03-09-2014, 10:42 AM | #276 |
Re: What did you do to your truck today part II.
Thanks! Its just poplar from home depot. Made my wife make the decision. I wasn't sure what I wanted and everyone I asked had a different opinion. So, I let her pic haha. Painting the original strips satin black. I think it will turn out good. Will be nice for water to not be shooting out of the bed when it rains anyhow! Haha.
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
03-09-2014, 04:07 PM | #277 |
Post Whore
Was showing mine off today. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-09-2014, 11:11 PM | #278 |
Pimpston, I gotta say you are one dude that really makes me scratch my head! You seem to sweat over small details of originality in your truck. Yet at the same time I see you're building a wild, purple-framed, about-as-far-from-stock-as-it-gets truck. Your truck seems to have many correct elements yet in completely wrong colors and finishes. Not even close to stock colors. Lots of incongruent visuals like old school bias ply tires on low-rider chrome wire wheels..... yet there's a carefully bent OEM exhaust system.... but a chromed suspension and rear axle. Huh? Seems like most guys here lean one way or the other: all-stock, or slammed/custom. You, my friend, are apparently a strange hybrid of the two groups. When I read about you spending big bucks on NOS pieces for your truck I can't help asking myself "why?" Care to enlighten us? Not trying to throw stones or bag on your truck or your tastes. To each his own. But you make me really curious and I bet some others are, too. I wonder what's the appeal of going to such lengths to be factory-correct when the finished product is very incorrect? At any rate, good luck with the build and thanks!
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
03-09-2014, 11:23 PM | #279 |
Got Top Of Engine In Order Headers Wires Coil Carb Cleaned Up Then Today went to Long Beach Hot Rod Swap Meet !!Seen This Sub
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
03-10-2014, 01:29 AM | #280 |
I wanted power door locks in my 64 C10. I've read that a LOT of the after market door lock solenoids aren't worth a carp so I wanted to stay with GM solenoids. I STOLE jimmydean's idea on installing power door locks but with a twist. I used the power door lock solenoids & brackets from a Chevy Astro Van. I drilled out the pivot pin and bracket to 5/16" & used a 5/16" X 3/4" bolt and Nylock nut. I used a coat hangar as a template to make my lock pull rod. Once I had that figured out I bought a length of 1/8" steel rod from Lowe's - about $3.00 if I remember correctly. The window channel is 1" wide. I drew a center line down the channel mounting screws & measured 5/8" out from there. I took the mounting bracket off the solenoid set it against my lay out line and marked my holes. I drilled my holes at 5/6" allowing a "little" play for solenoid positioning. It's a very close fit between the door skin and the window channel but it does fit without contacting the door skin or window channel. There's definitely a sequence to taking everything apart & putting everything back. Loosen the top screw to the window guide channel & remove the bottom screw. Remove the 3 screws holding the door latch mechanism then remove the 3 screws attaching the door handle latch assembly. As you walk the door striker around the window channel you will be able to disengage the door handle pull rod. Once your custom pull rod is made & installed on your latch assembly you will need to walk it back around the window channel to get it in place but before tightening it down be sure to attach the door handle pull rod now you can bolt in latch & door pull. Next thread the solenoid onto the pull rod you made and bolt it in place.
Here's the link to jimmydean's install - starting @ post #34 http://67-72chevytrucks.com/vboard/s...=397705&page=2 From his pics I did pretty much the same thing but using a GM lock solenoid. |
03-10-2014, 01:35 AM | #281 |
The factory solenoid bolts don't rub on the door jamb when the doors are closed. As you can see it's a pretty tight fit in there but it does fit and work flawlessly. Next up, I plan installing power windows using a factory window & door lock wiring harness form a 78 C10. Here's more pictures of my door lock solenoid installation. Again as you can see it's a very tight fit but it does work great.
