Old 09-09-2016, 12:09 PM   #276
MTCK
MTCK's Avatar
Re: Let's Build A 1 Ton Crew Cab 4x4
Nice work! You've been knocking this project out lately. Your rake isn't that bad I don't think. Maybe an inch or two. Remember to measure to the body crease, not the top of fender opening, because the front fender opening is taller.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-09-2016, 01:47 PM   #277
NastyBuzzard
NastyBuzzard's Avatar
I am trying to get it back together! Slowly pecking away at it is what it feels like. I will measure the body crease. It should be around 1.5" or so difference but then again I still lack the weight up front. I will work on leveling it out when all the weight is on it.
Trying to see about rear bumper and hitch and other holes to mount bed and such now.
Also finally replaced that bent steering link, and working on getting other steering components on.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 09-09-2016, 02:11 PM   #278
Deer_hunter_088
Deer_hunter_088's Avatar
subscribed!!
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 09-09-2016, 04:10 PM   #279
NastyBuzzard
As much as I want this big tough bumper on the back. It just isn't looking right or as good as I'd hoped. This bumper is off my 87 V1500 longbed that I ls swapped.
May end up with the sport style or blazer, unsure.
Also... I wanted to use the tow hitch off the k30 crew cab.. Tried clearancing it for the drop down perches and all, I'd have to go back and fix it where it would be strong again but it's close to where it would be mounted and once again... It just doesn't look right hanging so low from the bumper. So I may use the k5 blazer hitch that is laying on the floor instead so it will tuck up closer to the bumper.
Also may be swapping out the 4x4 stock xmembers from the engine area. I'm going to try and modify this diy4x one for the engine then the other xmember I swapped back out for the 2wd one. I'll just have to find a good strong way to mount the sway bar back bc I want to use it.
I also cleaned the crap off the stock tbi fuel lines. I may be able to use them and just make whatever else I need. Just have to replace the filter for diesel filter and put lift pump in line somewhere.
I'm also going to clean off all the other oem brake lines I have so I can use them and just make ends for what's missing.
Old 09-09-2016, 04:48 PM   #280
daddyjeep
daddyjeep's Avatar
Cool, it's looking like a truck now.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-09-2016, 07:47 PM   #281
jott_06
Camaro Club
jott_06's Avatar
On my suburban I kept the front 2wd crossmember in tact and built mounts for the sway bar off of it. I will try to get some pictures because I dont think I took any during the build.
jott_06 is offline   Reply With Quote
Old 09-09-2016, 07:51 PM   #282
NastyBuzzard
Awesome! I'd definitely appreciate it! I think doing that will be easier and neater than trying to retrofit the 4x4 one bc it was too tall and had to remove the sway bar mounts from it anyways and mount them further ahead.
Old 09-10-2016, 09:43 PM   #283
NastyBuzzard
Unfortunately, my second alternative hitch wont work because it is off a k5 which apparently has a curved frame or something like that at the rear. So I will be working on modifying the one I originally made for my 87 V1500 longbed.
I did get my tool box organized somewhat today.
I also got some of the fuel lines ran. So far reusing what I already have. Seems like it will be fine for the low pressure diesel.
Although I will need to remove the gas fuel filter. I also need to fit in a lift pump somewhere. Also, it is a pain to find pictures of the original mounting points of the lines in frame rail online.
Old 09-11-2016, 03:21 PM   #284
y5mgisi
Second Chance Program
y5mgisi's Avatar
Like
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-12-2016, 05:43 AM   #285
NastyBuzzard
I started to bolt down the bed. I was prepared to have to drill holes and all, but wow. All the carriage bolts just fell right in. Except the 2 closest to the tailgate. When I checked them out it was only b/c the hole was too small. So I just have to drill out those 2 holes. However, as you can see I may need to widen some holes to get it flush with the body, somehow it is off a tad on the DS.
I also cleaned and mounted the front prop valve and brake lines.
I need to find some steel braided hoses to go to the calipers, as well as steel braided hose to go from rearend up to the frame. Any ideas, should I make them myself?
I had a little bit of time and decided I wanted to see about the hitch more. I pulled out the one I originally made for the 87.
With some slight modification, I got it to set up in there.
I am going to model up some new 1/4" side plates for mounting, but I don't like the dainty square tubing even if it is 1/4" wall tubing. So I decided to cut the mounting plates of the k5 blazer hitch I had and I am going to make some more mounting plates for it instead as well as tuck it a little closer to the bumper. Its for aesthetics really, I just don't like the hitch to be hanging all crazy out there and way low.
Hopefully this week I can get my gear box rebuild finished up and work on the mounting plate for the hydroboost setup.
At this time I am also trying to finish plumbing lines and finding all the new holes I have to drill in the rear of the frame. So hopefully the next time I remove the bed it will be the last time until paint.
Also, I measured the body lines and it appears the front is about 2.5" higher than the rear. So after it is all together with all the weight on and the 35"s I will see about the height. If I can live with it being that much taller in the front I will add to the rear to level it out. However, I am pretty sure it will be too high and I will have to swap out the front springs. Time will tell.
