Closed Thread
Old 06-05-2010, 04:53 PM   #276
DangerBoy
Re: What did you do to your truck today!
Finished painting my one good fender and cowl. If everything goes well I'll have her back on the road within 2 months.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline
Old 06-05-2010, 05:35 PM   #277
Marc33
Marc33's Avatar
cut out old exhaust and installed new motor mount brackets for the big block that is going in next week.
Current stable:
1970 K5 Blazer 4x4
1972 K5 Blazer 4x4
SOLD:
1971 GMC Sierra Grande 2500 2wd
1972 Chevrolet K5 Blazer
1966 Chevrolet C20
1972 Chevy Suburban 4x4 1500
1956 Chevy 150 2 door post
1956 Chevy 2 door post bel air
1968 Chevrolet C20
1958 Ford Thunderbird
1968 4x4 Suburban 1/2 ton
Marc33 is offline
Old 06-05-2010, 05:50 PM   #278
big_al_71
big_al_71's Avatar
Clean the hell out of my engine compartment because I was going to a cruise and the rain canceled my plans...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 06-05-2010, 07:49 PM   #279
kevmic28
kevmic28's Avatar
I drove 6 hours round trip to pick up a set of doors with windows that are a hell of a lot better than the ones on my truck now for 100 bucks plus 60 in gas.
Not too bad a deal, would have been better if I had ac in the truck or it hadnt hit 100 degrees today.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline
Old 06-05-2010, 08:24 PM   #280
Yooper truck
Yooper truck's Avatar
Worked on getting wood boards for the bed cut to size and holes drilled in all the right places. The off-center washers were a bit challenging.
Yooper truck is offline
Old 06-05-2010, 08:28 PM   #281
CUSHE63
CUSHE63's Avatar
Baked it for 2 hrs at 165 degrees.
Steve
CUSHE63 is offline
Old 06-05-2010, 10:21 PM   #282
rick0312
rick0312's Avatar
layed some paint down earlier in the week and started to put things back together. even bought a nice shinny air filter. getting close!
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline
Old 06-05-2010, 10:38 PM   #283
rondog4416
rondog4416's Avatar
installed billit glove box door cover today
rondog4416 is offline
Old 06-05-2010, 10:43 PM   #284
Number98
Prestige Worldwide
Number98's Avatar
Originally Posted by vectorit View Post
Waxed the roof the the burb.
That much surface area!
Probably took two days at least...
Number98 is offline
Old 06-05-2010, 11:03 PM   #285
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I pulled the motor and trans yesterday...front crossmember and suspension, trans crossmember, e-brake lines, and drained the gas tank today. Boy that turned into a mess. I had the gas line pluged from where I pulled the motor. So I put a 2.5gal. gas can under it, take off the plug and a little gas flows and it stops. I think to myself...well it was almost on E when I pulled it in...and I've pulled it out and in several times since then so maybe its empty? I decide to just leave the hose plugged into the tank for a while and shortly after closed the garage, went inside, cleaned up, and layed down for a 2 hour nap.
My wife wakes me up....2.5hrs later (oversplept) screaming about the house smelling like gas. I stumble around trying to wake up (hard to do when your on pain meds) and finally make it out the back door to the strong smell of gas. I decide its not bad enough to blow up, and hit the garage door button. I get over to the truck and the gas can is full, and so is the large piece of cardboard its sitting on...along with a puddle, and a soaked concrete felt (whatever its called) between the driveway and garage pads. Obviously...the line started draining again and the 2.5 gal. gas can was not quite big enough. After I stopped the flow and finally got everything cleaned up I put another small can ander it...and it drained less the a half gal.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 06-06-2010, 05:48 PM   #286
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Installed a tilt column & a Grant wheel.
I haven’t installed the indicator yet in the photo - it's going to get a 327/700R4 this summer & that part will be hooked up then.
I haven’t driven it yet, but I'm thinking I am going to have to push the column towards the dash as well.
WOW does this wheel feel small after using the factory wheel for so long!
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline
Old 06-06-2010, 06:03 PM   #287
vectorit
What?
vectorit's Avatar
Added new seat belts
Rebuilt the kick panel vents
Worked on getting the timing just right - still not there...
Took her for a cruise
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-06-2010, 06:06 PM   #288
rhamlin
Replaced a broken wheel lug on the front
Ordered a new set of brake shoes.
Installed a temporary horn button.
Tomorrow, re-inspection for safety !
Rob Hamlin
rhamlin is offline
Old 06-06-2010, 06:16 PM   #289
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Thursday I took the Blazer on its first road trip of about 3 miles to the glass shop to get the windshield put in. Friday he still had it cause it wouldn't fit!! Now he's going to pull it tomorrow and grind it down to make it fit.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline
Old 06-06-2010, 09:04 PM   #290
Pont406
Put a motor in and clearenced rad support. Still need to run fuel lines, installed rad and trans cooler. Maybe swith over to cable linkage. Blower will go on last.
