02-04-2018, 03:24 PM | #276 |
Re: Ratchet's Blazer - 1970 2wd with Original paint
I pulled the 79 Firebird 8.5" 10-bolt out from under my other truck and mounted the brake rotors and wheels up so that I can get some good "before" measurements. I couldn't help taking pictures because those 315-35-20's just look so damn meaty, and the 13" C6 Z51 rear rotors look small in those 20" wheels...
I love these wheels, especially with the dish that the centers have.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 02-04-2018 at 04:42 PM. |
02-04-2018, 04:36 PM | #277 |
02-04-2018, 06:29 PM | #278 |
A guy with a truck
What are you doing for brake brackets? Just got my C5 rear calipers in the mail the other day
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-04-2018, 07:12 PM | #279 |
I had ordered a Kore 3 setup (355mm Hybrid front and 330mm Z51 rear with parking brake) for a 79 firebird, which worked on the other truck since I used a 79 Z28 front subframe on it and this 79 firebird rear axle. That project is going to start over after the Blazer because I don't trust the connection of the subframe to the truck frame.
I am stealing the brake setup from that project, basically. After talking with Tobin @ Kore3, the tall-spindle setup that I have is the same as the C-10 setup with the exception of the hubs, since I have HD spindles for 1.25" rotors. If I changed spindles to the LD, I could have used everything just like your setup on your truck, but I would have to change tie-rods and ball-joints which has all just been replaced. It came out to be just barely more expensive to order some new hubs for the HD spindles, but with the 5x4.75" bolt pattern. The new hubs used to be a special order, but they had so many requests that they now stock them. The only problem is that I already powder-coated the calipers green which was going to work with that truck, but I don't think it will look good against the blue of the Blazer. I have a buddy that can strip them and re-powder them, but I have to decide which color... I'm thinking a darker silver/grey/titanium color or a blue, but I'm afraid that if the blue won't match exactly it will look funny. What do you think?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 02-04-2018 at 11:04 PM. |
02-04-2018, 07:17 PM | #280 |
Here are my color options next to a picture that is closest to the real color of the Blazer out in the sun...
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 02-05-2018 at 11:26 AM. |
02-05-2018, 11:21 AM | #281 |
A guy with a truck
Grey all day. Can’t see your last pic, for whatever reason...
Edit: what’s your plan for master cylinder? I’ve been contemplating this exact setup, curious to see how it works out for you. The stock rotors are cheap and plentiful and converting to 5x4.75 is almost a wash money-wise, if you’re already buying wheels.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 02-05-2018 at 12:07 PM. |
02-05-2018, 11:28 AM | #282 |
I edited my last post... I was trying to be fancy and had built a .gif that cycled the color choices next to the pic of the Blazer.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
02-05-2018, 11:48 AM | #283 |
I dont think the green would look all that bad. You can two tone some of the other parts of the truck as well.
Posted via Mobile Device |
02-05-2018, 12:15 PM | #284 |
A guy with a truck
I’m somewhere between galaxy and speedway. Like a cast iron, but with flake.
02-05-2018, 12:29 PM | #285 | ||
Right now, I have a stock 72 style manual master cylinder for the factory disc/drum setup which would probably work fine if I replace the prop valve with an adjustable valve. Quote:
My wife is telling me to just go with a gloss black which might not look bad with the textured black that is on the pad abutment brackets already.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 02-14-2018 at 03:18 AM. |
02-05-2018, 12:36 PM | #286 |
The Black that Brandi says will look good, or the Galaxy. I am not a big fan of the bright colors calipers my self. To me it distracts from the vehicle.
02-05-2018, 12:42 PM | #287 | |
I just found this Graphite Charcoal which looks promising...
02-05-2018, 02:48 PM | #288 |
A guy with a truck
Funny, I was gonna say gloss black as a second option. Have you seen evo grey? It’s a prismatic color that I used on all of my PB stuff. Nice dark grey, that flops from near black to almost silver depending on lighting
02-05-2018, 04:51 PM | #289 |
I went back and looked through your thread to see that color, and you are right, it does look good. It's so hard to pick a color based on pictures on the internet though. My wife may be right in the fact that I should just do gloss black and call it done. My powdercoater keeps gloss and 20% gloss black in stock ready to go, any other special color I want would have to be ordered.
02-06-2018, 12:01 AM | #290 |
Well, I ordered swatches of all the colors listed on this page, to include the Evo Grey. If I don't like any of those, I'll just do the Gloss Black.
02-08-2018, 02:42 PM | #291 |
I've done a lot of measuring for my rear axle, and it looks like I will end up with about 1/2" clearance between the tire and the inner wheel tub. Do you think that is enough? If not it looks like I am going to have to do the "Lucy" mod that n2billet did.
The powder swatches came in today! I've taken about 100 pics, but it is amazing how hard it is to get an accurate representation of the colors. I have my favorite already, but which one do y'all like?
02-08-2018, 04:09 PM | #292 |
A guy with a truck
Plan on “Lucy” modding mine, too.
I like 2, but I’m also partial to 6
02-08-2018, 04:18 PM | #293 |
Actually, you would be partial to 5, that one is the Evo Grey.
02-08-2018, 04:39 PM | #294 |
A guy with a truck
Wow, the pictures really do mess with you...
02-08-2018, 05:04 PM | #295 |
2 or 6 would be my pick
02-08-2018, 06:08 PM | #296 |
:agree
6 or 2 (or Brandi Black )
02-09-2018, 12:22 AM | #297 |
I was trying to NOT remove the original rear end until I had the new narrowed setup ready to go in, but I knew I would regret not pulling it before-hand if I didn't. Tonight I removed the rear axle and stuffed one of the back tires up in there, and am I ever glad that I did. My measurements that I was taking told me that I would have 1/2" clearance when aired out, but physically sticking the tire in there says that my math was wrong somewhere. It is touching on the inside and outside. Now I HAVE to do the "Lucy" mod that N2billet did on his bedsides. It's just a little more work, but as you can see in my pics, it will be well worth the trouble!
02-09-2018, 01:10 AM | #298 |
A guy with a truck
God bless America!
02-09-2018, 09:16 AM | #299 |
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-09-2018, 01:31 PM | #300 | |
I finally got a picture that is closest to what I actually see with my old eyes.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 02-09-2018 at 01:36 PM. |
