08-17-2019, 11:11 PM | #251 |
Re: Dumptruck Dolly
A straightened tie rod, new tie rod ends, steering stabilizer attached...a good day. I am waiting for a connecting link for the steering linkage. I’ll start cleaning crossmembers soon in preparation for paint, and then opening up the truck.
08-20-2019, 07:13 PM | #252 |
Re: Dumptruck Dolly
Prepping more parts. Notice the V8 crossmember I’m grinding on...last pic shows Dolly waiting patiently...
08-20-2019, 07:20 PM | #253 |
Roadtrip!
Re: Dumptruck Dolly
Getting closer... That is a nice looking shop also.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-20-2019, 09:31 PM | #254 |
Re: Dumptruck Dolly
Thanks...I always wanted a shop like this while I was in college (for years); I am thankful and glad I have it.
Yes, with every part that’s cleaned up, I inch closer to that day. After the crossmembers are cleaned, I think I’ll tackle the transmission/transfer case prep. |
09-01-2019, 12:16 AM | #255 |
Re: Dumptruck Dolly
Dolly is now in her stall, ready for the transformation.
09-01-2019, 12:21 AM | #256 |
Re: Dumptruck Dolly
The proverbial “disconnect and remove the battery” photo, followed by draining of the radiator, as I am changing the motor.
09-01-2019, 12:25 AM | #257 |
Re: Dumptruck Dolly
I am going to remove the front clip to gain good access. First, I remove the wipers, and don’t forget to BAG all the little screws from the cowl.
09-01-2019, 12:28 AM | #258 |
Re: Dumptruck Dolly
Here, I document the number of spacers between the fenders and cab.
09-01-2019, 12:36 AM | #259 |
Re: Dumptruck Dolly
Off to the races...I am going to try leaving the hood on the clip, so I am just going after the bolts that attach the clip to the cab and front frame.
09-01-2019, 12:40 AM | #260 |
Re: Dumptruck Dolly
It’s easy to forget this bolt in the process...note the backing plate that goes between the fender and the cab.
09-01-2019, 12:43 AM | #261 |
Re: Dumptruck Dolly
I am taking this support bar off the drivers side fenderwell because I am going to leave the fenderwells on the clip, and with the steering in the way, it’s gotta go. I taped the bolts onto the bar once it was removed.
09-01-2019, 12:50 AM | #262 |
Re: Dumptruck Dolly
That’s what I got done for today, as I was working on a new project with some paint touch up...plus I was by myself, and I’m going to have to have help managing the clip removal.
09-01-2019, 08:21 AM | #263 |
Proprietor of Dale's Corner
Re: Dumptruck Dolly
I'm amazed that everything is unbolting. It's going to look good as a 4x4.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
09-01-2019, 09:07 AM | #264 |
Re: Dumptruck Dolly
09-01-2019, 10:56 AM | #265 |
Roadtrip!
Re: Dumptruck Dolly
You will be ready for the snow at this rate. You know there is a tool to remove the wiper arms so you don't have to pry with a screwdriver?
09-01-2019, 11:37 AM | #266 | |
Re: Dumptruck Dolly
If you can, send me a picture of the tool you mentioned. |
09-01-2019, 06:21 PM | #267 |
Re: Dumptruck Dolly
Lifting the nose off the frame...passenger side was stubborn and gave way to a 3 lb sledge...then I propped the sides up waiting for assistance.
09-01-2019, 06:23 PM | #268 |
Re: Dumptruck Dolly
Yes, I documented everything and bagged it.
09-01-2019, 06:54 PM | #269 |
Re: Dumptruck Dolly
Help arrived and we got the clip removed and placed in the yard. This was a big deal for me...NO turning back.
09-01-2019, 07:07 PM | #270 |
Re: Dumptruck Dolly
I'm surprised you only needed the 3# only once. Don't drink to much and run over the clip with the medium duty.....lol
09-01-2019, 07:09 PM | #271 |
Re: Dumptruck Dolly
Now, I’m going to “top half” the motor, preparing for removal...all electrical, and mechanical that can’t stay with the motor are removed, arranged and marked. These pics will assure I place the small clips, pins etc in the right spot when I put this together.
09-01-2019, 07:12 PM | #272 |
Re: Dumptruck Dolly
Here’s the mechanical “top half” of the motor.
09-01-2019, 07:15 PM | #273 |
Re: Dumptruck Dolly
Next is this Double BBQ Burger...one bun as I’m watching my Carbs.
Removing the shift handle pin on top the trans is left, and then I can “bottom half” the drivetrain...another day. |
09-01-2019, 07:18 PM | #274 |
Re: Dumptruck Dolly
09-01-2019, 07:21 PM | #275 |
Re: Dumptruck Dolly
I'm getting a little excited to see it done. That burger looks great. I'm having a tri tip sammich on a ciabatta roll. Mmmmmm
