05-22-2019, 08:37 AM | #3051 |
Re: PO has me PO'd
I got rid of my TPI setup and went with a Holley Sniper. I like it.
Might be an option for you? Looks like someone was a little rough on that heater hose nipple... |
05-22-2019, 11:45 AM | #3052 |
Re: PO has me PO'd
I was looking for the cool factor, but you're right , there maybe better systems out there!
Note the red arrow, cracked intake manifold. That's what happens when you use a tapered easy out, I was able to get a hacksaw blade in there to cut some of the threads and roll back the fitting with a punch. Hopefully I can have it tigged Just one of my SNAFUs. on to the shaft bushings for the quadra jet
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-23-2019, 08:29 PM | #3053 |
Re: PO has me PO'd
I seen the crack before the arrow. Hopefully it is a simple weld and good to go.
05-24-2019, 07:48 AM | #3054 |
Re: PO has me PO'd
Installing throttle shaft bushings, grind the staked screws or you WILL snap the heads off. mark blades for location and direction
[url=https://flic.kr/p/2g1QCQu]20190523_093722
05-24-2019, 08:05 AM | #3055 |
Re: PO has me PO'd
referance pics
[url=https://flic.kr/p/2g1QBNq]20190523_085540 [url=https://flic.kr/p/2g1Rqrf]20190524_070829 Notice 4 snapped screw heads, you would've thought I would have stopped and checked after one
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-24-2019 at 08:23 AM. |
05-25-2019, 03:18 PM | #3056 |
Re: PO has me PO'd
very little wear on the shafts, can't feel it with your fingernail
[url=https://flic.kr/p/2g2kpzA]20190525_081428 baseplate was cooked in my ultra sonic bath, at low temp, with purple power, changed to aluminum to a slate grey
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-26-2019 at 07:50 AM. |
05-26-2019, 07:46 AM | #3057 |
Re: PO has me PO'd
[url=https://flic.kr/p/2g2UuTv]20190526_063805
Be careful!, what appears to be a slotted screw is not, just a spring holder in the slot. The silver screw does come off for disasembly. In my application both shafts had to come out for the bushing kit to be used these shafts are very delicate, so don't force things when you disassemble
05-26-2019, 08:21 AM | #3058 |
Equal opportunity joke ofender
Re: PO has me PO'd
Still Waaaaay more patience than I have bud. I have none when it comes to carb rebuild or all that wiring you were doing for the other style. I am gritting my teeth not really wanting to do a harness upgrade on my panel even though I know it should be done.
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
05-28-2019, 09:21 AM | #3059 | |
Re: PO has me PO'd
Plus he's trying to paint his house this summer and I don't want to tie up his time... So, the ball is back in my court and I will continue to muddle along, carb is kinda fun, have an extra carb for reassembly help Bought the re-bush kit from cliff rugles, plus his forum helps with info...... Thanks for all your help over the years of this build
06-10-2019, 07:32 AM | #3060 |
Re: PO has me PO'd
[url=https://flic.kr/p/2gadD1T]20190606_162033
shifter is running, just some tuning left [url=https://flic.kr/p/2gadJmz]20190606_161944
06-10-2019, 08:37 AM | #3061 |
Re: PO has me PO'd
[url=https://flic.kr/p/2gadJqc]20190606_162049
I just want to get my kicks before the whole sh!t house goes up in flames
06-10-2019, 09:40 AM | #3062 |
Re: PO has me PO'd
Is that a 250cc on there?
06-11-2019, 08:29 AM | #3063 |
Re: PO has me PO'd
no, just a 125cc, still pretty quick for a 67 year old, with your butt 1" from the ground
06-19-2019, 06:05 PM | #3064 |
Re: PO has me PO'd
Date with the eleltrical shop, July 8 2019
I give up
06-19-2019, 07:32 PM | #3065 |
Re: PO has me PO'd
The kart does look like a blast.
You are going to have them wire up the FAST fuel injection? |
06-21-2019, 07:08 AM | #3066 | |
Re: PO has me PO'd
[url=https://flic.kr/p/2ghDpBP]20190621_065354 second attempt, maintained with trickle charger for 5 years and battery still failed...trying Genius this time, maintenance charger I wonder if I can replace bad cell on the old battery we're still driving on a country road, so I'll have to wait until I can get it on a track to see how it really preforms
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-21-2019 at 07:21 AM. |
06-21-2019, 07:38 AM | #3067 |
Re: PO has me PO'd
Is a dual battery hold down clamp differant then a single battery hold down clamp
[url=https://flic.kr/p/2ghEj2x]2019-06-21_07-34-16
06-25-2019, 09:28 PM | #3068 |
Re: PO has me PO'd
No way dude. Don't give up on it Jim. I've taken a ridiculous numbers of steps backwards on mine over 11 years. You've done so much. Don't farm it out now. Take a break, come back to it. Keep making progress.
06-26-2019, 07:07 AM | #3069 |
Re: PO has me PO'd
AJ, thanks for posting up, but time is my constraint, I'm 67 going on 68 in August, and I'm afraid I won't get to drive it much as I get older. So, I've made the choice to get it worked on by someone who understands the system...
For me, it's like putting a string on a yo yo, when you don't know what a string or yo yo is or does, it just doesn't make sense to me, and trust me when I say I've tried, I've sourced, I've read, sourced, and read some more, gleamed thru countless wiring diagrams, to no avail. If someone had done this before, I would have been able to ask questions, but no one has You've been a great source of info. over the years, and I consider you my friend, sorry to let you down, but it just has to be this way
06-26-2019, 08:58 AM | #3070 | |
Re: PO has me PO'd
I totally get the aspect of wanting to drive it. Get it done and get in the driver's seat. Keep us posted. |
06-26-2019, 09:28 AM | #3071 | |
Re: PO has me PO'd
As I told you before you have stuck at it way longer than I would have ever dreamed of doing. I can't say that I would have ever tried it so mad props to you for going as far as you have with it.
06-28-2019, 07:38 AM | #3072 | |
Re: PO has me PO'd
BTW, have'nt seen any kids playing with yoyos lately for me to ask, if you do, get me an email addy [url=https://flic.kr/p/2gmfJPn]20190628_075541
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-28-2019 at 08:02 AM. |
06-28-2019, 08:12 AM | #3073 |
Re: PO has me PO'd
[QUOTE=jaros44sr;8549678]Richard, got the battery hold down yesterday, thank you. Can I at least pay for postage and paint?
BTW, have'nt seen any kids playing with yoyos lately for me to ask, if you do, get me an email addy QUOTE] Jim Glad it arrived. No need, consider it a small contribution to the build. TBH I probably would need help with the yoyo nowadays lol Richard
06-28-2019, 08:28 AM | #3074 | |
Re: PO has me PO'd
posted by not a spring chicken, what ever that is
06-28-2019, 08:34 AM | #3075 | |
Re: PO has me PO'd
[quote=richard2717;8549687]
