Old 12-22-2017, 05:27 PM   #276
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: "Elwood" the 77_remix
Originally Posted by UKNOWME View Post
Damn that seat is sweeeeeeet! I that means a lot because I don’t typically like red interior.
I had originally planned to go with a buckskin color. It seemed as if every project I looked at was going with a tan color. I decided red was traditional, and should never go out of style.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-22-2017, 10:23 PM   #277
85supersierra
85supersierra's Avatar
Great work man. Maybe its just the camera angle but it looks like the shock mounts hang really low. How much ground clearance do you have?
85supersierra is offline   Reply With Quote
Old 12-23-2017, 12:27 PM   #278
N2TRUX
Happy to be here
N2TRUX's Avatar
They lower mounts do extend down quite a bit. When I first saw them I was concerned too. The folks at Ridetech assured me there is no scrubline concern.
Articles-
"Refining Sierra"
Old 12-23-2017, 12:31 PM   #279
N2TRUX
Happy to be here
N2TRUX's Avatar
Friday a received my shipment from RideTech. They included the rear swaybar and additional fitting for the air system.
Articles-
"Refining Sierra"
Old 12-23-2017, 01:42 PM   #280
N2TRUX
Happy to be here
N2TRUX's Avatar
I mocked up the swaybar and measured for center. I snugged the bolts down and marked the bottom brackets. These will be welded on later. The lower swaybar bracket is the only part of the 4 link kit that's not bolt on .
Articles-
"Refining Sierra"
Old 12-24-2017, 10:54 AM   #281
N2TRUX
Happy to be here
N2TRUX's Avatar
Saturday morning I moved closer to getting Elwood back on the ground. Chris had stripped and painted the gas tank. It was time to get it installed.
I removed the filter and pump to prep the inner frame for paint. I painted the pump cast iron and added more satin black to the frame
Articles-
"Refining Sierra"
Old 12-24-2017, 10:59 AM   #282
N2TRUX
Happy to be here
N2TRUX's Avatar
While the frame dried I added sound deadner to the support straps on the gas tank. It makes a great replacement for the factory insulation.
Articles-
"Refining Sierra"
Old 12-24-2017, 11:06 AM   #283
N2TRUX
Happy to be here
N2TRUX's Avatar
After the frame rails cured I concentrated on the fuel lines. When Roger did the Ramjet install he used Parker push-lok fittings and hose. It's great stuff, but it's meant to stay on once installed. It requires surgery to remove it, so I replaced all of the fuel lines.
Once the layout was determined I cut the hose to length and added fuel injection style hose clamps for added security.
Note that loose wire you see is a ground wire. I decided to run it to a different location.
Articles-
"Refining Sierra"
Old 12-25-2017, 12:15 PM   #284
N2TRUX
Happy to be here
N2TRUX's Avatar
Christmas eve was productive for me. We aren't hosting the family this year so I spent my day in the shop.
With The fuel system done I moved over to the air supply side. The RideTech Big Red valves will stay but the frame needed painting and lines rerouted to accommodate the changes.
Articles-
"Refining Sierra"
Old 12-25-2017, 12:53 PM   #285
N2TRUX
Happy to be here
N2TRUX's Avatar
When Roger at RPL Customs installed the system years ago, he made this cool plate to mount the valves one. All it needed was a clean up and fresh paint.
With the valves out of the way, I prepped and painted the frame. While it was curing I worked on the Big Red valves. All that was needed was a good cleaning before I updated the pressure fittings.
Articles-
"Refining Sierra"
Old 12-25-2017, 02:06 PM   #286
Rickysnickers
What kind of paint are you using for the frame and other parts? On a side note, there's a '74 stepside I have been watching. I'm thinking about selling my '57 and my Toyota and buying it. I won't have to smog it and I'll still have a hot rod.
Old 12-26-2017, 10:24 AM   #287
N2TRUX
Happy to be here
N2TRUX's Avatar
I use Krylon satin black on all my parts. Its durable, affordable, and easy to touch up.