Pont406 is offline
Old 06-06-2010, 11:29 PM   #291
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Been Putting Truck Back After Getting Back from Body Shop Got Grill and put New taillight assy Ran New Wires From The Front an NOS Headlight Switch Turn Signal Switch.... Go To Mother in Laws 3 Blocks And Get Pulled Over Buy Los Angeles Finest Asks Me If i am On Probation Or A X Con O DAm i Got Pissed And Told The SOB This is Profling, Tells Me he Pulled me over Cause i had No Light WTF Everthing Is New See i wasnt Afraid of him This Punk Ass Cop is Giveing me A Ticket For No light So I walk back to truck and turn lights on and Guess What they Work so i Am Talking More **** To Him His Supervisor Shows up To Explane... Whats there to Explane This Whole Stop "Is Bull**** I Ask HIm if i was Done And Walked Into Mother in Laws so iam Going Down And File A Coplant... They Just Want To Ck Out The New Paint
1971 GMC SHORTY is offline
Old 06-06-2010, 11:44 PM   #292
07SSSC
07SSSC's Avatar
I finished my fuel cell install yesterday and put the bed back on.
Coincedently, anyone ever have a brand new Summit cell leak around the fittings right out of the box?
Today I got most of the wiring done for my (on the cheap) electric fan setup, more info to come on that. Also cleaned up/tucked and retaped a lot of wiring, found a lovely twisted/soldered/duct taped and electrical taped mess at the battery for the wire running to the fuse block. My grandpa switched it to sidepost and had some "interesting" fixes to say the least. Gonna grab a new terminal tomorrow and redo it correctly.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 06-06-2010, 11:52 PM   #293
vectorit
What?
vectorit's Avatar
Got the timing issue corrected - Stupid mistake, had the vac adv connected to the wrong darn port on the carb...
Took my baby out for a long cruise out on the back roads as a test drive, and she is running like a top again! So stoked
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-07-2010, 01:57 AM   #294
frog trucker
frog trucker's Avatar
Location: Smack-dab in the middle of "The land of fruits and nuts", Sacramento, CA
I took care of a few more things the previous owner Mickey Moused. First, I replaced the “temporary rubber freeze plug” on the front of the engine. Next, the fan belt was too short, so I bought a longer belt, and while I was replacing it, I found out what was causing the strange noise I would hear when the truck was idling . . . one of the fan bolts was simply resting in the fan. The P/O used bolts that are too short, so they were threaded in only about two turns into the water pump and the one had stripped-out. I am thankful that nothing went into my radiator. Also, I replaced the METRIC bolt that the joker used to hold the alternator in place. I spent a few minutes wondering why the P/O used a 12-inch diameter steering wheel after he forgot to replace the P/S pump and hoses when he did the engine swap. My steering box is probably now junk because the inlet and outlet ports are full of dirt and debris.
frog trucker is offline
Old 06-07-2010, 04:50 AM   #295
SPIRIT OF 76 CHEVY
SPIRIT OF 76 CHEVY's Avatar
i look at it and then took it for a ride
Stan's short bed fleet
69 custom deluxe swb
69 custom swb shop truck
70 custom sport truck swb
72 GMC super custom swb
72 Custom/10 swb inline 6 auto p/s p/b
77 silverado swb
86 Buick Grand National
92 silverado sport swb
06 silverado crew cab
07 caddy sts
08 f250 4x4 crew cab Sold!!!
12 dodge ram 1500 big horn
SPIRIT OF 76 CHEVY is offline
Old 06-07-2010, 02:43 PM   #296
dabruce15
dabruce15's Avatar
Installed a late model steering wheel, even got the horn to work, and replaced the track bar and new bushings.
Beauty is in the eye of the beer-holder.
Praise the lowered!
dabruce15 is offline
Old 06-07-2010, 02:57 PM   #297
DorianB
DorianB's Avatar
Tried to pick up some used tires to last until I save up to get some new rims. Tires plus guy said the rubber that was on my truck was from 68, they had to come look since no one knnew what size 7.00 15LT was
DorianB is offline
Old 06-07-2010, 06:20 PM   #298
Marc33
Marc33's Avatar
didnt actually work on the truck, but picked up the new motor from the machine shop, and bought the headers, fuel pump and the carb. Dropped of trans to be built. Should be done on thursday.
This weekend, time to install the motor!!
Current stable:
1970 K5 Blazer 4x4
1972 K5 Blazer 4x4
SOLD:
1966 Chevrolet C20
1968 Chevrolet C20
Marc33 is offline
Old 06-07-2010, 06:43 PM   #299
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Installed rear tires, double checked for leaks (still leaks out behind the yoke). Centered the backend with the adjustable panhard bar. Dropped down and backed out of the garage just to drive it a little. I love the sound of open headers. Sucks that it leaks.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 06-07-2010, 06:47 PM   #300
Hart_Rod
Hart_Rod's Avatar
New shoes, .............
Hart_Rod is offline
Closed Thread
