Old 12-01-2016, 02:49 PM   #276
ACK
ACK's Avatar
Re: Post your Bed Wood/Metal - Customized/Modified or Stock
Originally Posted by Alberta65 View Post
maple plywood is all a man needs in life haha
The diamond plate looks sharp and I bet it's functional, too
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 12-01-2016, 03:54 PM   #277
coolfool_2
Here my '66.
coolfool_2 is offline   Reply With Quote
Old 12-22-2016, 01:14 PM   #278
lowslow64
lowslow64's Avatar
One piece of 3/4 cabinet grade plywood, that was split down the middle and covered in tiger stripe veneer. New stainless with the sliding adjustable bolts.
Bed was also raised 3" due to the lowering of the truck. Sides were sprayed with Raptor liner.
lowslow64 is offline   Reply With Quote
Old 12-22-2016, 01:35 PM   #279
Alberta65
Thanks, tried to keep it as functional as possible as this truck is nothing more than a bike hauler so I don't want to cry anytime someone throws something in the box
Alberta65 is offline   Reply With Quote
Old 12-22-2016, 09:13 PM   #280
corvettejim1968
corvettejim1968's Avatar
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 12-22-2016, 09:23 PM   #281
nsb29
nsb29's Avatar
looks good you have ben hard at it
nsb29 is offline   Reply With Quote
Old 12-23-2016, 11:24 AM   #282
Turtleman
Turtleman's Avatar
Nice Jim.. wanna come over and help me with mine?
Turtleman is offline   Reply With Quote
Old 12-23-2016, 07:45 PM   #283
corvettejim1968
Sure now that I know what I'm doing
Old 12-25-2016, 12:15 PM   #284
cioutlaw
Just finished getting my bed wood installed yesterday. Wood is Oak that has been lightly scorched.
cioutlaw is offline   Reply With Quote
Old 12-25-2016, 09:59 PM   #285
rvrfoot
rvrfoot is offline   Reply With Quote
Old 12-26-2016, 10:07 AM   #286
northern 85
northern 85's Avatar
cioutlaw ,nice touch i really like the look!
northern 85 is offline   Reply With Quote
Old 12-26-2016, 10:12 AM   #287
northern 85
Mar k oak ebony stain and boiled linseed oil.
Old 12-27-2016, 12:45 PM   #288
forestb
forestb's Avatar
I got bed rails for Christmas. Thought I would mock it up before I started bolting everything down. I took me half the day to drill holes in one angle strip cover and install it.
forestb is offline   Reply With Quote
Old 03-30-2017, 04:25 PM   #289
forestb
forestb's Avatar
finished it up
Old 02-04-2018, 01:03 AM   #290
cwcarpenter98
cwcarpenter98's Avatar
Went from steel plate over the wood to factory specs. My dad and I cut, routed, and stained the wood ourselves. Used the bed strips I had in the truck since they were still in good enough shape and got new bolts all around. Completed this part of the project over the summer, and not long after used it to snag a fridge for my dorm room. I added some tie down points since there weren't any down low from the factory.
All the info on this forum has helped me a ton since I bought the truck, thanks everyone.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-04-2018, 09:49 PM   #291
racecougar
racecougar's Avatar
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 02-04-2018, 10:12 PM   #292
vin63
It's Better With Nitro
vin63's Avatar
Flame burnish then red mahogany stain.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-05-2018, 06:48 PM   #293
Chevystep
Ipe...or Brazilian Walnut...Super hard, weathers to a grey if you don’t oil it. Has to be drilled when used as a deck material to put fasteners in it. Stuff is so hard and dense it don’t float. Found it in 3.5, 5.5 and 7.25 widths and it works in the original mounting holes, you do have to trim the 3.5 down a bit to tuck it under the two side strips so the holes show up. Adds a little more weight, but that should just give a better ride for our coil spring trucks. Buying the boards and routing the grooves for the strips myself was cheaper than all pre drilled oak kits I could find. And I hid the bed/frame bolts by inserting the bolts heads into the board’s underside with a forstner bit. Stacked head dado cutter on table saw, two passes for the strip insets...picts of a test board...
Chevystep is offline   Reply With Quote
Old 06-08-2018, 01:29 AM   #294
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by markeb01 View Post
I really like the look of the aluminum diamond plate with the polished skid strips. I could do that to mine without that much effort. My bed floor resides under a hard cover and is covered with "stuff" we take everywhere with us, so there isn't much point in making it prettier.
I saw you posted somewhere that you did aluminum diamond plate, but said would have rather used steel diamond plate because of needing more weight in the rear. I have steel diamond plate in mine and have been thinking I might rather have aluminum so to shed a little weight. Are you having handling issues with it being too light in the back?
66 C20 Service Truck:
Old 08-04-2018, 02:47 AM   #295
C-10 Norway
C-10 Norway's Avatar
Here's my shoptruck bed, just finished this week.
Walnut budget style.
I used spruce 3/4"x6" burnt the grain, two coats of Nescafé Brasero instant coffee , one coat of walnut stain topped of with three coats of varnish.
I think it turned out great for a budget bed floor.
Driver carries no cash. He's married.
'67 Chevrolet C10 SWB - 350 Vortec/TH700R4
Backyard Engineering
C-10 Norway is offline   Reply With Quote
Old 08-04-2018, 11:31 PM   #296
Captainfab
60-66 Nut
Looks good.....interesting use of coffee
Fredrikstad.....I like that town and I want to go back and spend more time there as well as some other places.
Old 08-06-2018, 10:44 AM   #297
wingnut62
Black walnut from our property.
wingnut62 is offline   Reply With Quote
