04-14-2017, 02:04 PM | #2826 |
I'm trying....
Re: PO has me PO'd
Ditto that...loving all the recent progress and pics. Keep it coming!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
04-14-2017, 06:43 PM | #2827 |
Re: PO has me PO'd
Wow, was starting to get disheartened, glad you guys posted up....
mounted my bowtie on the grille today, not sure if there is a top and bottom perfect patina to match my truck, also played around with my bed side rails, but I'm not sure if I'm junking up the truck. sorta like adding another window to the taj mahal, you guys let me know
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-15-2017, 10:19 AM | #2828 |
2WD Jimmy
Re: PO has me PO'd
Eyebrows ARE a *****. And it doesn't matter if they are original or re-pops.
04-15-2017, 04:08 PM | #2829 |
Re: PO has me PO'd
I was wondering how long it would take you GMC guys, that has done eyebrows to chime in. Yes, truly a PITA
04-19-2017, 08:49 AM | #2830 |
Re: PO has me PO'd
04-21-2017, 10:17 PM | #2831 |
Re: PO has me PO'd
Man. I haven't kept up well. When did a Hickey hood come into the picture??
04-22-2017, 04:59 PM | #2832 |
Re: PO has me PO'd
[url=https://flic.kr/p/U3pAmN]20170421_113157
[url=https://flic.kr/p/U3hmwN]20170421_110031 started to fool around with the last piece of my cooling system. bought this hose to cut up for the angles Thanks for watching AJ I was browsing the truck side and saw it was available, had some money in my pocket, next thing I know it was on my porch
04-24-2017, 05:55 PM | #2833 |
Re: PO has me PO'd
finishing up coolant system trying to make round holes in the cable bracket [url=https://flic.kr/p/SWpMn6]
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-24-2017 at 06:10 PM. |
04-24-2017, 09:11 PM | #2834 |
Re: PO has me PO'd
Looking good! Dang, I love the look of those LT1 intakes. Seems like you're buttoning up lots of loose ends.
My LS Swap: http://67-72chevytrucks.com/vboard/s...d.php?t=718573 |
04-24-2017, 09:23 PM | #2835 |
Re: PO has me PO'd
Hey Jim, jmo but I'm not a fan of the side rails maybe if it were part amphibious you know some place to tie it off too. Lol. I also love the tpi setup use to have two GTA trans am. Thanks for the pics
Bill |
04-25-2017, 08:48 AM | #2836 | ||
Re: PO has me PO'd
Always liked the look of the TPI, but if the FI works, I'll change it out for a englese or hilabrandt Bill, thanks for bringing that up, I've been on the fence with that one. And, you're right, doesn't quite fit the direction I want to go. Good thing I didn't buy that NOS set that is available Maybe, I should have built an Amphicar Well, back to work on the throttle bracket, weird, my kick down cable only moves 3/4" and my throttle cable moves 2"
04-26-2017, 06:07 PM | #2837 |
Re: PO has me PO'd
[url=https://flic.kr/p/SXFsRS]20170426_120759
my ashtray kept falling out due to the plastic rails broken, went to my spare center section I bought years ago, and it had good rails. 4 Phillip screws later, all excess able from the front bottom, and my ashtray doesn't fall out any more. it is easier if the radio is removed [url=https://flic.kr/p/TE8NYj] you can see the threads of the two screws on the left side of the bracket (top and bottom) Maybe Wes will see this and will work for his next project
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-26-2017 at 06:21 PM. |
04-26-2017, 06:17 PM | #2838 |
Re: PO has me PO'd
[url=https://flic.kr/p/Uf5ox2]20170426_181055[
some of the handy work of the PO, some people shouldn't have access to tools, but luckily the mounting buckets cover 2/3 of the hole
04-27-2017, 09:24 AM | #2839 |
2WD Jimmy
Re: PO has me PO'd
[QUOTE
my ashtray kept falling out due to the plastic rails broken, went to my spare center section I bought years ago, and it had good rails. 4 Phillip screws later, all excess able from the front bottom, and my ashtray doesn't fall out /QUOTE] My Jimmy has the same plastic guides. I wish they had stayed with the old ball bearing style. |
05-02-2017, 12:20 PM | #2840 |
Re: PO has me PO'd
I agree with you Tom
[url=https://flic.kr/p/UmGGny]20170502_09461 I have to build a kick down cable adapter,and figure out how to hook it up, then on to the cruise control [url=https://flic.kr/p/UmGBTo] put the last plug in the cooling system, time to fire up the electric w/p. Thick I forget gaskets on the w/p
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-02-2017 at 12:25 PM. |
05-02-2017, 06:25 PM | #2841 |
Re: PO has me PO'd
does anyone have a pic. of the actual part that the cable is swagged to, and then goes to the throttle blade? Thought I had one
07-11-2017, 10:08 AM | #2843 |
Re: PO has me PO'd
sorry J for not posting up, seems I myself have been the project of late. Between my vascular surgeon, and my cardiologist, I've needed a complete rebuild... should be good to go, as I've had my surgeries done yesterday! A couple days recovery and should be back at it
Ya never know which way a project will progress, but I haven't given up yet. Hopefully, I'll have something to report in the next week or so
07-11-2017, 12:38 PM | #2844 |
Equal opportunity joke ofender
Re: PO has me PO'd
Glad to hear ya came out on the good side Jim! Get well soon.
Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
07-11-2017, 02:32 PM | #2845 | |
Re: PO has me PO'd
Today was a success, as I weed whacked most of the yard, which was great as I had NO pain in my legs, maybe even able to cut the grass 3-4 months of sitting on my arse, has gotten quite old
07-11-2017, 08:12 PM | #2846 |
Re: PO has me PO'd
Jim glad you're ok, I thought maybe you we're going to surprise us all with a brand new paint job.lol
Slow and steady usually gets done. Best wishes Bill |
07-12-2017, 04:27 PM | #2847 | |
Re: PO has me PO'd
I'd really like to fire the motor up, but still have some connections to make
07-12-2017, 10:20 PM | #2848 | |
Re: PO has me PO'd
been busy with seasonal maintenance and not on board much ,saw this tonight glad to hear your doing ok Jess
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
07-15-2017, 09:12 AM | #2849 | |
Re: PO has me PO'd
sux, all my pics up to page 75 gone, thanks photo bucket! I'm not paying 400.00
07-24-2017, 02:45 PM | #2850 |
Re: PO has me PO'd
[url=https://flic.kr/p/WRsuWv]20170724_134025
[url=https://flic.kr/ still having problems mounting up rad., seems my harness is to large with the addition of wires for the headlight relays
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-25-2017 at 09:42 AM. |
