Old 12-16-2014, 12:07 AM   #276
CRGRS 66
CRGRS 66's Avatar
Re: Bringing the '65 back to life
Originally Posted by racecougar View Post
Thanks guys!
Lol. Half of it actually. We'll spend the other half in Punta Cana.
Nice, safe travels!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 12-17-2014, 04:59 PM   #277
66ChevyMax
66ChevyMax's Avatar
Just read through your build, nice work. I bet that painted cab is a sight for sore eyes after all that work you put into it.
Thanks for the firewall map, it's awesome!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 12-18-2014, 05:08 PM   #278
Monte's62
Congrats!!! Enjoy yourself, that trucks not going anywhere. Remember, you'll need that little ladies "advice" in your future endeavors with this truck, future trucks, and your racing interests as well. Never heard of Punta Cana, but it sounds nice.
Monte's62 is offline   Reply With Quote
Old 12-29-2014, 10:17 PM   #279
racecougar
racecougar's Avatar
Thanks everybody! We returned from the honeymoon early yesterday morning, and I made my way over to the shop today. Dad and I installed the lower control arms, pressed in the lower balljoints, and shot some paint on a bunch of small parts/hardware. If anyone has a good reference for front suspension torque specs, please post up a link. I'll be searching for that information in the morning.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-29-2014, 11:35 PM   #280
Mjminino
C10/C20-30
Upper ball joint 70 / 120
Lower ball joint 120 / 215
Tie rod ball joint nut 30 / 50
Tie rod clamp 132 in# / 132 in#
Idler arm mounting bolts 30 / 30
Idler arm to relay rod 60 / 60
Pitman Arm 60 / 60
Pitman arm to selector shaft 125 / 125
All values are in foot pounds unless noted.
Mjminino is offline   Reply With Quote
Old 12-29-2014, 11:48 PM   #281
racecougar
racecougar's Avatar
Thanks. Here are other specs I've located thus far: http://www.chuckschevytruckpages.com...que_specs.html
Old 12-30-2014, 04:46 PM   #282
racecougar
racecougar's Avatar
We installed the upper control arms today, then turned our attention to the spindles and springs. We'll be using a pair of CPP 2.5" drop spindles (the non-modular ones) and stock coils. We taped off the machined surfaces and stuck them in the blast cabinet to remove the as-delivered paint, then everything received a coat of primer.
Old 12-31-2014, 05:48 PM   #283
racecougar
racecougar's Avatar
Shot the front coils and spindles in hammered silver today (same paint as the interior of the cab).
Old 12-31-2014, 07:38 PM   #284
Mjminino
Looking good! I just had a tenant move into my other garage space. his monthly rent is going to fund my project
Old 01-02-2015, 08:14 PM   #285
racecougar
racecougar's Avatar
Nice!
We slapped the front suspension together today. We were hoping to stick a pair of Cragar S/S's that Dad bought back in the late-60's on it and set it on the ground, but they didn't clear the caliper mounting ears on the spindles. So, it'll continue to ride jackstands for a bit. You can actually see the old Polyglas bias-plys in the background.
I just set a caliper in place for a quick photo/visual. They'll stay on the shelf for now.
Old 01-02-2015, 11:18 PM   #286
Mjminino
I can't remember if you mentioned it or not, but do you habe part numbers for your caliper set up?
Old 01-02-2015, 11:21 PM   #287
racecougar
racecougar's Avatar
Those are just regular old Wilwood D52 calipers.
Old 01-03-2015, 09:15 AM   #288
clemdaddy
clemdaddy's Avatar
congrats on the wedding, looks like you got a sweetheart there.
kim and i laughed out loud when we saw the wedding cake...too funny.
keep that girl happy and your garage allowance will increase
clemdaddy is offline   Reply With Quote
Old 01-03-2015, 07:12 PM   #289
racecougar
racecougar's Avatar
Thanks clemdaddy!
Taking turns working on the trailing arms today.
Old 01-11-2015, 03:41 PM   #290
racecougar
racecougar's Avatar
Another day spent doing what I enjoy.
Old 01-17-2015, 08:34 PM   #291
racecougar
racecougar's Avatar
Getting there. It was nice having the shop doors open today in this 60* weather.
Old 01-18-2015, 06:43 PM   #292
racecougar
racecougar's Avatar
Holey moley! We set the mill up to compensate for the 0.5 degree taper, then bored six lightening holes into the first of the two trailing arms.
The holes will be sealed via 2-1/4" tubing, which slips snugly into place. I'll work on welding these up tomorrow.
Old 01-18-2015, 09:18 PM   #293
Ta2Don
Ta2Don's Avatar
Those Trailing Arms are gonna be Sick!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 01-19-2015, 03:11 PM   #294
racecougar
racecougar's Avatar
Thanks! I need to finish dressing the welds, but you get the picture.
Now to make another one.
Old 01-25-2015, 04:08 PM   #295
racecougar
racecougar's Avatar
And then there were two.
Old 01-25-2015, 04:10 PM   #296
Mjminino
Interesting
Old 01-31-2015, 03:14 PM   #297
racecougar
racecougar's Avatar
Managed to get this one smoothed out today before running out of supplies. The next step will be to blast the mill scale off and put it into primer. I just need to get the other one dressed first.
Old 01-31-2015, 09:04 PM   #298
dantimdad
dantimdad's Avatar
I would chrome those when you are done with them.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 02-02-2015, 07:39 AM   #299
Mjminino
^^^^^^I second that
Old 02-02-2015, 08:19 AM   #300
racecougar
racecougar's Avatar
That would be awesome, but I don't even want to ask what that would cost.
Smoothed out the welds on the second one yesterday. They're just about ready to blast and prime.