Old 09-13-2016, 05:54 AM   #286
NastyBuzzard
I did finally get my wheels!! I have heard people say you need spacers with these and some say you don't. I guess I will find out soon enough. I need some 33 or 35" roll around tires to slap on them for now. New tires aren't currently in the budget but I am ready to ditch the stock wheels and 31s.
Old 09-13-2016, 10:34 AM   #287
daddyjeep
daddyjeep's Avatar
Nice, love the wheels.
04 1500 crew cab
Old 09-13-2016, 10:40 AM   #288
NastyBuzzard
Me too!! I have been hunting a set of these specific ones since I got the crew cab! I love the 5 star design, I was stoked I found the chrome set. I never thought I would and they were cheap! Now I just need some cheap tires to roll on.
Old 09-13-2016, 11:43 AM   #289
68Timber
I know the pieces fit
68Timber's Avatar
Those look good. Did you see y5mgisi's update yesterday on his 76? He put some budget new tires on his refurbed wheels that looked great and had good reviews, might be worth checking out.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-13-2016, 12:33 PM   #290
NastyBuzzard
Yeah I see all his updates on facebook too. We are friends there I think. However, they are a great deal for tires but still more expensive than what I need at the moment. The set still ran him around $640 or so I think. I just need some tires that hold air for the moment. I still haven't decided if the truck will get MT or AT tires.
Old 09-14-2016, 10:02 AM   #291
NastyBuzzard
So, extended brake hoses. What are some cheap options here? I would like steel braided but so far I can't find the 3 hoses for less than $100. So I am looking at other options. I don't want to drop the lines down below the frame.
Old 09-15-2016, 11:29 AM   #292
y5mgisi
y5mgisi's Avatar
You can get factory rubber ones for I think like a 93-96 2wd 3/4 ton chevy pickup that are long enough for like a 6" lift and have the correct ends. As I recall there is an extra bracket on the hoses where they would have mounted onti the control arm but it's removableremovable. Look into those.
Old 09-15-2016, 11:31 AM   #293
NastyBuzzard
Will do. Any difference in the fitting on the 1ton caliper vs the 3/4 caliper?
A lot of sites only show lines for 1/2 ton and 3/4 ton so I had to ask.
Also I see someone sells a 3/4 ton brake swap kit for the dana 60, says it saves you 41 or so lbs. Why go smaller, I figure the 1 ton stuff must be better?
Old 09-15-2016, 11:36 AM   #294
y5mgisi
y5mgisi's Avatar
I think the 3/4 swap guys are mostly crawler guys that don't need the bigger brakes. And I really don't recall the exact details on the brake lines. I have them on my suburban now but they have been on there from probably 10 years. Maybe if you ask on one of the Facebook groups they will be more hip to what I'm referring to.
Old 09-15-2016, 11:39 AM   #295
y5mgisi
y5mgisi's Avatar
These might work.
http://pages.ebay.com/motors/link/?n...874502&alt=web
Old 09-15-2016, 12:51 PM   #296
NastyBuzzard
Whoa! Those lines are cheap! Those would be excellent. They say for 6-8" of lift though. Seems like they would be ridiculously long? I need some 4"-6", if only could find those at that price.
EDIT. That is the price for just the rear line not all 3 per the description.
Old 09-15-2016, 05:48 PM   #297
NastyBuzzard
So I am looking at coming up with brake upgrades and I have to wonder...
I put H3 hummer 4 piston calipers up front of my 87 4x4 with Dana 44.. So besides to some modifications to the mounting bracket for caliper and the fact that the rotors are 6 lug rotors. Any reason why I couldn't do almost same damn thing on this dana 60?
I am also looking into rear disc upgrade for rear. I need park brake and I won't use the el dorado calipers. I am maybe thinking of a way to try and put the H3 4 piston caliper or on the rear as well. Its conceptual at the moment. However, I still need park brake. I have seen that Wilwood makes a standalone mechanical park brake caliper. I could use that, maybe. IDK.
Something like this.
http://www.hispeccalipers.co.uk/svascal1.html
School me b/c I haven't found crap for some real nice brake upgrades.
Old 09-15-2016, 06:03 PM   #298
MTCK
MTCK's Avatar
Have you considered driving it with the stock brakes? Only reason I ask is they stop pretty damn well with the big drums out back and hydroboost. I was thinking about brake upgrades on mine before I installed a new booster and master cylinder and it will lock them all up if you stomp on the pedal. Not sexy, but they work.
-Marcus
Project Plow Truck
Old 09-15-2016, 07:04 PM   #299
NastyBuzzard
Not with it 4x4 and hydroboost but otherwise yeah. I just want really good brakes in case what I'm towing doesn't have brakes.
Plus it pretty much all needs replacing and I'd hate to spend that $ and then it not reform and I have to redo it. I hate doing that. Plus I already want to go disc brake out back.
Old 09-15-2016, 07:22 PM   #300
jott_06
Camaro Club
jott_06's Avatar
could you just get all the parts to covert it to rear discs from a newer 3/4 ton gm truck?
