07-18-2018, 12:13 PM | #2951 |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
07-18-2018, 12:28 PM | #2952 |
Re: PO has me PO'd
I’ll be home Friday and get one of mine out will see what it is .....memory says pan head philips
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
07-18-2018, 02:09 PM | #2953 |
Equal opportunity joke ofender
Re: PO has me PO'd
Jim
They are 1/4" pan head sheet metal screws 1/2" long. Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
07-18-2018, 08:33 PM | #2954 |
Re: PO has me PO'd
good answers guys, good thing i didn't try to thread that 1/4-20 in. Now on the hunt for screws. OK, found some, at least I have a sample.
Thanks for the direction and time Guys. May have to post up a WTB in the classifieds or Fastenal good memory Jess
07-18-2018, 08:42 PM | #2955 |
Re: PO has me PO'd
Jim
I have a few extras if you need 2. Pm me your address and I will get them out tomorrow Richard
07-18-2018, 08:46 PM | #2956 |
Re: PO has me PO'd
Not sure as the bracket has welded nuts on it, that would mount the bracket thru dash, these may be machine screws
[url=https://flic.kr/p/29cyP9J]20180718_204220
07-18-2018, 08:51 PM | #2957 |
Re: PO has me PO'd
Correct two of them that go thru the dash panel should be 1/4 20 and the two that are not threaded will be what I posted above.
Let me go get a picture of the complete unit
07-18-2018, 08:57 PM | #2958 |
Re: PO has me PO'd
here are a couple pictures
07-19-2018, 09:19 AM | #2959 |
Re: PO has me PO'd
[url=https://flic.kr/p/29hCAZK]20180719_091541
Thanks Richard for the offer of parts over the years, you have been a great help. bolts and screws should be here, but it's been 20 years since I took it apart Chased the threads, and 1/4-20 seems to work. Of course, the PO used the wrong screw driver and screwed up the head Found 1 screw, may have to hit you up for 1 screw
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-19-2018 at 09:43 AM. |
07-19-2018, 12:12 PM | #2960 |
Re: PO has me PO'd
07-19-2018, 01:19 PM | #2961 |
Re: PO has me PO'd
08-06-2018, 11:58 AM | #2962 |
Re: PO has me PO'd
[url=https://flic.kr/p/L7au3p]20180806_113815
[url=https://flic.kr/p/28LEqVW]20180806_113844 Started to work on the FAST harnesses again, while some of the leads need to be used, not all of the XIM, the harness leads for the XFI are used while some of the XIM are duplicated( such as the MAP), but there may be more, as I hook this up 1 of the leads that are coming out of the XFI harness is for the crank sensor, that I won't be using, was told by FAST to just ignore or cut off, since my XIM harness has the leads for crank and cam sensors from my EFI parts, I've changed the connections so I can plug in directly to the 2 sensors Now to hole saw(1 1/4") into my firewall, going to slice grommet and super glue back together, don't feel like depinning all the connecters to get it through grommet Connections I am working on now; DS and PS coil driver Cam/ hall effects Cam and Crank sensors ground(-)
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-06-2018 at 12:21 PM. |
09-21-2018, 08:59 PM | #2963 |
Re: PO has me PO'd
With all the time and effort you're spending on this, that harness from FAST is cheap looking. Consider replacing that convoluted tubing with some braided sleeving from Wirecare Just a thought.
09-22-2018, 09:21 AM | #2964 |
Re: PO has me PO'd
AJ, I agree with you 100%, but this was my last attempt to resolve the issue
[url=https://flic.kr/p/FPtFum]20180131_093349 Needless to say, after two new harness's, I'm taking baby steps.... I have the wrap you are referring too Post #2901 was a debacle
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-22-2018 at 09:26 AM. |
10-06-2018, 10:00 AM | #2965 |
Re: PO has me PO'd
Milestone of sorts....Shifter cart is running, will post up pics as soon as I can get them off of my Iphone, maybe some track time before winter flys
10-22-2018, 11:50 AM | #2966 |
Re: PO has me PO'd
[url=https://flic.kr/p/2ceMUgf]20181022_104141
[url=https://flic.kr/p/2cjgM5a]20181022_101915 [url=https://flic.kr/p/2aVwsqX]20181022_101709[
10-22-2018, 11:55 AM | #2967 |
Re: PO has me PO'd
Jim
You got way more patience than I do. Looks like you moving right along though Richard
10-22-2018, 01:31 PM | #2968 |
Re: PO has me PO'd
[url=https://flic.kr/p/2bdwtRu]20181022_132509
This pic shows where to insert tool, locking tab is at 12 o'clock, but only have insert about 1/8" to engage lock, then rock tool up and down. then install tool at 6 o'clock to remove wire
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-22-2018 at 04:16 PM. |
10-22-2018, 01:35 PM | #2969 | |
Re: PO has me PO'd
This the beginning of my build season Have to go back and edit the pics for slplanng
10-25-2018, 12:14 PM | #2970 |
Re: PO has me PO'd
[url=https://flic.kr/p/29zRZJo]20181023_105308[
[url=https://flic.kr/p/2b1rGjZ]20181025_094122 The tape wants to roll, memory. Found this gold plated tool in her toolbox( she passsed several months ago). A note hand written by her said "tools go to Jim" and her retirement clock. tools were gold plated when she retired from CPPC. She was the only woman in the engineering dept.. And her job was to repair broken wires the size of your hair. Company built guidance controls for the Apollo moon shot [url=https://flic.kr/p/2b1sL5H]20181025_095736
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-25-2018 at 12:31 PM. |
10-28-2018, 09:45 AM | #2971 |
Re: PO has me PO'd
[url=https://flic.kr/p/QjdAd1]20181027_115106
[url=https://flic.kr/p/2bm2Ak1]20181027_121149 [url=https://flic.kr/p/2bm14X9]20181027_115223
10-29-2018, 05:22 PM | #2972 |
Re: PO has me PO'd
Date coded '67
[url=https://flic.kr/p/2cv93Sx]20181029_120152 Now I have to find some red and clear lenses
11-01-2018, 02:17 PM | #2973 |
Re: PO has me PO'd
Cam/ Hall effect
[url=https://flic.kr/p/2cv6UWh]20181101_133758 [url=https://flic.kr/p/2bbLmP8]20181101_133725 [url=https://flic.kr/p/NPizUg]20181101_132518
11-02-2018, 05:18 PM | #2974 |
Re: PO has me PO'd
This is where it can be confusing, as the connectors look the same, but, there is a notch on the left one at the top and will not let them connect
I use my hemastats to keep the locking tabs from reengaging as you pry off on side [url=https://flic.kr/p/2cAMx5k]20181102_113902 [url=https://flic.kr/p/2bd3ceZ]20181102_120842 you can see better the notch I am referring to in this pic These are the cam and crank senser connectors Started to install some of the wire care wrap, but didn't use tape to finish yet. I guess AJ was right, doesn't look as cheap
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-03-2018 at 08:49 AM. |
11-02-2018, 07:22 PM | #2975 |
Re: PO has me PO'd
You know it!
