Old 12-08-2012, 03:57 AM   #276
maxxxy
maxxxy's Avatar
Re: maxxy's 81 bagged c10 build
Got a new present from AVS!!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 12-09-2012, 11:55 PM   #277
shoob
Originally Posted by maxxxy View Post
Okay its been a little while, I have half of an update. Lol I got my spindles in a day or two ago and I started to put them on. I got on the drivers side and realized I was hitting the bottom of my control arm way before anything else. So I did some trimming there. I ended up only getting about two inches of drop and now I think my upper ball joint is binding. But oh well. Lol*
here's the pics.
Pass side w/o drop spindles
Driver side with drop spindles
so....what was the original setup before you added the drop spindles?
shoob is offline   Reply With Quote
Old 12-10-2012, 12:15 AM   #278
shoob
Got my crossmember all welded up!! It's all welded then I ground down all the welds and it looks pretty good.*
The first picture is of some reinforcement I welded into the bottom to better support a jack.
im new to this as well...but wouldnt this make the engine sit higher? and in turn change the tail shaft angle on the trans?
Old 12-10-2012, 03:42 AM   #279
maxxxy
maxxxy's Avatar
Before drop spindles, I had bags, factory upper control arms, and like some old school recessed spring lower control arms the p.o. put on. they are basically like cupped lower control arms. (I later modified these) so it sits about an inch lower than factory setup w/bags.
Max
Max's bagged 81
Old 12-10-2012, 04:13 AM   #280
maxxxy
maxxxy's Avatar
The position/location of the motor doesn't move at all. The motor mounts attach to the upper face of the crossmember. Think of it like this, the section that is cut out stays bolted to the frame in factory position, and you move the entire suspension upwards around the cut out piece 1.25 inches, then weld back in place.
Its really hard for me to explain, unless you're just looking at it. I'm a very visual person(thus my picture-loaded thread) But all in all, the only thing that is in a new spot afterwards is the suspension and steering moved up 1.25".
Max
Max's bagged 81
Old 12-10-2012, 12:48 PM   #281
truckzilla
truckzilla's Avatar
I like that pressure gauge! Send us a picture when you've installed it, if you would!
truckzilla is offline   Reply With Quote
Old 12-10-2012, 03:42 PM   #282
king-918
king-918's Avatar
I'm jealous need to get back to work. Hope to see it in person one day. Keep it up!
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 12-11-2012, 01:59 AM   #283
shoob
thanks for the clarification, 100% clear now.
Old 12-19-2012, 11:50 PM   #284
mooseknuckles
mooseknuckles's Avatar
lookin good maxxxy
mooseknuckles is offline   Reply With Quote
Old 12-27-2012, 10:57 PM   #285
luifer76
luifer76's Avatar
any pics of the truck laid out bro?....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 12-28-2012, 12:37 AM   #286
maxxxy
maxxxy's Avatar
Originally Posted by mooseknuckles View Post
lookin good maxxxy
Thanks guys. Been hammering away little by little. Too many little things to list, but Heres some recent pictures from a week ago.
Max
Max's bagged 81
Old 12-28-2012, 06:02 AM   #287
bbbc10
Diggin The SquareLife
lookin bada$$
bbbc10 is offline   Reply With Quote
Old 12-28-2012, 01:24 PM   #288
luifer76
luifer76's Avatar
looks really good bro..... nice job.
Old 12-29-2012, 12:41 AM   #289
maxxxy
maxxxy's Avatar
Its been like 20 degrees outside in oklahoma the past couple days, and in a unheated barn, its pretty hard to get much work done. I did some research, and found out that the $80 4"x2"x1" air ride switch boxes, are the exact same as $3.85 "project boxes" from radio shack. I built one a tad bit bigger.
Max
Max's bagged 81
Old 12-29-2012, 12:10 PM   #290
luifer76
luifer76's Avatar
$3.85 "project boxes" from radio shack? are those momentary on/off switches? what does the $3.85 box from radio shack look like? i assume that the one your holding is the final product you built....
Old 12-29-2012, 12:11 PM   #291
luifer76
luifer76's Avatar
the one your holding on the pic looks good.....
Old 12-29-2012, 01:31 PM   #292
maxxxy
maxxxy's Avatar
Thanks man. That is the one I built.
I spent like $4 dollars and some change on that box, because it was slightly bigger than the 4x2x1. It comes in a blank box http://m.radioshack.com/radioshack/c...do?cid=1092675 . I already had the momentary switches.
Max
Max's bagged 81
Old 12-29-2012, 07:56 PM   #293
luifer76
luifer76's Avatar
cool thanks for the info i got some momentary switches too i may try building one myself.....
Old 12-29-2012, 09:04 PM   #294
baclay9
Lookin good Max. Glad you got to work on it a little. Shame it has been so cold lately though.
baclay9 is offline   Reply With Quote
Old 12-29-2012, 09:27 PM   #295
maxxxy
maxxxy's Avatar
I finally brought my motor home from my dads shop. I've been slowly working on it.
I figured its be more motivation to get it in if I have to look at it everyday.
Max
Max's bagged 81
Old 12-29-2012, 09:45 PM   #296
luifer76
luifer76's Avatar
wow that's nice bro....
Old 12-31-2012, 05:47 PM   #297
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
How long untill she is due back on the road?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-05-2013, 01:41 AM   #298
maxxxy
maxxxy's Avatar
Thanks man!
Not soon enough! It'll probably be mid summer, I go back to college next week and the truck wont get any action until then.
Pieced together a serpentine belt setup, now I'm looking for a local place to powder coat the pulleys for me.
Lots of little things coming together. The piddly parts really start to add up!
Hung my inner fenders and made a new battery bracket today. Theres a little surface rust lol.
Max
Max's bagged 81
Old 01-05-2013, 01:43 AM   #299
maxxxy
maxxxy's Avatar
Oh yeah 2 of my 6 valves crapped out on me completely. So thats more money that i have to spend...
Max
Max's bagged 81
Old 01-05-2013, 08:15 AM   #300
baclay9
Looking great max
1981, bagged, c10, custom, oklahoma
