Old 02-20-2015, 05:38 PM   #276
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: Dutch '59 Fleetside Longbed
I put mine on the bottom side. Screwed them in place first then removed one screw at a time and plug welded them in. Seem sealed all the edges and undercoated the bottom side, painted the top side and covered with Dynamat!
ChuckDriver is offline   Reply With Quote
Old 02-20-2015, 05:49 PM   #277
RockinKees
RockinKees's Avatar
Looks great Chuckdriver, Did you weld it from the top of the bottom?
Thanks Kim, I do my best! (Can't even stand in your shadow )
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-20-2015, 07:35 PM   #278
ChuckDriver
From the top!
Old 02-23-2015, 02:56 PM   #279
RockinKees
RockinKees's Avatar
Today I had planned to get the propane tanks at the side of the framerails.
I had to modify more as planned...
I knew I had to take a piece out of the cabcorner, this doesn't matter because you don't see it.
After some measurements I came to the conclusion I also had to modify the step inside the cab.
I'm glad I have a longbed, otherwise it didn't fit at all
So I took my buddy The Grinder and take a piece out of the cabcorners and out of the steps...
Cabcorner:
Step:
This is one of two propane tanks that going to be mounted next to the framerails:
They measure 125 cm x 25 cm (49,2" x 9,8")
I drilled the holes for the brackets to hold the tanks and test fitted them.
I must say, they fit pretty good, it's a shame I had to cut into the steps, but propane is so much cheaper to drive than petrol overhere. I really do not want anything in the bed if it isn't really neccesary.
Sometimes you must sacrifice some....
The two mounted:
With the bed on, you don't see the tanks, and that's what I wanted.
You don't even see the modified steps with the doors closed
I found the cabcorneres in pretty good shape, some small holes, the inner corners weren't so bad either. So I grinded the last 2 inch off of the inner cabcorners to open them up. The rest of it stays. There came a few kilos of rubbish out of it! The small holes will be repaired and undercoated, just like the rest of the entire underside.
Now with this done, I can clean up the rear frame and put some paint on it.
Then take care of the IRS, clean it up, new brakes on and paint it.
All goes to plan
Cheers!! Kees.
Kool Guyz CC
Old 02-23-2015, 04:17 PM   #280
Katrina/10
Katrina/10's Avatar
You would probably never use the area you cut out of the step anyway!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 02-23-2015, 04:32 PM   #281
RockinKees
RockinKees's Avatar
Yeah, that's what I thought, Gary!
Cheers!! Kees.
Kool Guyz CC
Old 02-23-2015, 05:35 PM   #282
Steve-W
Steve-W's Avatar
Looks great Kees, I was also wondering what the purpose was of those "pockets" at the rear cab corners.
Kim and Chuckdriver, your solutions look great!
Can't wait to see what yours will be like Kees
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 02-23-2015, 05:36 PM   #283
Kim57
Kim57's Avatar
Those fit real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-23-2015, 05:59 PM   #284
ChuckDriver
Looks good!
Old 02-23-2015, 08:06 PM   #285
Advanced Design
Advanced Design's Avatar
Nice work Kees! Don't see many propane fueled hot rods here.
Advanced Design is offline   Reply With Quote
Old 02-24-2015, 09:54 AM   #286
reaper71
reaper71's Avatar
Looking really good (totally out of the box) at least over here!! I LIKE IT...
Mark...
reaper71 is offline   Reply With Quote
Old 02-26-2015, 12:11 PM   #287
RockinKees
RockinKees's Avatar
Thanx all!!
And yes, it's literally out of the box
I took all the parts off of the frame again, cleaned it a bit so it's ready for paint.
I also took the halfshafts off of the IRS, I need longer wheel studs in it, mount new brake discs etc.
I need a press to get the flange off, I'll try that Saturday...
The Brittish know how to put an axle together... it won't fall apart, everthing was so tightened, the waterdrops stood on my back
Cheers!! Kees.
Kool Guyz CC
Old 02-26-2015, 04:54 PM   #288
Kim57
Kim57's Avatar
The frame looks real stout in the rear.
Kim
My build thread
Old 02-26-2015, 07:07 PM   #289
Katrina/10
Katrina/10's Avatar
Jag IRS has American Dana 44 center section. I like how they did that.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 02-27-2015, 12:15 PM   #290
RockinKees
RockinKees's Avatar
Thanks Kim, I also like how it turned out.
Gary, Jag used two different types of centers, Dana and Salisbury, they look alike but are just a tad different. Don't know which I got just yet.
I put some primer on the rear frame and the parts of the IRS today.
I think it needs another coat and then the black can go up.
This week is the final mounting of the IRS (I hope )
Then on to the front, and finish that part.
Still got a lot to do
Cheers!! Kees.
Kool Guyz CC
Old 02-27-2015, 12:30 PM   #291
Katrina/10
Katrina/10's Avatar
I did not know they used Salisbury, the cover sure looks like a Dana 44. Have fun painting!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 02-27-2015, 01:38 PM   #292
ChuckDriver
Very clean! Are you going to detail the IRS??
Old 02-27-2015, 02:41 PM   #293
Spblack
Spblack's Avatar
man, I don't know if it would want those propane tanks sitting there exposed if you get hit from the side. I would try to place in them inside the frame rail.
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 02-27-2015, 06:31 PM   #294
RockinKees
RockinKees's Avatar
ChuckDriver, IRS is just going to be painted. Nothing fancy, it's going to be a daily driver you know
Spblack, inside the framerails doesn't fit.
I drove for years this way with a Chevy Van, never had any issues with it, just hoping the "other people" would look out some...
Thanks for your worries though!
Cheers!! Kees.
Kool Guyz CC
Old 02-27-2015, 06:56 PM   #295
Kim57
Kim57's Avatar
Frame looks real clean in primer.
Kim
My build thread
Old 02-27-2015, 08:17 PM   #296
oldman3
oldman3's Avatar
Kees, frame looks good in primer, with black paint will look great...Jim
oldman3 is offline   Reply With Quote
Old 02-27-2015, 08:49 PM   #297
Advanced Design
Looking really good Kees!
Old 03-02-2015, 02:04 PM   #298
RockinKees
RockinKees's Avatar
After two coats of primer, now one coat black.
Just one black coat to go
I took the IRS apart to get a good look at it (had not done that yet...)
There was only one broken bolt, a bad one!
The lower control arm are hold by a "bridge" that is bolted to the diff with only two bolts each side.
Left side was loose, and at the right side was one broken, not really a good thing
It sure is a good thing I clean things up before I mount it on the truck
What good about it is that the diff itself and the power lock is really clean
Parts, parts, parts....
A look inside:
Till next time!!
Cheers!! Kees.
Kool Guyz CC
Old 03-02-2015, 02:50 PM   #299
Advanced Design
Good progress. I can almost smell the gear oil in the last picture. Always reminds me of my Grandpa's garage.
Old 03-02-2015, 05:23 PM   #300
Kim57
Kim57's Avatar
The frame looks real good.
Kim
My build thread
