Old 10-05-2010, 09:56 PM   #276
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Dang it.............was going to try it. The other option is to spin pump in clamp so it faces the right way.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 10-05-2010, 10:02 PM   #277
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
honestly I don't remember which filter you bought...some wouldn't matter...others would.
which side does your fuel line go down? Is that the same side as the feeds for the Holley or no?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-05-2010, 11:17 PM   #278
85burb
85burb's Avatar
The lines go down passenger side frame rail. The holly fuel line is also on that side. I will prob just turn it in its clamp. The pump i got is a holly branded as a summit. You can see it behind the gauge in the pic.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-06-2010, 10:55 AM   #279
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by 85burb View Post
Can they be mounted upside down? Thoght about that but i will be putting it in befor the motor.
Depends upon the pump design. It should say how it can be mounted in the instructions. Call their tech department if it is not.
It really needs to be mounted below the fuel level of the tank. Most electric pumps do not pull well at all and you may have a hard time getting it to prime if it is mounted too high. They really need the gravity feed to get the fuel to them. The closer to the tank the better too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-06-2010, 09:10 PM   #280
85burb
85burb's Avatar
Well deal with hot cam fell therw. What do yall think of this cam?
HT1 SDPC LSX Truck Cam
214/218 .555/.562 111lsa
VS this one
Gm Hot Cam
I: 219 E: 228 I: 525 E: 525 112lsa
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-06-2010, 10:06 PM   #281
68GMCCustom
mild duration with more lift. should make good power down low.
more lift....you'd definitely need better springs..and maybe p-rods
Kurt -
Old 10-06-2010, 10:14 PM   #282
85burb
85burb's Avatar
How you think it will idle? I will be getting LS6 springs they have a max lift of .570. They should work right?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-06-2010, 10:22 PM   #283
68GMCCustom
as long as they meet the spring pressure requirememnts...so many lbs seat pressure and so much when open. You'd think with a 111LSA it would have some lope...
Kurt -
Old 10-06-2010, 10:46 PM   #284
85burb
85burb's Avatar
The cam opens to 562 and the springs max lift is 570. I guess they match
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-07-2010, 10:13 AM   #285
85burb
85burb's Avatar
Just ordered the bigger cam and bedtter springs then i was looking at getting. SD alos told me that it would be a wast of money to change the lifters sence they are roller lifters. So i did not order them. Also found out that brp makes swap headers for my truck but they are from 500-660. So i will be ordering me a set of Fbody headers maybe today.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-07-2010, 03:49 PM   #286
85burb
85burb's Avatar
Put order in for my f body headers too. 210 shipped to me for stailes steel with hardware. Now just need set of maniflods for back up.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-09-2010, 03:43 PM   #287
85burb
85burb's Avatar
Got cam and springs in mail today. Only took two days to get here. Am very impressed.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-09-2010, 07:46 PM   #288
85burb
85burb's Avatar
Well i went and tryed to put my cam in but did not get to far. Took oil pan off and took bolt out of the balancer. Then tryed to get it off. Did not have a puller so i did not get too far with that. Will go get one tomarrow. Got spring compressor today tho and thread locker and assembly lube today.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-09-2010, 11:32 PM   #289
68GMCCustom
so what are the specs?
Kurt -
Old 10-10-2010, 10:18 AM   #290
85burb
85burb's Avatar
The springs are good to .600 lift. A little higer presure then the .570 springs i was looking at. The duration on the cam is a little less then the GM hot cam. But they said it is a much better cam. Was even cheaper. But the springs were of corse twice as much as the other springs.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-10-2010, 12:31 PM   #291
68GMCCustom
but I would feel better with .600 springs then the .570's. The .570's would be too close to the cam lift max for me....like .015/.008 vs .045/.038? I don't think they would have last as long as the PAC springs?
Kurt -
Old 10-10-2010, 05:22 PM   #292
85burb
85burb's Avatar
Well got the cam and springs installed today. Had to rent 3 jaw puller to get balancer off. After i fought that and won for a few mins everything went smooth. Was very scared for a min tho. Motor did not want to turn over at all. But i turned it back and forth a few times it came loose. After i got the cam and springs in i truned it over like 20 slow revs with the plugs out. Did not make any expensive noise or have any tight spots. The top of the valves did not even look like they were worn at all. The cam spun freely and all the pushrod ends looked great. Have to go back next week and check the rod lenght. Then i will back all the rockers off tell i get ready to install the motor. I have decided not to remove the heads. If there would have ben a thight spot after turning it over by hand few times i would have pulled them. Will spray some penetrating oil in cylinders next week and turn it over more just to make sure everthing is some what lubed.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-10-2010, 05:28 PM   #293
85burb
85burb's Avatar
I went with the PAC springs as you can see. I did not want to feel bad when i got into higher rpm range. The pac ones have more pressure also. They are like .250 taller then old ones. I guess that is why they have more seat pressure? I know they are harder to compress then stock ones. Was a bit scared of my 20 doller spring compressor there for the first few springs.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-13-2010, 07:49 PM   #294
85burb
85burb's Avatar
Well i got my headers in today. I have to say they look better then i was expecting for 170. They have very thick flange and welds look pretty good. Next time i see my engine i will bolt them up with the intake and take pretend finished photo.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-13-2010, 10:43 PM   #295
GasBurner
So very nice.
GasBurner is offline   Reply With Quote
Old 10-16-2010, 08:03 PM   #296
85burb
85burb's Avatar
Went to storage to put headers in there and i set the intake and manifolds on for a test fit. Looks about done. Wish i could just put the sucker in and drive it already. The wait is killing me. I am sure it will pay off tho. What yall think?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-16-2010, 10:05 PM   #297
68GMCCustom
Looks nice...but the way the drivers side of those 4th gen f-body headers kicks out bugs me. Did you need the smog hookups?
Kurt -
Old 10-16-2010, 10:31 PM   #298
85burb
85burb's Avatar
No but the place that sells the headers does not sell them with out the tubes. The 6.0 does not have any smog or egr. Still trying to figure that one out my self. Intake has no hole for egr from the factory. I hope they work in my burb.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-16-2010, 11:46 PM   #299
68GMCCustom
then you'll need to cap off those three inlets?
Kurt -
Old 10-17-2010, 12:28 AM   #300
85burb
85burb's Avatar
Ya. That is the only bad part. Found kit to block them off for like 30 bucks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
