Old 06-06-2015, 10:24 PM   #276
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
Looks fantastic my friend, keep at it!
--Josh
Old 06-09-2015, 12:33 AM   #277
T bone
Hi Sid,
I'm curious to know why most builders using the C4 rear opt to replace the mono leaf in favor of coil overs?
Some considerations I'm aware of include:
-better adjustability characteristics of coils
-higher replacement cost of mono if needed
-possible leaf interference with drive line elements
-leaf more easily damaged by heat and engine fluids
Are there other considerations I've missed? What were the major factors in your decision?
T bone is offline   Reply With Quote
Old 06-13-2015, 01:47 AM   #278
gearhead2069
Hey buddy, your chassis looks clean! Fantastic! You have got some seriously impressive skill!
Have you figured out a fix for a rear sway/torsion bar? I think I have figured out what to do with the front and from what a lot of people have told me, due to the rear being so light, it doesn't really need a rear. I guess the more I think about it the more I get irritated. Have any ideas?
gearhead2069 is offline   Reply With Quote
Old 06-13-2015, 07:47 AM   #279
FarmerSid
FarmerSid's Avatar
Originally Posted by oldman3 View Post
Sid, frame looks great, sons in the shop, couldn't ask for more....Jim
Thanks Jim. Glad to have the boys out with me.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 06-13-2015, 07:50 AM   #280
FarmerSid
FarmerSid's Avatar
Originally Posted by 99 to Life View Post
looks saaawweeeett. Your doing kids right by even having them around this stuff at all, let alone actually getting their hands on it.
Thanks 99. The oldest learned how to use the chop saw to cut some 2X4 tubing for me. The sparks and loud kinda made him nervous at first but is now asking if I need anything cut.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-13-2015, 07:52 AM   #281
FarmerSid
FarmerSid's Avatar
Thanks Josh! Good to see you around. So...what are you up to now that you sold your truck?
C4 IFS & D44 IRS
5.3 HO L33
Old 06-13-2015, 07:59 AM   #282
FarmerSid
FarmerSid's Avatar
Originally Posted by T bone View Post
Hi Sid,
I don't really know exactly why but I had some of the same considerations you did. I like the cleaner look of no leaf spring as well. That all I have for you T bone.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-13-2015, 08:08 AM   #283
FarmerSid
FarmerSid's Avatar
Thanks Gearhead! What do you mean fix for the rear sway bar? I haven't put too much thought in it but the frame rail is directly above the inside portion of the bracket that is bolted to the IRS. I would have to make new end links of some sort to connect the bar to the IRS. Same with the front. Not too much room between the tie rod and coil over to install the end link. Both the front and rear end links are big and bulky.
Don't get too irritated. That's a sign to take a break. Keep it fun. I'm getting used to doing things over 2 -3 times now. LOL!
What's your idea for the front sway bar?
C4 IFS & D44 IRS
5.3 HO L33
Old 06-13-2015, 08:29 AM   #284
FarmerSid
FarmerSid's Avatar
I have a couple pictures to share but will post a bunch more when I get a bunch more done.
Exhaust ports
Curving the frame cross members. What a job!
Curved cross members finished with exhaust ports mocked up to see what they look like.
I've made two more exhaust ports for the front that go under the curved portion of the cross members. The transmission mount will be bolted in the curved portion. I will make a 6" ID round drive shaft port/opening at the rear to tie everything together. Don't need too big of an opening as the drive shaft will be in a stationary position.
Go ahead and critique my work and idea's as I may be over looking things. Any thoughts on brake and fuel line routing?
C4 IFS & D44 IRS
5.3 HO L33
Old 06-13-2015, 08:40 AM   #285
gearhead2069
Flat-Out (the set up I went with as I don't think I have your skill) didn't really have a sway bar solution so I've been trying to come up with ways to fix the issue. I was searching around and I found this:
http://www.welderseries.com/blog/onl.../sway-bar-kit/
Which is pretty pricy for what it is, but I don't think it would be difficult to fabricate. I really like how Nerd Rods did theirs and I don't see why that wouldn't be feasible.
