Old 03-03-2016, 02:02 AM   #2776
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
after some grunting, some PB Blaster, and some more grunting, both long bolts and body mounts were out
Gregski is offline   Reply With Quote
Old 03-03-2016, 02:07 AM   #2777
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I also removed the battery tray just so that I could have more wiggability, and then it was time to wiggle the radiator support out
I took my time and wore some construction gloves so I wouldn't cut my surgeon like hands, ha ha
and soon enuff Bob was your uncle
Old 03-03-2016, 02:09 AM   #2778
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
This may be the justification you all were seeking for me pulling the core support out, surely many of you have removed an engine out of a car without removing the entire front end, right, well look in the bottom right corner of this structure, or the lack there of
Old 03-03-2016, 02:11 AM   #2779
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
now lets take a looksie at that engine without having the grille obstruct our view shall we
Old 03-03-2016, 02:14 AM   #2780
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
things were going great, I was on an adrenaline high, so I kept going
decided to remove the water pump, so easy now without the silly radiator in the way, ha ha
four bolts later and it was off, by the way it must have square bearings cause it makes an ugly sound when rotating, needed replacing for sure
Old 03-03-2016, 02:15 AM   #2781
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ah what the heck lets separate the radiator fan from the water pump
Old 03-03-2016, 02:16 AM   #2782
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I was hoping to put in 2 hours tonight, but ended up putting in 4, so needless to say it was soon Beer:30
~ that's all for today folks
Old 03-03-2016, 02:30 AM   #2783
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
oh almost forgot, can you tell what is missing from one of these pictures, one is a pic of my original driver side fender, the other of an OEM replacement I got from a junkyard off of a '79 Scottsdale 10 for the passenger side
Old 03-03-2016, 02:38 AM   #2784
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Chaplain View Post
My original core support was about the same. In fact, since the battery was also rusted out you could look straight through and see the ground.
As usual, nice documentation.
Thanks, and yeah, this is one of the few design flaws of our beloved trucks, that silly lip in the bottom of the radiator core support catches water, dirt, and of course battery acid drippings. The other terrible design flaw is the taco hood. Another one would be the dumb always on blower fan in the cabin, so annoying. Then there's the lame fuel tank filler neck that you have to squat and hold the gas pump nozzle just right or it will run on the side of the truck, LOL. There may be one more, but I forget.
Old 03-03-2016, 02:55 AM   #2785
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
The lower built in nut is missing.
yup, good eye, and since you have a '79 also you mind checking what yours looks like, if you have not put the front end back together already that is, did GM get lazy and say why use 4 bolts when 3 will work, LOL
Old 03-03-2016, 11:59 AM   #2786
Titomars
Titomars's Avatar
Re: Restoring Rusty
In GM's defense, I would argue over some of those said design flaws.
when the fuel filler location were designed the filler nozzles of the day were of the old type (like a diesel nozzle) they were not problem like the vapor recovery nozzles are.
The "taco" hood was a DOT mandate to all manufacturers. before the event of the folding hood, In a front end collision the hoods had a better than average chance of entering the passenger compartment and under enough cases decapitating occupants.
due to their flat design, the real cause of the hoods bending over time is lack of lube to the hinges.
The blower on always was not a defect this was GM wide feature of their "Flow-Through" ventilation system. A lame idea in my book, but........
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-03-2016, 12:34 PM   #2787
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
I don't know if its true or not but read somewhere it was to create positive cabin pressure to keep exhaust fumes out of the passenger area.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-03-2016, 12:41 PM   #2788
68Timber
68Timber's Avatar
Re: Restoring Rusty
My 79 fenders are OEM and do not have the lower bolt hole.
John
74 Honda Z50 build
Old 03-03-2016, 02:29 PM   #2789
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
If you have one that hasn't been modified there are hooks and tabs to catch the back of the hood in a collision so the A-pillars aren't getting the brunt of the impact.
I've had four of these 73-80 trucks that had hinges that were properly lubed by the owner. All of them had zero bends in the hood.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-03-2016, 03:09 PM   #2790
jwilson645
Re: Restoring Rusty
Yup, that spot is a devil. Here's a nice shot of mine. Also notice that the front of the wheel well and the inner fender structure are gone too.
jwilson645 is offline   Reply With Quote
Old 03-03-2016, 09:59 PM   #2791
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
you was robbed, ha ha - thanks for confirming
Old 03-03-2016, 10:02 PM   #2792
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Day Three of Leftie Loosies
Fun Level = 11 (a little Spinal Tap reference for you all, horns up if you got it)
man I tell you working in a clean garage with an empty surface to put your parts on is such a big difference and a pleasure to work on your truck
Old 03-03-2016, 10:04 PM   #2793
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
we decided to move this party indoors tonight, and do a little wrenchin in the cabin
first we loosened up the shifter rubber boot
Old 03-03-2016, 10:07 PM   #2794
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
we were paying attention the last time we dropped the tranny so we learned (thanks to you all) how to press down and turn the metal cup to get the shifter stick out
Old 03-03-2016, 10:08 PM   #2795
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Hey, is this what they mean by Four On The Floor?
ha ha, I kid I kid
Old 03-03-2016, 10:10 PM   #2796
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then we removedatized the transmission turtle shell
Old 03-03-2016, 10:11 PM   #2797
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
we disconjoined the go backwards light switch thingie
Old 03-03-2016, 10:11 PM   #2798
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Johnny are you taking notes, there will be a Quiz you know!
Old 03-03-2016, 10:13 PM   #2799
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
next we disconbobulated the "Do You Know How Fast You Were Going Son?" cable
Old 03-03-2016, 10:16 PM   #2800
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then we had to suck in our gut (see Lowering The Truck posts above) and slid under the truck like a sloth and removed the ZZ Top bar
