Closed Thread
Old 01-10-2016, 10:27 AM   #3126
Possmguts
Possmguts's Avatar
Re: What did you do to your truck today? Chapter II
converted the column from a shift on the tree auto to a floor shift column, tore it completely down, cleaned everything, re-greased, and painted.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 01-12-2016, 09:45 PM   #3127
justinl6050
wish i had time and money to finish my truck
justinl6050 is offline
Old 01-13-2016, 12:06 AM   #3128
mud.man.rj
mud.man.rj's Avatar
Time and money aside, looks like you have a great start..
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 01-13-2016, 12:21 AM   #3129
toolboxchev
I swiped some of the rain soaked moss that wants to etch into my stock 46 year old paint. It is starting to get black mold spots growing into pin holes in the paint.
Ah Yeas, time and MONEY to finish my truck.
toolboxchev is offline
Old 01-13-2016, 08:15 PM   #3130
Econman
Econman's Avatar
Media blasting was done on my cab, so I rolled the chassis out to deliver it to the body shop to mount the cab and get them started on metal repair... It's amazing what blasting uncovers...
Econman is offline
Old 01-13-2016, 09:31 PM   #3131
hayhauler71
hayhauler71's Avatar
4 new tires and lowered it
Fuzzy
hayhauler71 is offline
Old 01-13-2016, 09:35 PM   #3132
flashed
Damn ,that looks good ,I love that orange .
flashed is offline
Old 01-13-2016, 09:48 PM   #3133
hayhauler71
Fuzzy
Old 01-13-2016, 11:24 PM   #3134
mud.man.rj
mud.man.rj's Avatar
Truck sits nice, also looks like a bit of tire on the back in the 2nd shot, orange is cool..
5.0 4spd std.
7" lift w 35's.
Old 01-15-2016, 01:15 PM   #3135
zellway
zellway's Avatar
Getting around to the heart transplant in my 67.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 01-16-2016, 02:37 AM   #3136
OregonNed
OregonNed's Avatar
Tonight I put on a new hood to cowl seal from GMC Pauls. Very impressed with the quality as well as the way it fits.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 01-16-2016, 09:14 AM   #3137
Econman
Econman's Avatar
Ordered a new inner cowl, a couple of cab supports and rocker panels from Cooper Restorations. Thanks, Jeff!
Econman is offline
Old 01-16-2016, 11:17 AM   #3138
Possmguts
Possmguts's Avatar
Installed the rear sway bar... Anyone know what shocks I should be using up front with the 5.5 inch drop?
Old 01-16-2016, 02:04 PM   #3139
zellway
zellway's Avatar
Looks like a clean setup. What brand is that swaybar? Looks like it would need the bed removed to install it.
Erik
zellway is offline
Old 01-16-2016, 02:09 PM   #3140
Possmguts
Possmguts's Avatar
You would have to unbolt the bed and lift it on on blocks a few inches... Its a No Limit sway bar
Old 01-16-2016, 02:33 PM   #3141
zellway
zellway's Avatar
I will check it out. Might be a option for one of my trucks but I want to get one for my Suburban. I have been looking at a few different setups. When you get some road test time please let us know how it works for you.
Erik
zellway is offline
Old 01-16-2016, 02:37 PM   #3142
Possmguts
Possmguts's Avatar
I would love to report on it, but its gonna be a while...
Old 01-17-2016, 03:52 PM   #3143
fleetimus
fleetimus's Avatar
Replacing a heater/ac lever, replaced gas sending unit. Trying to get the fan switch working on all three speeds. 71 C10
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline
Old 01-17-2016, 06:30 PM   #3144
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I've done next to nothing over the last two months. Football season nearly over, it's getting warmer and I'm anxious. Can't wait to get to the front end and engine compartment. Will be a breeze after dismantling the cab.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 01-17-2016, 06:30 PM   #3145
71CHEVYSHORTBED402
Done next to nothing over the last two months. Football season nearly over, it's getting warmer and I'm anxious. Can't wait to get to the front end and engine compartment. Will be a breeze after dismantling the cab.
Tony
Old 01-17-2016, 09:33 PM   #3146
XwalkerX
changed the oil with some mobil 1 10w30 and a AC delco filter
then installed some of the parts i have laying around:
3 point seat belts
door frame rubber grommets
gas tank carpet
new ignition bezel
XwalkerX is offline
Old 01-17-2016, 10:18 PM   #3147
68 Stepper
Put a coat of paint on the upper control arm and cross member. Used POR15.
68 Stepper is offline
Old 01-17-2016, 11:15 PM   #3148
greywurm
Finished redoing motor and transmission mounts... Now that its all tightened up, got a pretty good shake going when sitting at red lights. Grrrr
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350
06 Yukon XL Denali - Stock
greywurm is offline
Old 01-19-2016, 07:26 PM   #3149
Ken B
I know a lot of guys like factory seat covers. I do as well but I work for a leather company that sells only the highest quality leathers so that is what I went with. This past weekend my upholstery guy finished my seat so I added new rubber floor and new sill plates as well. I also added a new shift boot as mine was torn, Its surprising how much quieter it is in my truck!
Ken B is offline
Old 01-19-2016, 08:08 PM   #3150
Possmguts
Possmguts's Avatar
I was gonna go out and see what I could get done... but then out of nowhere a 3 hour nap happened...
Closed Thread
