Old 06-29-2014, 11:24 PM   #276
litew8
litew8's Avatar
Re: Project NiteMare-1970 C10 LWB build
Sits nice. Always entertaining to see before and after side-by-side
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 06-30-2014, 01:02 AM   #277
swamp rat
swamp rat's Avatar
Now ya just got to get it out of the garage and on the road, is the interior still gutted? engine? I came into the build later on so didn't read everything.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-30-2014, 02:19 AM   #278
Bomp
Bomp's Avatar
Truck is looking great.
Bomp is offline   Reply With Quote
Old 07-02-2014, 12:27 PM   #279
70blackfish
have you driven it yet?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 07-02-2014, 02:22 PM   #280
Molberg
Molberg's Avatar
Thanks guys.... Haven't even fired the engine yet. Lol. Still up in the air as what to do for a carb. Was always an edelbrock guy. Never had good luck with the old holleys. Advice welcome on that topic. Interior all done.. As is all the wiring shy of under the hood. Engine/tranny done and installed. (383 with AFR heads/built th400). Was going to install serpentine setup off a 90's V8 with reverse drive water pump. Advice welcome on that one too.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 07-04-2014, 05:22 AM   #281
Aussie Ol' Blue
Aussie Ol' Blue's Avatar
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
Man! That is on very wicked truck! I would so love to have your talents!
That's going to be one hell of a traffic stopper!
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY!
IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE!
Aussie Ol' Blue is offline   Reply With Quote
Old 07-04-2014, 10:19 AM   #282
jlsanborn
jlsanborn's Avatar
I've had good luck with the Edelbrock / AFB but a Holley is winner too. I'd go either way, whichever you can muster a better deal on. Just make sure she's clean and calibrated as it came out of the box.
Here's what I'm hoping to do...
http://www.summitracing.com/parts/ae...o-bk/overview/
With an automatic you may want to stick with the vacuum secondaries though.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 07-04-2014, 03:21 PM   #283
Molberg
Molberg's Avatar
Thanks Aussie! I appreciate the compliments. Nice thing about a build thread is I can edit out all the screw ups I make. Lol. Nobody hears the cussing or sees the flying tools when it doesn't work out the first time.
-Project Nitemare-
Old 07-04-2014, 03:26 PM   #284
Molberg
Molberg's Avatar
I've been out of the carb thing too long I guess... Never heard of an AED. Looks to be modelled after a Holley. I'm eyeballing the edelbrock AVS series friend of mine has a new Holley on his '70 nova... And loves it. And he used to curse them up and down. Lol.
-Project Nitemare-
Old 07-04-2014, 06:46 PM   #285
swamp rat
swamp rat's Avatar
I believe Edelbrock bought out Carter who made AFB.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-04-2014, 07:02 PM   #286
jlsanborn
jlsanborn's Avatar
Yup, the Edelbrock Performer is a re-badged Carter AFB. The "AVS" is adjustable vacuum secondaries, which will work sweet in your truck. Depending on your usage, they've got two or three sizes. I would go big, especially with your CID and kool heads. All you would probably need to do is set the idle and idle air then adjust the secondary opening. Should be pretty spot-on out of the box in terms of jetting. Most people that fiddle with jetting are usually just trying to cover up some other deficiency like a mis-matched cam, lame ignition, wrong gear / stall, etc...
Old 07-04-2014, 10:28 PM   #287
Molberg
Molberg's Avatar
I was gonna go with the 750 AVS(minimum)... 3.73 gears with ratcheting spool, reprogrammed th400 with 2800 stall, 383 with the AFR heads. Cam has .496/520 lift @ 224/234 duration @.50. Should work well I'm thinkin.
-Project Nitemare-
Old 07-05-2014, 12:04 PM   #288
Molberg
Molberg's Avatar
Decided I'd polish up the wiper arms and slam them on. Test fired the wiper before install... Ran nice, parked like it should. (Or so I thought). Installed the arms... Turned the switch on it dragged my wipers down the cowl and heading for the hood. (Insert hissy fit here). Thank god no scratches or damage. Never dawned on me I might have the motor eccentric arm 180 out... Ugh. Off with the arms, cowl, rotate the arm 180. Seems to work as it should now.
-Project Nitemare-
Old 07-05-2014, 03:43 PM   #289
swamp rat
swamp rat's Avatar
At least the hissy fit involved no damage. But i bet the ticker jumped off beat a couple times!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-09-2014, 07:04 PM   #290
litew8
litew8's Avatar
Wipers are fun
Old 07-09-2014, 09:10 PM   #291
chevyc10lover
This is how it sits.. not sure if I'll spray them black or polish yet. I spent about a week fabbing up plastic inserts from 2 factory grilles. Fiberglass work all done (except final work) Installed it and hated it.. lol. So this is where I wound up.
awesome build ! congrats!
chevyc10lover is offline   Reply With Quote
Old 07-10-2014, 03:55 PM   #292
Molberg
Molberg's Avatar
Thanks! The Inlaws are comin tomorrow. See their old shop logo on the truck for the first time. (And the truck painted/assembled) I hope all goes well... Lol. Thanks again.
-Project Nitemare-
Old 07-13-2014, 11:55 AM   #293
Molberg
Molberg's Avatar
The man, the business and the truck.....
-Project Nitemare-
Old 07-13-2014, 01:02 PM   #294
litew8
litew8's Avatar
Old 07-19-2014, 07:19 PM   #295
Mr.Hyde
congrats on the build! have to drive down and see it in person sometime!
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline   Reply With Quote
Old 07-20-2014, 02:26 PM   #296
swamp rat
swamp rat's Avatar
I guess the big question is ...... Whats next??????
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-20-2014, 02:51 PM   #297
Molberg
Molberg's Avatar
I grabbed all the engine brackets, pulleys, 7 blade clutch fan and accessories of a truck at the local wrecker. (1980 V8 chev truck). Bring them home and the water pump pulley touches the water pump when tightened. Won't spin. Ugh... I have a long neck water pump on my engine... I assumed 1980 would be the same. Compared part numbers from my engine to the donor on rockauto... They're different. Must be difference in the shape of the casting I guess. Pulleys all seem to line up well... It just touches the casting
-Project Nitemare-
Old 07-21-2014, 10:41 PM   #298
Molberg
Molberg's Avatar
looks like I bought my next project today... gonna build a summer driver for the wife out of this.
-Project Nitemare-
Old 07-22-2014, 11:25 AM   #299
Gor77
Gor77's Avatar
a great gift
I hope your wife liked it
___________________________________
Dima
1970 Chevrolet C10 stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=569197
Gor77 is offline   Reply With Quote
Old 07-22-2014, 01:29 PM   #300
swamp rat
swamp rat's Avatar
Nice! But i was hoping you'd say Swamp Rats 67! LOL!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
