Old 03-08-2016, 10:44 PM   #2876
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then it was on to the other side 1-3-5-7
Gregski is offline   Reply With Quote
Old 03-08-2016, 10:47 PM   #2877
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then we cleaned the back side (closest to the firewall), man how many sides does this thing have? lol
Old 03-08-2016, 10:48 PM   #2878
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
yo Jimmy can we get a birds eye view of this beauty?
Old 03-08-2016, 10:53 PM   #2879
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Cleaning the Short Block
how about some glamour shots
not bad if I do say so myself for a Pollack n a grinder
Old 03-08-2016, 10:54 PM   #2880
lkfldredneck
Re: Restoring Rusty
Wow awesome work Greg! Block is looking mint.
Actually makes me appreciate the hot tank and wash box we had for the blocks and various parts haha only now id have to do it your way since we sold them
lkfldredneck is offline   Reply With Quote
Old 03-08-2016, 10:56 PM   #2881
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright, what do we get when we knock off the dirt and grime off a part?
that's right - Part Numbers!
Maybe Keith can chime in and decipher these hieroglyphs for us
Old 03-08-2016, 11:00 PM   #2882
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
you all remember that bubble bath we gave to those parts, well lets see how things turned out
hmm, not too shabby - I declare that Rattle Can Ready!
Old 03-08-2016, 11:13 PM   #2883
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Nice Greg!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-08-2016, 11:19 PM   #2884
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
Great place to check those numbers and verify what you have is mortec.com - LINK
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-08-2016, 11:19 PM   #2885
enaberif
Re: Restoring Rusty
3970010 is your standard 350 block with .010 amounts of nickel
The last picture on the pad behind the alternator is usually a partial VIN and casting code which will give you the date of when it was made.
enaberif is offline   Reply With Quote
Old 03-09-2016, 10:42 PM   #2886
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Gentlemen I just realized you have not been properly introduced to my old cylinder heads
so here they are, Passenger side first
if my hazel eyes do not deceive me I believe the part numbers are as follows
4 (no idea what that means)
882
33388? (2 I think)
L 143
and GM TPL 21-4 ? on the exhaust valve
Old 03-09-2016, 10:46 PM   #2887
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright lets see that old stock Passenger cylinder head already
hey they did their job for 41 years, thank you heads
Old 03-09-2016, 10:47 PM   #2888
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Cylinder Head
OK, lets see them numbers on the Dirver side Cylinder Head
2
882
333882
L 133
Old 03-09-2016, 10:50 PM   #2889
enaberif
Re: Restoring Rusty
There are two variations of the 882 heads... light and heavy castings. You sir have heavy casting 882s and while they are a crappy smog head they were the best of the two and usually didn't crack in the valve seat like the light castings versions.
Also did you clean those valves off? Because they look like they were either cooking coolant or you cleaned them up.
So Rusty had that going for him.
Old 03-09-2016, 10:57 PM   #2890
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and now for the Driver side Cylinder Head
I saw this quote on the InterWeb somewheres about these heads, it made me laugh
"882's are the "Best" of the worst heads."
Old 03-09-2016, 10:57 PM   #2891
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by enaberif View Post
there are two variations of the 882 heads... Light and heavy castings. You sir have heavy casting 882s and while they are a crappy smog head they were the best of the two and usually didn't crack in the valve seat like the light castings versions.
So rusty had that going for him.
saweet !!!
Old 03-09-2016, 11:01 PM   #2892
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
couple more things we learned from the autopsy
first the intake manifold was excellent very nice and thick part number 1256 I believe
however the head gaskets although metal, were paper thin, you can see where one failed around cylinder #1 or was close to failing
examining the heads closer there indeed was a bit of milky substance around cylinder #1, I said a little bit, ha ha
hey that's why we do what we do, know what I'm a sayin'?
Old 03-09-2016, 11:06 PM   #2893
enaberif
Re: Restoring Rusty
Those head gaskets are absolutely shot and were leaking. Stock OEM gaskets were metal shims that measured in around if I remember 0.010 thick so they seem extremely thin!
Old 03-09-2016, 11:09 PM   #2894
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
years ago my buddy "Harley" Bill, picture a 6' 8" skinny Colonel Sanders from Tennessee showed me how to do a valve leak test on my '83 Shovelhead (that be a Harley Davidson for the uninitiated) using gasoline
now you could do this using water, but water molecules be bigger than gasoline, so you may need to leave the liquid in the chambers longer while you have dinner, or even overnight, where as gasoline, gives you an almost immediate feedback
so we fill the spark plug holes with [ahem] spark plugs, and flip them rascals upside down, and level them with a socket of approximate height
I like to put clean cardboard or a paper grocery bag underneath for better visability of any dripage or leakage
as you can see our old heads looked tight, if there was a problem with a valve sealing you would know right quick
Old 03-09-2016, 11:13 PM   #2895
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
that's what I'm talkin' about, parts, parts, parts
20 New Old Stock push rods showed up, GM part number 14095256 cost $147.56, with just the right amount of surface rust, ha ha, but hey that's why they sell steel wool right? Yes I did say 20, I had to buy one lot of 8 and one of 12, oh well we got extras.
also got me some of them nice orange GM valve cover gaskets, GM part number 10046089 score for $26.56
Old 03-09-2016, 11:16 PM   #2896
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
That cleaned up real nice. Good work Greg.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-09-2016, 11:19 PM   #2897
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Christmas in March! Nice, more parts
27 hydraulic lifters showed up GM part number 5232720, also New Old Stock off of eBay, yes we got extras.
Cost $95.00
Old 03-09-2016, 11:19 PM   #2898
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thank you bud, TON OF WORK!
Fun Level = 2
Old 03-09-2016, 11:31 PM   #2899
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Truckaholics
I must tell you that I have been stock piling some parts over the last few months that I intentionally did not share with you all since I was not ready to work on them, but now it is time, so here is the Vortec Dual Plane Intake Manifold GM part number 12464340 I bought on eBay for $127.50, but the extra $40 for shipping stung a little, so total $167.50
Old 03-09-2016, 11:41 PM   #2900
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Vortec Cylinder Heads
Here are the gorgeous Vortec iron heads GM part number 12558062 I scored from the junk yard for a total of $88.00 yes that was for the pair of them. I think it was 50% OFF all engine parts that weekend at the local Pick N Pull. But I did have to go to four yards to finally find a set on the last vehicle I looked at, a 1999 Suburban, and I almost died of heat stroke that day. Things I do for you guys! JK
~ Hey me, it's me from the future, it's two years later (9/22/2018) and I gotta tell you these heads did not turn out, they were both cracked, warning to all you ambitious junk yard pullers out there, I do not recommend hunting for used Vortec cylinder heads, I pulled 5 pairs, and all were cracked! ~
