-01-2017, 03:49 PM   #256
jweb
jweb's Avatar
I was going to say drive over to Truck and Car shop and check one out. I bought 2 different fenders from local shops, Dan's Classics in Portland and The Filling Station in Lebanon. I was able to return them both. The third fender was new in the box from someones abandoned project, I checked for the issue before buying it.
Maybe the gap won't bother you, it sure would save a lot of work and then you know there's no hidden rust.
Old 08-01-2017, 03:56 PM   #257
65chevysub
65chevysub's Avatar
got one door frame stripped and reprimered and installed new door check. Found some rust at the bottom of the door that will have to be POR-15'd or blasted, but not too bad....yet. Even came across the original paint(Light Blue).
65chevysub is offline   Reply With Quote
Old 08-01-2017, 06:04 PM   #258
ChevyJr
Junior Member
ChevyJr's Avatar
@rvrfoot How'd the repop door fit?
ChevyJr is offline   Reply With Quote
Old 08-01-2017, 06:41 PM   #259
rvrfoot
Pretty good I was quite happy with them compared to all the hype everybody's talking about on the internet I bought a complete bed too happy with that I'm going to try fenders everybody said the fenders or pretty bad
Old 08-02-2017, 12:35 AM   #260
Softpatch
Softpatch's Avatar
washed it it's been yrs (2014) since I washed it started clay bar ran out of time
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 08-04-2017, 11:00 AM   #261
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Sanded the firewall to 600 grit. Few more spots and then a good cleaning and masking and ready for paint!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-07-2017, 10:31 AM   #262
AngryPirate
AngryPirate's Avatar
I got the engine & trans pulled out, pressure washed the 57 years of dirt and oil off of everything...I also power washed through what was left of the frost plugs. ;-)
Engine on engine stand now!
AngryPirate is offline   Reply With Quote
Old 08-07-2017, 06:47 PM   #263
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Got some paint down. Now for cutting and buffing and it should look almost perfect.
Old 08-09-2017, 10:46 AM   #264
vin63
It's Better With Nitro
vin63's Avatar
After about 6 hours of sanding, I finally got some stain on the bedwood. A few more rounds of sand-then-stain, and I hope to get some urethane down this weekend.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-09-2017, 11:22 AM   #265
AngryPirate
Originally Posted by vin63 View Post
After about 6 hours of sanding, I finally got some stain on the redwood. A few more rounds of sand-then-stain, and I hope to get some urethane down this weekend.
Man, that is NICE looking.
Old 08-13-2017, 10:58 PM   #266
rvrfoot
I installed my roll pan today.Name:  DSCN0971.jpg
Old 08-14-2017, 08:39 AM   #267
jbgroby
jbgroby's Avatar
Got the pipes installed, Woke up half the subdivision getting to the shop, but what the heck - they had to wake up anyway! Dan took his time and had to route carefully run around the oil filter and transmission pan, I have torsion bars so he was able to bring the pipe in the center of the arch and go to the rear, good clearance.
jbgroby is offline   Reply With Quote
Old 08-14-2017, 11:22 AM   #268
rvrfoot
Installed my new auto meter gauges and a clock.Name:  DSCN0959.jpg
Old 08-14-2017, 12:17 PM   #269
drmatera
drmatera's Avatar
More rust repair. This is very intimidating as it's my first time but I think it's coming out ok. Nothing is welded yet. Gotta fit floor pan next.
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
drmatera is offline   Reply With Quote
Old 08-14-2017, 03:35 PM   #270
oliver63
oliver63's Avatar
run fuel line from tank
1990 Silverado Sport
2010 Silverado K1500
1996 K2500
oliver63 is offline   Reply With Quote
Old 08-14-2017, 03:52 PM   #271
slepysal
slepysal's Avatar
Replaced shifter bushings , installed press on door seals, buffed out the paint and installed some Cragar S/S.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-14-2017, 05:15 PM   #272
Turtleman
Turtleman's Avatar
WOW,, that floor pan is shot!... Have you ever thought of just adding one of those glass bottoms in there instead? you know,,, Like the ones they have on those glass bottom boats?.. you could cruz around and see what you pass over then
Turtleman is offline   Reply With Quote
Old 08-14-2017, 05:47 PM   #273
drmatera
drmatera's Avatar
That would be pretty cool. I could wave to the squirrels as they run under the truck...
Old 08-14-2017, 07:47 PM   #274
rvrfoot
Put on my new window and vent window.Name:  DSCN0962.jpg
Old 08-14-2017, 07:48 PM   #275
rvrfoot
