Old 03-03-2020, 10:48 PM   #276
joedoh
joedoh's Avatar
Re: Francis the Tow Pig - 1949 GMC 250 Dually
Made some good progress tonight. Parts delivered in time for me to come home and install them! Got the rear diff cover back on with the LubeLocker gasket, if you're not using these for your differentials, I highly recommend them! Filled with Amsoil Severe Gear 75w90.
Moved on to the Hellwig anti-wrap springs. They come with good reviews from the S10 crowd in controlling wheel hop. I'll be putting them to the test for sure, been a day or two since I've treated the tires like a rented mule.
Some of the AC stuff will start rolling in this week, and my ICT Billet "cut to fit" plug wires should be in tomorrow or Thursday.
those half springs should help a lot
The guy doing the transmission service spilled fluid after he thought the pan was completely drained....and will remain unnamed.
fire that guy!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 03-05-2020, 10:44 AM   #277
OutlawDrifter
fire that guy!
Let's hope so on the springs...they were definitely "affordable".
As to firing the dude who will remain unnamed...he signs the checks and orders the parts, I better keep him around until this project is "done"...haha
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-06-2020, 11:18 AM   #278
joedoh
joedoh's Avatar
well fire him and give him a couple days off, anyway sounds like the boss is a pushover, and will hire him back
Old 03-06-2020, 10:52 PM   #279
lower50's
lower50's's Avatar
The carpet turned out nice
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-08-2020, 01:02 PM   #280
OutlawDrifter
Thanks lower50s!
1991 Z/28, 6.0L/T56
Old 03-08-2020, 01:03 PM   #281
OutlawDrifter
Interior less AC is done. I'm very pleased with how the seat turned out, the colors and pattern are exactly what I wanted. Door panels are so-so, I should have made some out of hardboard and had them cover that...oh well.
Everything is in, I just need someone to come by with a spare set of hands to help me tighten the seat down. I can only do so much by myself!!
Had some satin paint that matched the seat pretty well, used that on the plastics. I think it's about ready for a drive!
1991 Z/28, 6.0L/T56
Old 03-08-2020, 02:05 PM   #282
joedoh
joedoh's Avatar
very very classy!
Old 03-08-2020, 02:30 PM   #283
OutlawDrifter
Thanks Russ!
1991 Z/28, 6.0L/T56
Old 03-09-2020, 02:21 AM   #284
Rusti
Rusti's Avatar
Hallo.
Grate interior work! Looks verry clean and comfortable. By the way what type of steering wheel are you useing?
So long Arnd
Rusti is offline   Reply With Quote
Old 03-09-2020, 09:31 AM   #285
OutlawDrifter
Originally Posted by Rusti View Post
Hallo.
So long Arnd
Thank you!
It is a 1940 Ford Deluxe steering wheel.
1991 Z/28, 6.0L/T56
Old 03-09-2020, 10:32 AM   #286
8man
That interior really looks good!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 03-09-2020, 10:50 AM   #287
OutlawDrifter
Thanks Robert!
1991 Z/28, 6.0L/T56
Old 03-28-2020, 02:27 PM   #288
OutlawDrifter
Half springs work great! No more wheel hop, just tire smoke and noise.
I moved my coils off the firewall, put them under/behind the air cleaner. Gives it just a touch more SBC flavor.
I've been unhappy with the brakes since I put the truck together. Finally decided to take the one size fits all proportioning valve off. Without a good bleed on the brakes, they are better for sure. I don't know if I got a bad valve, or it just didn't work with my setup. I did put an inline proportioning valve on the back brakes. This valve will also close all the way off and let me destroy back tires without worrying about the brakes. Probably need to find some cheap tires to put on the stock S10 steelies I have.
Cab weatherstripping, window channels, and carpet have made a huge difference in the cab noise. Driver's door is still sprung, so I still get some noise towards the upper part of the door near the back of the cab, overall a huge improvement.
Hope everyone is staying home and healthy!
1991 Z/28, 6.0L/T56
Old 03-28-2020, 05:19 PM   #289
joedoh
joedoh's Avatar
squeakin gets the greasin, glad you are driving and fixing! looks great marc!
