Old 03-11-2021, 01:11 PM   #251
6DoF
6DoF's Avatar
Re: Orson the 49 GMC ~ Chris C.
Originally Posted by skymangs View Post
That’s exactly the reason it was chosen, that and the width. These trucks will fit a 55” seat, this one’s 53”
the yukon seat i got is 55 and it places my butt a little on the outside of the steering wheel. you'll probably be more comfortably centered with 53.
6DoF is offline   Reply With Quote
Old 03-12-2021, 12:24 AM   #252
skymangs
skymangs's Avatar
we FINALLY got the Wiring finished today! We’re hoping for initial startup tomorrow.
skymangs is offline   Reply With Quote
Old 03-12-2021, 12:28 AM   #253
skymangs
skymangs's Avatar
Wyatt started cutting and patching the floors that Michael half-assed
Old 03-12-2021, 10:45 PM   #254
skymangs
skymangs's Avatar
we spent all day trying to start the truck, but were plagued with problems. First a bad starter, then a bad fuel pump. Monday we diagnose it. Wyatt did get the floors done. Monday we will diagnose.
Old 03-15-2021, 10:30 PM   #255
skymangs
skymangs's Avatar
we spent all day today trying to start your Truck. No spark. I have 12v at every coil, and we have continuity through all 8 coil trigger wires. We did drill and tap the water pump for the fans thermostatic switch and discover a leak in the fuel tank, so we are replacing that
Old 03-16-2021, 11:34 PM   #256
skymangs
skymangs's Avatar
we spent the whole day checking continuity on the 80 circuits of the blue connector. Found a few mistakes too (I chalk it up to being JP's first time building a harness) tomorrow we go through red, and then I expect it’ll fire right up! We also installed the radiator for the last time.
Old 03-17-2021, 10:44 PM   #257
skymangs
skymangs's Avatar
we checked continuity on all 80 circuits of the red plug today, still no spark. Have a lead on the coil pack grounds I’ll run down tomorrow
did get all the pedal holes welded though. And did some finish work on the firewall.
Old 03-18-2021, 10:08 PM   #258
skymangs
skymangs's Avatar
We’re still scratching our heads as to why it won’t run (no spark). I had hoped that the ground to the coils would be the answer, but they had good continuity. We did put on your MAF and air filter today. Clearances are tight but there. Wyatt did some smoothing on your firewall. And we got the new gas tank physically in.
Old 03-19-2021, 10:48 PM   #259
skymangs
skymangs's Avatar
Still doesn’t run... Tearing my hair out at this point! Here’s the email I just sent Brendan (friend of mine and the owner of LT1swap.com)
"I bought a $100 scan tool, no idea how to make it show RPM. hot power to the coils, and both the battery and ignition pins on the PCM. ohm'd all the wires on the crank sensor. 12V to it. ohm'd the coil grounds and all the individual ignition wires, as well as the reference wire to each coil. Even went so far as to replace the crank sensor just in case. Still no spark!” ”
We wired the OBD2 port, hooked up a scan tool and got no engine codes. then out of desperation we tore into the Side of the motor and replaced the crank position sensor.
Old 03-19-2021, 10:50 PM   #260
skymangs
skymangs's Avatar
Here’s a picture of that drivers toe board. The firewall all finished up, notice the removable panel in the center for a firewall pass through.
Old 03-20-2021, 03:00 PM   #261
jed971959
Hi did you get it running
what tune file do you have in the computer
my 5.3 had no spark after doing the harness. I found that I put a 2005 tune file and used wiring harness for 99-02
jed971959 is offline   Reply With Quote
Old 03-20-2021, 03:54 PM   #262
skymangs
skymangs's Avatar
nope. I had LT1swap cut the PCM, just had Brendan do a basic Performance tune.
Old 03-22-2021, 11:10 PM   #263
skymangs
skymangs's Avatar
so my code reader given a PO336 code which says the crank position sensor must be diagnosed. We tried switching it out. There are only 3 wires. The lt blue has 12v key on, the yellow/blk has continuity with ground key on, and the reference Wire has ~5v key on. The adapters from EV6 to Delphi injectors got here yesterday, so we decided to rip out the modified one and install a pre-made with the adapters.
Old 03-23-2021, 01:35 PM   #264
edgeleycanuck
You've never been stumped yet, I know you'll get this one figured too!
edgeleycanuck is offline   Reply With Quote
Old 03-23-2021, 02:33 PM   #265
6DoF
6DoF's Avatar
block grounds connected well?
adjustable sensor mount? need it closer? turn the motor slowly and you should be able to see it go open on a multi meter when the teeth pass by
Old 03-23-2021, 03:56 PM   #266
skymangs
skymangs's Avatar
well I'm feeling pretty stumped and frustrated about now!
Old 03-23-2021, 04:11 PM   #267
6DoF
6DoF's Avatar
do the good signals continue during cranking?
Old 03-23-2021, 09:51 PM   #268
skymangs
skymangs's Avatar
yes, but I have no spark. It makes no sense!
Old 03-23-2021, 10:17 PM   #269
skymangs
skymangs's Avatar
The new harness doesn’t seem to have any PRND wiring so we are in the middle of adding 5 circuits to the harness. Needles to say, but I won’t be buying from them again! Tomorrow we hope to get the cab on for the last time.
Old 03-24-2021, 09:46 PM   #270
skymangs
skymangs's Avatar
We finished up the fuel system and bolted everything down. we also finished the PRND circuits and re-covered the harness. Put the harness through the firewall pass through, and mounted the cab.
Old 03-25-2021, 07:48 AM   #271
6DoF
6DoF's Avatar
that always feels awesome, makes it a truck vs a pile of parts.
Old 03-25-2021, 08:22 AM   #272
skymangs
skymangs's Avatar
you bet
Old 03-25-2021, 07:16 PM   #273
gigamanx
Exactly the air filter style I'm looking for on my Model A! Is this a Spectre brand or something else?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 03-25-2021, 09:28 PM   #274
skymangs
skymangs's Avatar
Sure is! Here’s a link https://www.ebay.com/itm/SPECTRE-816...72.m2749.l2648
Old 03-25-2021, 10:27 PM   #275
skymangs
skymangs's Avatar
We put them the cab back on for the final time. Then we moved the bottom of the column left, drilled and bolted it. We did have to clearance the firewall, but not to worry, we’ll weld it up.