Articles-
"Refining Sierra"
Old 12-26-2017, 07:27 PM   #288
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking great man. I like it a lot
--Josh
Old 12-26-2017, 08:00 PM   #289
st1
st1's Avatar
Really nice. I love that you are explaining as you go. I never seen that heat shield before. Thanks for sharing and awesome work.
stone sends...
78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201)
06 Dodge Charger Daytona R/T
05 Suzuki GSX-R 1000
st1 is offline   Reply With Quote
Old 12-26-2017, 10:34 PM   #290
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks guys.
Articles-
"Refining Sierra"
Old 12-26-2017, 10:46 PM   #291
N2TRUX
Happy to be here
N2TRUX's Avatar
While waiting on paint to dry I worked on the gas tank shield. I tried cleaning it up, but it was too scuffed to leave raw. I decided a light coat of undercoating would give it enough texture to cover the scratches in the plastic. I followed that up with a satin black. Its amazing how the texture changes the color. Both the tank and the guard are painted the same color.
Articles-
"Refining Sierra"
Old 12-27-2017, 10:28 AM   #292
N2TRUX
Happy to be here
N2TRUX's Avatar
With the tank shield done, I moved back to the RideTech Big Red valves. Part of the updates will be replacing the Ride Pro E3 system with the new Ride Pro X air management.
I will document the entire Ride Pro X installation once I move inside the cab. For now I wanted to replace the E3 pressure sensors with the new Ride Pro X sensors. I unscrewed the old sensors and bagged them up. I cleaned the threads with a brass brush and installed the new sensors.
Articles-
"Refining Sierra"
Old 12-27-2017, 11:42 AM   #293
gringoloco
A guy with a truck
gringoloco's Avatar
Looking good as always.
I had a thought when I was looking at your calipers: custom ELWOOD logos in the WILWOOD font would be super trick, but subtle enough that most wouldn’t notice
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-27-2017, 12:19 PM   #294
N2TRUX
Happy to be here
N2TRUX's Avatar
Its a good thought, but Wilwood might not appreciate that since they are a sponsor.
I will find a way to get "Elwood" on the truck somewhere.
Articles-
"Refining Sierra"
Old 12-29-2017, 11:15 AM   #295
N2TRUX
Happy to be here
N2TRUX's Avatar
The valves were mounted in place tucked up on the side of the frame. I cleared all of the wiring away and concentrated on the air lines first. The supply line from the tanks needed to be replaced so it was first. Once it was safely routed I adjusted the remaining lines and secured them.
Articles-
"Refining Sierra"
Old 12-29-2017, 11:25 AM   #296
N2TRUX
Happy to be here
N2TRUX's Avatar
Unfortunately you cant always run the air line exactly like you want since its rather rigid. I had to go around a body mount to get to the rear of the truck. I was concerned that this location might come close to the exhaust so I created a heat shield. I found a bracket that I had saved and cut it down to fit in front of the body mount. The air line tucks behind it and its now protected from exhaust heat.
Articles-
"Refining Sierra"
Old 12-29-2017, 12:43 PM   #297
lolife99
67-72 parts collector,…
lolife99's Avatar
Ken have you ever used these Parker elbows? They make sharp turns really easy. I think I found these on Amazon.
Keith
Convert to disc brakes.
Old 12-29-2017, 12:47 PM   #298
N2TRUX
Happy to be here
N2TRUX's Avatar
Keith, thats what I am using on the air tanks. I plan to switch them on the valve block as well. I just need a functioning system for now.
Articles-
"Refining Sierra"
Old 12-30-2017, 12:28 PM   #299
N2TRUX
Happy to be here
N2TRUX's Avatar
Ironically the fittings I needed to clean up the output lines on the Big Red valve block came in. Of course there wasnt enough room to switch them with the block mounted, so I had to pull it off again.
The ports are 3/8" NPT so the fittings are pretty thick. I removed the old straight fittings and replaced them with 90 degree 3/8" npt x 3/8 ptf elbows. This allowed me to cut about 6" off of the 3/8" air line and tuck it in much tighter.
Articles-
"Refining Sierra"
Old 12-30-2017, 04:42 PM   #300
gringoloco
A guy with a truck
gringoloco's Avatar
Much mo betta! What are you using to protect the lines where they pass through the framerails?
-Chris