For the rear, once again, it looks like Nerd Rods has worked something out but I'm just not entirely sure how I feel about the bracket being welded to the lower trailing arm. Seems to me that mounting point would be a bit of a weak spot but maybe a modified version of that idea. I don't know, I was thinking about mounting it somewhere around where the old shock mount is. Just kind of making it an extension of the new cool over mount. Like I said... Just pondering for a solution.
Old 06-13-2015, 08:50 AM   #286
FarmerSid
FarmerSid's Avatar
Ya, I'm going to have to come up with something the same as Nerd rods in the first picture. I don't care for the rear though. I think I should be able to put the sway bar on top of the frame and make end links to connect in the stock location. I think I'm going to add mounts to the frame front and rear so I'm ready to go if I need or decide to run them.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-13-2015, 10:26 AM   #287
gearhead2069
Sounds good. Can't wait to see how things turn out. Keep up the good work!
Old 06-13-2015, 10:27 AM   #288
windows
Nice fab work, Sid. Really like what you're doing.
windows is offline   Reply With Quote
Old 06-13-2015, 11:55 AM   #289
Advanced Design
Advanced Design's Avatar
Great fabrication Sid. Crossmember looks really good. Can you run your brake and fuel lines just under the crossmember? An alternative is along the top if there is room. Of course that could make it more difficult to change them out in the future if needed.
Advanced Design is offline   Reply With Quote
Old 06-13-2015, 12:59 PM   #290
99 to Life
99 to Life's Avatar
very nice
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-14-2015, 09:18 AM   #291
FarmerSid
FarmerSid's Avatar
Thanks all! AD, there's 1 3/4" space there to run lines. Should be enough room using both sides.
Big change to the cross members. A buddy stopped by and thought that things would "flow" better if I curved both ends so that's what I did. I like it better but a better part of the day was spent modifying them. I'll get some pictures up soon.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-14-2015, 10:32 AM   #292
solidaxel
solidaxel's Avatar
The fuel lines went inside the box frame and the brake lines went outside
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-14-2015, 07:22 PM   #293
FarmerSid
FarmerSid's Avatar
Thanks solidaxel. Gave me a few idea's.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-14-2015, 07:37 PM   #294
FarmerSid
FarmerSid's Avatar
So......as I mentioned before, a buddy convinced me to curve the rear portion of the inside cross members. Here's how they turned out. You can also see the exhaust ports tacked in place to see what things look like.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-14-2015, 07:47 PM   #295
FarmerSid
FarmerSid's Avatar
Here's a few of where the trans mount will go and where a drive shaft loop type thing will go but mostly to tie things together and stiffen things up. The blue tape represents the approx. trans mount location. The second picture is the rear where the drive shaft loop thing will go. Anybody have any design idea's for the trans mount and loop they want to share?
Anybody see any issues that I don't?
Now I have to make two more exhaust ports for the right side now that the rear portion is angled. What do you all think of them?
C4 IFS & D44 IRS
5.3 HO L33
Old 06-14-2015, 08:30 PM   #296
FarmerSid
FarmerSid's Avatar
I'm really terrible at taking pictures. Here's one of the overall frame to date.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-14-2015, 10:23 PM   #297
99 to Life
99 to Life's Avatar
thats one clean and nice looking frame.
Old 06-15-2015, 12:29 AM   #298
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
What if you used DOM tubing, maybe 1-1/2", to make both pieces. Make the trans mount a half circle, and the driveshaft loop a full circle, but the same dimensions otherwise. Weld a plate on the tubing where it lies against the upright section of the frame, and bolt through that, two bolts per side. That way you have a consistent theme, and you keep your nice smooth bends in the center section.
On second thought, maybe I should draw a sketch; I'm not sure I even understand what that says, and I wrote it!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 06-15-2015, 02:48 AM   #299
Chevy-49
Chevy-49's Avatar
Looking nice, perhaps any pictures of the exhaust system?
Did you end before or after the rear axle?
My build thread: 1949 AD truck 'Chevy-49'
Chevy-49 is offline   Reply With Quote
Old 06-15-2015, 06:48 AM   #300
FarmerSid
FarmerSid's Avatar
Good idea. Not too sure the round tubing would look right. Maybe....something to think about for sure.
C4 IFS & D44 IRS
5.3 HO L33