Old 03-28-2020, 05:23 PM   #290
Richard2112
Richard2112's Avatar
Wow! Nice project
Richard2112 is offline   Reply With Quote
Old 08-17-2020, 09:51 AM   #291
OutlawDrifter
Time for an update.
I daily drove the truck for a couple of months, before the weather got too hot. Totally enjoyed it, and it performed flawlessly.
AC is still not done, that got put on the back burner with all the 'rona. I just need the under dash unit, a line set, and the bracket for the compressor, and I can finish it...maybe this Winter when I'm bored. ICT Billet just released a new tight fit compressor 7176 compressor bracket that might clean up my install.
One Saturday I had the Camaro out and noticed it had a puff of smoke when rev'd up. Decided the rings needed some attention, so I threw a can of Kreen in it and all is well, decided the '49 could stand for a cleaning as well. This product amazes me how well it scrubs the inside of an engine! Anyways, back to the story...I was changing the oil in the '49 this weekend and had it back up in the air idling, looking for leaks. Well it was profusely leaking fuel down the back passenger side of the block! Turns out the hose end AN fitting on the fuel rail crossover had sprung a leak. I'm glad it happened on the lift and not going down the road!!! New chunk of hose, and all is well with the world again.
1991 Z/28, 6.0L/T56
Old 08-17-2020, 10:37 AM   #292
joedoh
joedoh's Avatar
wow that was a lucky find!
thanks for the update, I was wondering how things have been going with francis! thanks for the heads up on kreen too, I have a ticky lifter on the 2500hd, otherwise no problem. dads old truck so he used shell (dealer) oil in it for a long time.
Old 08-17-2020, 10:43 AM   #293
OutlawDrifter
No joke, Russ! Fire is cool and all, just not when its engulfing my vehicles...
Since getting rid of my late model F150(Picked up a GMT400 K2500 454 Suburban as a replacement, cause you know...that's practical), I have been without a pickup bed other than Francis, so I've been shuttling gas cans and other assorted pickup bed duties with the 'ol truck.
1991 Z/28, 6.0L/T56
Old 08-17-2020, 11:02 AM   #294
joedoh
joedoh's Avatar
I bet that gas gauge swings like a vacuum gauge.
Old 08-17-2020, 11:15 AM   #295
OutlawDrifter
Haha, 44gal tank, you don't feel the pain until you put in 27gal when it registers a 1/2 tank.
1999 with the Vortec 7.4l...I have seen 13+mpg all interstate....usually around 11.2-11.5 back and forth to work. Its the smiles per gallon that matter though...right?!
1991 Z/28, 6.0L/T56
Old 08-17-2020, 11:32 AM   #296
joedoh
joedoh's Avatar
i had a 99 suburban, 2wd though, with a 350 vortec. it actually got in the 20s on the highway! victory red!
never should have GIVEN IT AWAY. I saw it a few years ago, trashed of course as all gifts end up.
Old 12-14-2020, 10:57 PM   #297
Nchristi
Truck looks awesome man. I’m about to finally get my butt in gear and start working on mine again. I’ve got a 53 gmc I’m putting on an s10 frame with 2” drop spindles and 3” rear blocks. I’ve got a 6.0 and 4l80 I’ll be putting in it. I’ll be using skymangs cab mount design. What type of motor mounts did you use? I’m trying to figure out the correct ones that won’t interfere with the steering column. Also what type of headers are you running?
Nchristi is offline   Reply With Quote
Old 12-14-2020, 11:07 PM   #298
OutlawDrifter
Thanks!
I used Speed Engineering build your own mounts. Welded them in. I'm running modified factory truck manifolds.
1991 Z/28, 6.0L/T56
Old 12-15-2020, 12:41 AM   #299
lower50's
lower50's's Avatar
Sounds like you had an enjoyable summer driving the truck, glad its working out for you.
Who really cares about fuel mileage driving there cool old vehicle. If it bothers you, go get in your new 4 cylinder appliance and drive to walmart. LOL
1951 MG TD
Old 12-15-2020, 08:46 AM   #300
OutlawDrifter
Thanks lower50s!
I don't bother myself with trivial things like fuel economy.
I like to drive vehicles that you have to turn and look at as you're walking away
1991 Z/28, 6.0L/T56
