Old 07-27-2012, 08:33 AM   #276
smartass12
smartass12's Avatar
Re: "Made Bail"
Originally Posted by smartass12 View Post
rustspot (if u have the time) could you take three measurements for me. rear tire width, distance from outside rear tire edge to outside rear tire edge, and distance from inside rear tire edge to inside rear tire edge. Reason i need these measurements are i dont think my rear suspension setup is the same as your and i need to see if i can lay frame (with your rear end/wheel setup) without any binding/rubbing on the rear suspension components. Thanks again in advance if you are able to find the time.
The truck is coming along great..Frame looks like you can eat off it.. Thanks again for getting me the above measurements, at your leisure ( i know you have a ton of stuff on your plate)
My 67 stepside build
http://67-72chevytrucks.com/vboard/s...d.php?t=522760
smartass12 is offline   Reply With Quote
Old 07-27-2012, 01:55 PM   #277
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Thanks for all the kind words guys. The frame could have used some bodywork but I rushed it a bit. It's nice but could have been ALOT nicer. At the end of the day this truck is not going to be for show but just a cool truck to cruise in. I will take it to shows but not pushing for any awards. This forum is my motivator so hopefully it will be together soon. I'll have the measurements by tomorrow evening and answer any other questions. Again thanks guys. I appreciate the fact you guys think this a cool build.
rustSpot is offline   Reply With Quote
Old 07-29-2012, 10:40 AM   #278
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Originally Posted by ajgriffin View Post
I know I'm late on this post, but can you tell me what you did in these pics? Is the trans tunnel all custom fab or did you modify a piece you purchased somewhere? What's the process like making one if you made it from scratch? Finally, what's the white stuff at the welded seams?
Trans tunnel came from Chris Alstons but had to be cut and trimmed to fit, thanks to Kris.The white stuff is seam sealer.
Old 07-29-2012, 10:43 AM   #279
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Found the tech article on the bed. I'll scan and post tonight. As for the measurements family duties called and have yet to get the chassis rolling. Close. Maybe by tonight.
Old 07-29-2012, 12:15 PM   #280
nastyc10
nastyc10's Avatar
Re: "Made Bail"
Looks good man, keep it up!
nastyc10 is offline   Reply With Quote
Old 07-29-2012, 10:47 PM   #281
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Man I can't believe I did it but I go home and realized I left the written down measurements at the shop. Send them tomorrow. Sorry. Did get them tho!
Old 07-29-2012, 11:39 PM   #282
Jimbabwe
Jimbabwe's Avatar
Re: "Made Bail"
Lookin' good!
Jimbabwe is offline   Reply With Quote
Old 07-30-2012, 09:38 AM   #283
smartass12
smartass12's Avatar
Re: "Made Bail"
No worries..I just hope i dont have to go a different route. Im sure ill know once i get the measurements...Also ,if you can recall, with your bed on did you have any room to go wider on your rear and still lay frame. The s10 rear wont work for me (will hit upper bag mounts) i feel like im trying to put a square block in a round hole...
Old 07-30-2012, 08:51 PM   #284
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Outside of tire to outside of tire 68 1/2". Inside of tire to inside of tire 46 1/2". Tire is about 11 1/4" wide. Hope this helps you figure it out. Let me know if you need any other measurements.
Old 07-30-2012, 08:53 PM   #285
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
My bad. 46 1/4" inside to inside.
Old 07-31-2012, 09:01 AM   #286
smartass12
smartass12's Avatar
Re: "Made Bail"
You are the best..Thank you for the measurements..I guess the only other one i would need would be, with the bed on, does the rear end have any room to move out and still lay frame? Obviously the bed wont be on for a bit so no rush just wondering if you remember off the top of your head. My rear suspention is fighting me every bit of the way..i was warned
Old 07-31-2012, 01:10 PM   #287
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
To lay frame is questionable. Lotta variables. Tire height, backspacing etc. Being this truck lays the rockers yes I would feel there is room to move out a bit to lay frame.
Old 07-31-2012, 01:12 PM   #288
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
If your running the same tire height as mine you'll possibly have maybe 1/2 to 1 inch of room towards the outside. Being the stepside fender rolls down its probably gonna be a trial and error situation. Once I have the bed on maybe I could get accurate on this.
Old 07-31-2012, 01:17 PM   #289
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Found a place for my truck to call home in the shop for the next couple weeks. Maybe I'll get it done this time.
Old 07-31-2012, 01:27 PM   #290
Tinkermc
Re: "Made Bail"
still watchin and still think you built 1 heck of a truck
Tinkermc is offline   Reply With Quote
Old 07-31-2012, 10:33 PM   #291
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Brian Vastine doin what he does
Old 07-31-2012, 10:34 PM   #292
jasonhall
jasonhall's Avatar
Re: "Made Bail"
Sweeeeet! Can't wait to see it at good guys
jasonhall is offline   Reply With Quote
Old 07-31-2012, 10:37 PM   #293
rustSpot
*NO REGRETS*
rustSpot's Avatar
Re: "Made Bail"
Thanks man! Alot of help from the guys at the shop. Much thanks to them.
Old 07-31-2012, 10:37 PM   #294
1stchevy
1stchevy's Avatar
Re: "Made Bail"
Looking good, love those wheels!
1stchevy is offline   Reply With Quote
Old 07-31-2012, 10:45 PM   #295
Jimbabwe
Jimbabwe's Avatar
Re: "Made Bail"
Looks great, Spot!
Did you find that tech article on the tailgate/bed mod?
Old 07-31-2012, 10:47 PM   #296
David67
David67's Avatar
Re: "Made Bail"
Looking sick
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 07-31-2012, 10:48 PM   #297
67cheby
67cheby
67cheby's Avatar
Re: "Made Bail"
Sweet !
67cheby is offline   Reply With Quote
Old 07-31-2012, 11:58 PM   #298
jwalk
What was I thinking?
jwalk's Avatar
Re: "Made Bail"
Nice!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 08-01-2012, 10:27 AM   #299
67cheby
67cheby
67cheby's Avatar
Re: "Made Bail"
is it light green ?
Old 08-02-2012, 11:05 PM   #300
65Pickup
65Pickup's Avatar
Re: "Made Bail"
What x member did you use, great truck.
65Pickup is offline   Reply With Quote
