10-20-2013, 12:22 PM | #276 |
6>8 Plugless........
Re: 72 K20 Cheyenne Super Build
Something along the lines of it's going to be a long time or hack it out yourself.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-20-2013, 01:01 PM | #277 |
yeah, that sounds about right...
10-20-2013, 11:25 PM | #278 | |
What size tires? wondering how big i can go and use the spare tire carrier?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-21-2013, 09:50 AM | #279 |
Carpe manana
Thanks!! Subscribed. The 33" tires work just fine in the spare carrier - I'll check clearance once my truck arrives in MT. Not sure if 35" would fit...
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
10-21-2013, 12:40 PM | #280 | |
To follow up after read the entire build: Can i assume that the reason to allow for ether forward mount or rear mount motor mounts in the frame is to allow for the front axle to clear the cross member on a 4X4? Can you look and tell me if when they mounted the bed did they use rectangular rubber 1/4" cushions between the bed and frame? if they did was 1/4" spacers required on the cab mounts and radiator support mounts? Sure wish i could take my truck to where you had the work done!
10-21-2013, 02:08 PM | #281 | |
Carpe manana
The asphalt/rubber spacers were not originally on this or the bed-donor truck (or my K10). I did add these however but kept OEM size cab/rad support cushions. All the body lines look good. Thanks for the good words!
10-21-2013, 06:43 PM | #282 |
The asphalt/rubber spacers were not originally on this or the bed-donor truck (or my K10). I did add these however but kept OEM size cab/rad support cushions. All the body lines look good.<<< Thats interesting, I got and installed my body mount kit and had to leave the bed pads out to get the body lines to match, so if i use them i'll need to use spacers on the cab...
10-22-2013, 07:40 AM | #283 | |
Deadhead.. Your truck is a piece of art! Killer! Hell of a job
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
10-22-2013, 10:50 AM | #284 |
Carpe manana
Not sure this makes a difference or not but the bed was mounted on the pads for a while and maybe settled a bit. Those I used were maybe a 1/4" thick. I went back and traced my lower woodgrain trim lines on the pics and they all seem to square well. My body mounts came from Wes Hepp at Classic Heartbeat - board member/vendor.
Thanks sboris!!
10-22-2013, 11:07 AM | #285 |
Junior Member
It turned out great!
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
10-22-2013, 12:41 PM | #286 |
LOL! So did mine, He's about 45-40 minutes away from me. Go figure.
11-24-2013, 07:18 PM | #287 |
Hey Pete,
Truck looks truly amazing! Better than new. Great Job! Can you post some info for converting your oil pressure gauge to electrical? Does it work well? What was the turn time to do this? Who did it? Thanks, |
11-24-2013, 11:25 PM | #288 |
Carpe manana
Thanks Steve! My K20 and K5 were FINALLY delivered here last Sunday. I've attached a local pic I was able to take this morning.
There's a world renowned gauge restoration shop in Albuquerque (MoMa Gauges) that's been in business for decades and typically works on high end restoration for old Ferrari's, MG's etc. It's run by an 80 yo woman! They did the gauge conversion. It was a little pricey at ~$175. What they do is preserve the face and needle then replace the inner mechanical "guts" of the gauge with electronic parts. A sending unit and wiring was included IIRC. They don't have a website but here's their contact info: MoMa Gauges 1321 2nd Street NW Albuquerque, NM 87102 Phone: (505) 766-6661 Don't waste an 80lb gauge like I did - they can use a 60 lb gauge and it will read like an 80. You absolutely cannot tell the oil gauge was converted when looking at it in the cab and its worked great for the 56 miles I have on the truck I had a ground come loose yesterday that I fixed last night but that was no big deal at all. It took them no more than 1.5 weeks and that was tearing into a restored speed warning cluster. No more oil line to deal with. Hope this helps! Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 11-24-2013 at 11:32 PM. |
11-24-2013, 11:28 PM | #289 |
Carpe manana
Getting snow on the mountains that ring the valley:
11-25-2013, 12:24 AM | #290 |
Its going well below freezing here at night too, snow in the mountains, been lucky for about a week with sunny weather in the 40's, but its not gonna last.
11-25-2013, 09:52 PM | #291 |
we've got snow on the mountains, and on my front yard! glad to hear the trucks made it Pete, how is life in the big sky country? hope all is well.
11-25-2013, 10:38 PM | #292 |
Carpe manana
Thanks Ryan! I'm having a great time up here! So far all well but I'll have to see what the winter has in store Will keep you posted. It's hard to start these old rides when it's 20 degrees - I've stocked up on starting fluid. Pete
11-26-2013, 01:00 AM | #293 | |
Vintage 4x4s
Diggin the scenery there for sure. One dream I have is to someday have a piece of land in MT.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
11-26-2013, 09:54 AM | #294 | |
Carpe manana
I did get my K20 carb rebuilt at SMI for ABQ's altitude, which is ~1500 ft higher than here in MT. I didn't go with the small body HEI but do have a regular GM HEI on board. My K5 is also a bear to start and since arriving will diesel a little bit when I turn it off - I'm thinking it may need the carb and timing tweaked.
11-26-2013, 11:39 AM | #295 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-26-2013, 09:17 PM | #296 |
Carpe manana
Thanks - it's great country up here. I haven't done anything with that blue 71 super GB door yet but have you in mind
11-26-2013, 09:33 PM | #297 |
Thanks......
12-03-2013, 12:32 AM | #298 |
Moderator
Pete,
Beautiful truck and amazing work. I love it! Richard
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
12-03-2013, 11:39 AM | #299 |
Carpe manana
Thanks Richard!
12-03-2013, 07:37 PM | #300 |
Pete,your truck is incredible.I hope to have one someday,half as nice as yours.Really,you have a very nice truck.I actually just picked up a 71 c30 car hauler,same color as your to your k20.Something about that color ! Cant wait to see this blazer of yours.Take care.Tom