03-10-2014, 09:30 AM | #282 |
thks for notice'n my build. well i can sum it up in 2 words "oem custom" when i started my build in 98' i had always seen guys build hotrod cars never trucks so much, so i searched high and low for the perfect truck. yet at the same time i was into the lowrider scene. so once i started planning which way i wanted to go i combined the two, while keeping it all stock as much as i can, just to keep its value up in the off chance i sold it. i wanted to sell a truck that if the buyer was looking for an all original truck mine would fit the bill. as you've seen really only thing that needs to be done is strip the custom color, repaint or powder coat correct colors and bam you have a full on oem correct truck and with all my parts win a ton of awards. plus im an odd bird myself always looking for whats hot while keeping the old stuff alive thats all, thks for taking note!!!! ps i finally got me an offset mounted mirror yea!!!!
03-10-2014, 09:35 AM | #283 | |
03-10-2014, 06:50 PM | #284 |
Post Whore
We got a break from the rain for a week so I pulled the tarp off on mine and now two tone is back to sitting perrty in the sun with her chrome glowing away! lol
03-10-2014, 08:30 PM | #285 |
Today I finally made 2 decisions. #1- decided to order my disc brake conversion kit with,
2.5" drop spindles, 2' drop front springs, 6" drop rear springs, complete front end rebuild kit, and sway bar kit. decision 2 ..order from ECE. So when all said and done, this truck is going to be on the ground! Cant wait, as this has been in the works for about 4 months now. LET THE GAMES BEGIN!!! |
03-10-2014, 09:18 PM | #286 |
I would recommend you rethink the 6" rear springs. It will ride terrible, ask me how I know.....maybe consider 3" springs and 1 1/2 - 2 blocks. You live close, come look at my truck and you'll get an idea of the ride & ride height.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
03-10-2014, 09:41 PM | #287 |
Greg, ...I alrdy have 4" drop in the rear. I just didn't want it to be nosed over to hard. I was going to just add a 2" block to it, but got a little punch drunk when purchasing lol. I guess the good thing is I DO have the 4" springs so If the 6's rides too rough for my likings I could always drop the 4 back under it and sell the 6"er's
As of right now with the 4" in the rear and fronts lopped off, it doesn't ride too bad at all. I was actually shock at how well it did ride, specially in the front considering that the fronts are hacked. Hacked so bad it leans to the passenger side by least 1.5" - 2" I do appreciate the recommendation! Don't think that I don't. But I'll give it a whirl and go from there Speaking of living close, one these days we'll have to meet up and shop talk |
03-10-2014, 11:31 PM | #288 |
Put on the Left NOS Fender Went To See What was under the Bubbles Ugg
Need To Find Right NOS Fender Here's what I zfounf
03-10-2014, 11:32 PM | #289 |
Right Fender
03-11-2014, 12:57 AM | #290 |
GOD BLESS AMERICA! |
03-11-2014, 11:34 AM | #291 |
just bought another radiator, this one makes 3 ugg
03-11-2014, 07:12 PM | #292 |
Are those C10 or C20 caps? Do tell!
03-11-2014, 07:18 PM | #293 |
reproduction half tons
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
03-11-2014, 09:51 PM | #294 |
I went down and got a parking permit so I can park my truck out in front of my house for longer then 2 hours.... $109 for a year just to park in front of my own house.
That's city livin for you... I also used my truck to cut the plywood to make this. Now I just need to make the doors.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
03-12-2014, 09:20 AM | #295 |
And you also have to remember to move your truck on street sweeping day so you don't get a healthy ticket on top of that. Been there done that.
03-12-2014, 11:07 AM | #296 |
I have till Friday noon...
03-12-2014, 07:35 PM | #297 |
Post Whore
Well Two Tone went an had her eyes done today! If any of ya can't figure out the difference look in my build thread.
03-12-2014, 08:03 PM | #298 |
Finally finished the bed wood and put the bed back on the truck today! I will get better cleaned up pics tomorrow and post in the build thread.
Chris
03-12-2014, 08:18 PM | #299 |
WELL--- today I finished putting my NEW motor in my truck. been about 2 months since I started this project. was going to be a pull one put the new one in. then you look at the firewall and inner fenders and say, I need to paint these! NOW there is a lot of extra holes that are not used. SO now we have to weld them up. and FIX SOME wiring that is not quit right!!!! anyway I went to just see if my battery would turn over after sitting for 2 months and the truck FIRED right up. did the break in run. will get pictures maybe tomorrow
03-14-2014, 02:18 AM | #300 |
