Old 12-03-2008, 07:24 PM   #276
Kiamichi Kid
Kiamichi Kid's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
Very cool build. Are the guages going to be retro?
1969 CST-10 Stepside
1971 C-10 Short Fleetside
1967 GMC 3/4 Suburban 4x4
1972 C-10 Longbed
Kiamichi Kid is offline   Reply With Quote
Old 12-04-2008, 02:15 AM   #277
gunkis84
gunkis84's Avatar
nice build
-68 SWB fleet.. currently 20/18" 402bb 700r4
Changing Daily
AKA PROJECT ROOKIE
http://67-72chevytrucks.com/vboard/s...d.php?t=314716
gunkis84 is offline   Reply With Quote
Old 12-04-2008, 04:48 PM   #278
71Hulk
The gauges cluster will be from a modern vehicle. Stay tuned!!
71Hulk is offline   Reply With Quote
Old 12-05-2008, 12:08 PM   #279
au03z71
au03z71's Avatar
You sir, exhibit some seriously meticulous craftsmanship. Very nice job!
au03z71 is offline   Reply With Quote
Old 01-04-2009, 08:00 PM   #280
68 short step
a little update on the hulk, we're trying to get thing a roller....so i got a fo*d 9" and im in the process of narrowing, rebuilding, and smoothing....its gonna be narrowed 8.5" from the stock 12 bolt, or 50" houseing end to houseing end....
anyways here are a few pics
68 short step is offline   Reply With Quote
Old 01-04-2009, 10:55 PM   #281
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-05-2009, 12:04 AM   #282
nuke1
nuke1's Avatar
are you personally gonna shorten the rear diff, if so, what a re you gonna do about making sure the diff is strait after welding?
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-05-2009, 02:00 AM   #283
VA72C10
VA72C10
VA72C10's Avatar
Wow, looks great so far....will love to follow along on this one...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-05-2009, 07:21 PM   #284
68 short step
yes, it will be jigged up....basically a solid peice of round bar, thats perfectly streight, and 2 'pucks' that slide over the bar and into the bearing hole in the axle housings ends....if this doesnt make sense dont worry it will when i post the pics of the process...
Old 01-07-2009, 01:58 AM   #285
Blitz
Mr. Thread Killer
You ready to tell us yet?
Blitz is offline   Reply With Quote
Old 01-09-2009, 06:53 PM   #286
ChevyChad
Post pics of the new tunnel! It looks killer
ChevyChad is offline   Reply With Quote
Old 01-09-2009, 10:00 PM   #287
71Hulk
yea tell em...we need sumthin interesting for a change!!!
Old 01-11-2009, 12:26 AM   #288
tk-mpl
tk-mpl's Avatar
Don, when you make your engine harness and when you are shortening your wires do you solder and heat shrink them. Do you solder the O2 sensor wires. I was told today that you should not solder O2 sensor wires for some reason. If that is the case I am going to have to redo mine. Just wanted your opinon on that.
Thanx.
tk-mpl is offline   Reply With Quote
Old 01-11-2009, 10:17 AM   #289
68 short step
Thanx.
when i make a harness, i buy the PCM pins, and then i shorten the wire and crimp the new pin on.... i take great care as to not have any brakes in the wire, i.e. no soldering, no butt crimp, just one sinlge wire with the proper termination (pins) on both ends......there are cases where i have to splice wires together, and in this case i solder the wires and then use a solder sleeve over that, then sometimes heat shrink over that.....in the rare event i have to lengthen a wire, i use the same method.....as for lengthing or shortening your o2 wires useing the solder method, you should be fine with that, if your soldering points are good... the only sensor i know of that the wire length is accounted for in the proper reading is a thermocouple, in messing with those you never lengthen or shorten them...
Old 01-11-2009, 11:22 AM   #290
gringoloco
A guy with a truck
gringoloco's Avatar
68SS- What are you using to crimp the pins? Is there a special tool?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-11-2009, 11:29 AM   #291
68 short step
yes, its called a weatherpack crimper...
Old 01-11-2009, 01:50 PM   #292
tk-mpl
tk-mpl's Avatar
I knew that you shouldn't solder the wires from the connector to the sensor, but the harness wiring?? I hope it will be fine it is already done and in the truck- wish me luck.. I probably should have repinned it, but figured this was easier and cheaper..
Thanx
Old 01-11-2009, 06:37 PM   #293
Blitz
Mr. Thread Killer
I hate thermocouples! Of course the only exposure I've had to them is changing/troubleshooting them on a C-130. Not sure how they would relate elsewhere. Off topic I know.
Anyway, do we get a shot/hint of those gauges you spoke of?
Old 01-11-2009, 07:29 PM   #294
71Hulk
sure...as soon as we get em mocked up!
Old 01-12-2009, 09:54 PM   #295
68 short step
ok....the last trans tunnel i made was fine with my mock-up cab mounts (2x4)..i had four 2x4 wood blocks i was useing for the cab mounts at the time i made the tunnel, but when i put the real bushings in, only the rear were the same thinkness as the 2x4... the front was not as thick, thus lowering the cab and trans tunnel....so my .5" clearance between the trans and tunnel went to touching each other........oooooooopppppppsssssssssss, i even knew better so i cut it out and made another one, and this one flows better with everything else( like the dash) altho i know it'll be completely covered, least it looks good now
Old 01-12-2009, 10:04 PM   #296
68 short step
also got the parts to buildup the third member of the ford 9" going in....it has a eaton locker, richmomnd 3.70 gears, and of coarse new bearings.....sandblasted and painted the thirdmember too
Old 01-12-2009, 10:18 PM   #297
my67chevytruck
Under Construction
keep at it Don... looking good...
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-20-2009, 09:20 PM   #298
68 short step
got the rear end narrowed to 50", also centered the pinion....i didnt narrow it as planned, because the jig i planned on useing wasnt available. so i farmed it out. also ordered some universal axle perches for these trailing arm trucks....i had to torch out the half circles to fit around the axle tubes... got the rear end centered up, set the pinion angle,then welded the perches on...
Old 01-20-2009, 09:41 PM   #299
killer71
killer71's Avatar
Couple o' questions...
1) will u guys go w/ a bigger axel notch?
2) what's up with that members only emblem?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 01-20-2009, 09:49 PM   #300
68 short step
on the notch, yes, we're more then likely gonna have to go with a bigger notch, for that sweet stance we want, while keeping it streetable too....
also the members only sign, is just that.if you dont know, you probley never will
