05-18-2017, 07:47 PM | #276 |
Re: Out of the Ditch = The Rebuild Begins ('72 GMC)
Looking good! Thanks for the update.
85 Silverado - 350/700r4 |
05-18-2017, 10:37 PM | #277 |
Proprietor of Dale's Corner
Looking good.......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
05-19-2017, 09:00 PM | #278 | ||
"I ain't nobody, dork."
Thanks you'se guys!
Check this out... I was looking at the cab floor today and I can't believe I never noticed this. The pics show the front drivers side outboard seat bolt hole. There is a good sized dent there where the seat bolts to the floor. After some research and also looking in my 1972 GMC parts truck, this area should be flat. Apparently hitting a ditch at 45 MPH with a 245 pound dude in the seat can do this. Wow... no wonder the frame was bent. I also have a dent in the upper part of the drivers side door where it hit my left elbow. How it didn't shatter my arm is beyond me. That area is pretty stout right there where the metal starts to round off towards the window opening. My arm was pretty sore, and I consider myself dang lucky. I am leaving the dent there, and have a pinstriper do a 1970's style asterisk in the middle of the dent with the word "OUCH" next to it. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-19-2017, 09:20 PM | #279 |
Forgive my ignorance as I am still learning about body work, do you put seam sealer down between the old and new sheet metal or after it's all welded in and put it where the old metal meets the new?
Skip
For those that have fought for it, Freedom has a flavor the protected will never know. |
05-19-2017, 10:36 PM | #280 | ||
I have brushable seam sealer that I am brushing over all the welds, and using body seam sealer in the areas where there are gaps and where there are factory seams. I'm sure from the factory there was seam sealer schmutz'd in between some of the panels and then spot welded together. But trying to do that here and get good penetration on welds might be an issue. At least that's my take on it... and I'm no expert on the matter.
Gary
05-20-2017, 07:40 AM | #281 |
Well, GASoline71, that's what I thought. I didn't think it would weld well with it in between the panels. Thanks.
Skip
06-03-2017, 08:31 PM | #282 | ||
Drivers side outer rocker panel. Drilled 78 holes that are 1/4" for "spot welds".
Burned it in, ground down the welds today and then shot it with primer. As you can see in the finished pic I have primered most of the cab floor and hit the welds with brushable sealer. Will do some more seam sealing tomorrow! Gary
06-03-2017, 08:58 PM | #283 |
Looks real nice!
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
06-03-2017, 09:51 PM | #284 |
Looking good!
06-06-2017, 09:42 AM | #285 | ||
Thanks!
Spent the evening after work using a 3M Roloc Bristle Disc on the door edges of the cab. Removed all the old glue residue and stuck rubber from the old seals. Had to hit a few areas with a 60 grit grinding wheel to get at some rust. But It's all done. Now I have to mask it all off and give it a shot of etching primer and then a coat of paint before I put my new push-on door weather seals on. Also seam sealed the entire cab last night. Gonna go over a few more areas with brushable sealer after work today. Gary
06-06-2017, 12:53 PM | #286 |
Very tidy fab work on the new panels! Great stuff and love the idea of the pinstripper doing the "ouch" with asterisk
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
06-13-2017, 08:45 PM | #287 | ||
Thanks Dylan!
Update. I installed "Fat Mat" over the weekend to the cab floor and to the back of the cab under the rear window. The original jacking and tool stowage instructions sticker is still there... so me being the sucker for nostalgia I am... I left it there and put the sound deadening around it. My furry "helper" was a bit camera shy... Funny how Maggie can tell when I have my phone camera on her... She turns her head just at the right moment. Cleaned out the gas tank and threw it in for a pic or 2. Gonna remove it and repaint it. Also look for some kind of spray paint that looks like the original galvanized metal look. All in all it's more progress. Feels good to be getting closer to firing this thing up again. Gary
06-14-2017, 06:50 AM | #288 |
Awesome work on the cab Gary!!
Scott |
06-15-2017, 04:10 PM | #289 | ||
Thanks Scott!
Another update... My 1972 C25 parts truck had an aftermarket heater control panel installed in it. So I removed it to use in my 1972 C15 that had the original unit with 2 busted levers. Once I got them both out and sitting side by side... I didn't like the aftermarket unit. Instead of the decorative "ribbing" on the face being metal like the original, the "ribbing is nothing but a foil sticker. The 2 good things about the aftermarket unit were the levers are steel and not pot metal, and the heater fan switch is the exact same switch (even the manufacturer) as the old original switch. So I kept my 1972 control panel and installed the aftermarket levers and knobs, and used the newer fan switch. EZPZ... The aftermarket panel also had smaller lettering on the "DEF" "AIR FAN" "HEAT" side. So I am glad I used the original with new levers. Gary
06-15-2017, 04:49 PM | #290 | |
It also looks like those new rockers fit pretty well!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-15-2017, 06:17 PM | #291 | |||
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I used the el-cheapo disposable acid brushes to brush it on the weld seams I am extremely happy with how that drivers side outer rocker fell into place. Wish I would have bought that brand when I did the passenger side. Live and learn! Gary
06-16-2017, 12:32 AM | #292 |
That's really great to hear as I have the same ones in my parts pile.
I'm going to have to try that stuff out!
06-26-2017, 02:27 PM | #293 |
Looking good Gary ,My yellow lab supervised the truck i redid last winter, they are real good dogs ,Are you going to do the paint job and bodywork yourself ?
06-26-2017, 02:47 PM | #294 |
Nice to work on the heat controls. It's always a good feeling knowing you don't have to fight the broken levers and have to reach under the dash to turn the heat on or off.
Scott |
08-18-2017, 10:09 AM | #295 | ||
Been awhile since I posted in here! Whew! It's been a busy summer. Didn't get nearly as much done as I wanted. But I accrued more parts and even installed a couple things.
New aftermarket Ididit tilt steering column installed. It fits great, but I have one complaint in that the plug and play adapter is too short. Since this is their universal column it fits almost anything, and then they include the correct electrical adapter (made by AAW) for your vehicle. It is a very nicely made column and I clear coated the bare metal after I wiped it down with solvent to remove the oils that were on it to prevent rust. Hope the clear coat holds up on the portion that sticks through the firewall into the engine compartment. Also picked up my new shifter. B&M Pro Stick. Need to fabricate a mount for it as it will be too low mounted to the floor. More to come soon. Not many pics, but if anyone is interested, I will take more pics of the wiring adapter that came with the column. All quality made in the USA stuff. just too short in my opinion. I contacted AAW to see if they have a longer adapter and they don't offer one. But the guy said they can supply the adapters without wires so I can make my own. Which I might just do. Gary
08-18-2017, 10:15 AM | #296 | |||
Gary
08-18-2017, 11:04 AM | #297 | |
Ps Hows that chain sharpening stone business doing . |
08-18-2017, 12:54 PM | #298 | |||
I just noticed you're over in PA! I never had a chain sharpening stone business. But I used to fall timber for a period as a hired gun. Gary
08-18-2017, 03:35 PM | #299 | |
Your doing a fine job on the truck ,lot of guys would not have changed the whole frame out . |
08-18-2017, 05:22 PM | #300 | ||
I had a feeling you were referring to AS! Haven't been on there in ages.
Gary
