07-25-2017, 09:39 AM | #2851 |
Re: PO has me PO'd
picked up my -12 and -10 block off caps, now I can continue on with the cooling system check, hopefully no leaks
[url=https://flic.kr/p/Wt4mBG]20170724_180453 also found my aluminum ring I made for the fuel pump hold down, now I can finish that up, after I find a schematic for the pump [url=https://flic.kr/p/VQ423r]20170724_144842
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-25-2017 at 09:45 AM. |
07-25-2017, 04:29 PM | #2852 |
Re: PO has me PO'd
four years and finically,have my aluminum rad. mounted to the 67-68 front core support (only designed for a two row rad.)using four row rubber bushes and brackets
[url=https://flic.kr/p/Wv5Cfw]20170725_161156 5/16tpi stud was the key to pull down straight, and then use the OEM bolt. bought a bag of them at Fastenal thru AUeevo black phorous coated and washer that rotates but doesn't come off
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-25-2017 at 04:35 PM. |
07-27-2017, 04:46 PM | #2853 |
Re: PO has me PO'd
This ought to be interesting, not a clue how to set up timing
Stabbing my dual sync distri.at least I remembered the gasket [url=https://flic.kr/p/X6QNkf]20170727_164113
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
08-29-2017, 09:51 AM | #2854 |
Re: PO has me PO'd
OK, I quit....EFI is not in my ability, carb and distri. is in my future for now. But, which one?
08-29-2017, 02:30 PM | #2855 |
Equal opportunity joke ofender
Re: PO has me PO'd
Jim
Sorry to hear that. You have put a lot of work into that efi.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
09-02-2017, 03:26 AM | #2856 | |
Re: PO has me PO'd
My installer quoted me a price of 1500- 2500 to wire this animal up, and dyno time to get it running right. Parts should be in, in a couple weeks. In the meantime, I get to tear the front of my engine apart one more time. Thank goodness I have that cross member that my son and I had modified from DIY4x4, makes it much easier to drop the pan Anyone want to buy a Cloyes timing cover with cam button? I'll be posting it soon in the classified section Thanks for watching, this beast may work soon
09-06-2017, 07:34 AM | #2857 |
Re: PO has me PO'd
started to take the front of motor off again, still have to pull timing chain cover and oil pan
[url=https://flic.kr/p/XS1yBU]20170906_072038
09-06-2017, 08:18 AM | #2858 |
Re: PO has me PO'd
since my crank moved, had to return to TDC. Now I have to find a bucket that hold 7 quarts of oil and zinc additive
[url=https://flic.kr/p/YfDdRB]20170906_081337
09-13-2017, 03:40 PM | #2859 |
Re: PO has me PO'd
My parts came in today from EFI Connections, cam and crank triggers. Along with the 4x reluctor
[url=https://flic.kr/p/Xqged3]20170913_153143
09-15-2017, 09:36 AM | #2860 |
Re: PO has me PO'd
talked to EFI, and they said the clearance between the reluctor ring tooth and sensor s/b 30 thou. measured mine and came up with 23 thou., so I added a 10 thou. spacer
[url=https://flic.kr/p/XsTuTh]20170915_091544
09-15-2017, 09:59 AM | #2861 |
Re: PO has me PO'd
timing chain cover installed, with crank sensor
word of caution...with the reluctor installed, it will push your balancer out maybe 100 thou., so alignment of belts and pulleys may be a problem in my future, we'll have to wait and see [url=https://flic.kr/p/Ys8DTU]20170915_095530
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-15-2017 at 10:24 AM. |
09-15-2017, 07:42 PM | #2862 |
Re: PO has me PO'd
09-16-2017, 12:22 AM | #2863 |
60-66 Nut
Re: PO has me PO'd
All you have to do is turn the correct amount off of the snout of the balancer or find a balancer from a L31 Vortec.
09-16-2017, 06:53 AM | #2864 |
Re: PO has me PO'd
perfect solutions, thank you! I would've never thought of that....did you ever get yours running?
09-16-2017, 09:16 AM | #2865 |
Re: PO has me PO'd
timing chain cover sealed and torqued to 12 ft/lbs. next step turn down balancer
[url=https://flic.kr/p/Yvjn1m]20170916_091148
09-16-2017, 11:03 PM | #2866 |
60-66 Nut
Re: PO has me PO'd
None of my projects are running.......no time with working 80hrs/7 days a week every week.
09-17-2017, 08:17 AM | #2867 |
Re: PO has me PO'd
Kinda hard to hold w/p, 4 gaskets and 2 March brackets in alignment at the same time, so I use exhaust studs for alignment, then remove to bolt up....
Captain, good for the income, bad for the toys! Glad I'm outta that rat race [url=https://flic.kr/p/Yx1wru]20170917_080854
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-20-2017 at 08:54 AM. |
09-21-2017, 10:31 AM | #2868 |
Re: PO has me PO'd
[url=https://flic.kr/p/YCJ9iC]
the gaskets had a chance to set up, so, I took one bolt out at a time and reinstalled with thread sealer. Left side mounting bolts were a PITA, had to use a ball end allen wrench to tighten
10-02-2017, 12:27 PM | #2869 |
Re: PO has me PO'd
back in the blue.....4 salmon hooked up, 2 netted and released, 2 foul hooked, broke off
pics to follow, trying to get off of iphone got my photos out of hock with photo bucket...thanks rsgt
10-03-2017, 10:26 AM | #2870 |
Re: PO has me PO'd
definition of insanity; doing the same thing over and over expecting differant results
My prndl pointer keeps coming out of the notch in the housing [url=https://flic.kr/p/Y1EoRm]
10-03-2017, 11:52 AM | #2871 |
Re: PO has me PO'd
10-09-2017, 11:09 AM | #2872 |
Re: PO has me PO'd
10-13-2017, 11:26 AM | #2873 |
Re: PO has me PO'd
saw foose use this method for installing porshe headlights in an europa. remove tape and install on white board.
Need to install computers under dash on a flat surface. 1/4 inch flange on plates [url=https://flic.kr/p/ZhV4cq]20171011_101608
10-13-2017, 11:58 AM | #2874 |
Re: PO has me PO'd
10-13-2017, 12:01 PM | #2875 |
Re: PO has me PO'd
