07-02-2012, 05:16 PM | #276 |
Re: Yet another GMC build
Aluminum center and fiberglass surround. I always liked the look of an LT1 intake with the ribs so I had it ball milled.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
07-02-2012, 06:48 PM | #277 |
That's pretty cool but beyond my skills.
Kim |
07-02-2012, 08:45 PM | #278 |
That was my first time with fiberglass. It's not perfect but you have to start somewhere. I just made a "mold" with styrofoam board and cardboard, then wrapped it with saran wrap and glassed it. Then I peeled all the junk off the bottom when done. Then I used bondo on all the imperfections. I did the filter box the same way. I glassed a cardboard box then cut the filter hole and ripped out the box and saran wrap. I don't think it's beyond you at all! I've seen your metal work and if you were half as good at fiberglass it would be better than mine. My problem is that I get kind of good at everything but rarely REALLY good at anything. It's a curse...
07-03-2012, 12:13 AM | #279 |
I may have to give it a shot when I get to that part.
Kim |
07-03-2012, 06:02 PM | #280 |
Some hand polishing, new tires, and wheel center caps and it looks like a whole truck.
Put on the last two Bilsteins and drove it for 30 minutes over every pothole I could find (many in Oklahoma) and so far no bottoming out. I REALLY need to get those A/C parts though. 100+ degree weather here.
07-03-2012, 11:21 PM | #281 |
Looks real sharp.
Kim |
07-04-2012, 11:50 AM | #282 | |
looking good. fine tune your glassing skills and make the grill/opening in the hood your air intake
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-13-2012, 11:33 PM | #283 |
Wow and wow
I'm not tail-gating, I'm drafting. http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
07-14-2012, 02:45 AM | #284 |
PROJECT 7DEUCE
Truck turned out great.... Congrats....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-14-2012, 04:13 AM | #285 |
v v nice truck !
08-19-2012, 07:51 PM | #286 |
Trying to get the Vintage Air in the truck but I seriously miscalculated how the top vents were going to fit. I couldn't get the duct hoses hooked up because
1. too close to the dash top and 2. right in the middle of the wiper linkage. I have to move my controls from the bottom to the top but the dash is already painted and cut. Answer: thank goodness for my connections with a great machinist! I had a stainless cover plate made to match my gauge panel and it covers the vent holes perfectly. Now I have to buy another vent that will fit my pod underneath.
08-19-2012, 08:21 PM | #287 |
That came out nice.
Kim |
08-20-2012, 04:52 AM | #288 |
good recovery and it looks planned
the irony of a unit named compac, it's a big pig but you will be happy with the way it cools
08-20-2012, 10:19 AM | #289 |
Nice save !!
So where are the center vents now? I have two extra holes in the firewall of my green truck, about 3 inches from the two that hold the evap. to the firewall !!! I hope you tilted it a bit to the right to empty the condensate out of the case, this time of year there is a bunch !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
08-20-2012, 04:50 PM | #290 | |
08-20-2012, 06:49 PM | #291 |
OKGMC4, Looks very Cool!!
Harvey 1957 Chevy Stepside 1958 GMC Fleetside C4 project build thread: http://67-72chevytrucks.com/vboard/s...65#post5510465 |
08-20-2012, 07:10 PM | #292 |
ToTM Winner
Very Nice Lookin Truck!
ToTM Winner |
08-20-2012, 07:27 PM | #293 |
not sure what your doing for kick panels
but i stuck one in the pass kick works well for the passenger i also stuck one under the dash just out of sight above the drivers feet
08-20-2012, 09:32 PM | #294 |
Thanks guys. The closer it gets the more impatient I get.
I built the kicks with the vents in the hinge pocket. Just enough room to get a hose in there and pull it up into the dash.
08-20-2012, 09:37 PM | #295 |
6>8 Plugless........
Very nice work on that save! I have also ran to issues like that with some tight dashes and it can be a real pain!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-22-2012, 08:34 AM | #296 |
Frequent Flyer
I checked your truck out at Fuddruckers last night... VERY nice truck!
08-22-2012, 04:26 PM | #297 |
Thanks a bunch. Wish mine was as polished and "finished" as yours. Still trying to work out the minor things so I can move on to fine details. I know my underhood area will NEVER be as nice as yours!
08-25-2012, 02:58 AM | #298 |
Got some bed bling. Mostly wanted storage space. Don't want to scratch up the bed. (Not all of us can have a trunk in our truck, Ogre.)
08-25-2012, 03:02 AM | #299 |
Got my center vent in and everything seems to be working. Now I just need help charging the a/c. Have to admit the Vintage Air compac unit blows harder than I expected and it's as quiet as a factory unit. So far pleased with VA quality.
08-28-2012, 06:55 PM | #300 |
My brother in law took a ton of pics of the truck with his super fancy awesome camera. I have to admit, I can really tell the difference between a proffesional camera and my $100 digital. The orange seems to pop a lot better. Thought I'd share a couple.
