06-25-2006, 06:39 PM | #301 | |
Re: Project Penicillin~ 68 crewcab build up!
06-25-2006, 09:11 PM | #302 |
Seats are done and mounted. The rear seat has a little problem of wanting to flip up All mounts are built out of 1/8" and 3/16" plate and have welded nuts for mounting ease. The rear also has two slide in mounts just below the rear window that the back of the seat drops into. It can not be a bolted mount since when you flip the seat up the back rest moves due to a cam type lock system.
Kevin LFD Inc. |
06-25-2006, 09:15 PM | #303 |
Final shots for now! More to come after a few other projects get their turn.
The center bracket is for the child seat mounts. The drivers side mount had to be sectioned 1 3/4". Kevin LFD Inc. Last edited by Rokcrln; 06-25-2006 at 09:16 PM. |
06-25-2006, 10:22 PM | #304 |
Cool!!!!!!!!!
67- 72 Parts collecter |
06-25-2006, 10:40 PM | #305 |
Kevin,
Looks good, the extended cab rear seat seems like it was made to fit in the truck if GM had ever made a truck like this from the factory. I like the fact that the seat folds up against the back of the cab when it is not in use. Thanks |
06-27-2006, 01:10 PM | #306 |
Jamie Hyneman is my twin
I've been gone for a while, and that was the best three pages I've read all summer. What a fantastic job you do Kevin. You are a hero to just about everyone on the forum.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
06-27-2006, 07:23 PM | #307 |
couple quick questions:
has anyone ever tried the ext. cab rear seat as their primary cab seat (single cab?) i think they are usually "thinner" seats, perhaps allowing for more tummy/leg room? any thoughts? would they be comfy?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
06-27-2006, 09:18 PM | #308 | |||
Union Electrician
cstanley, that is a good question, one that I would like to have answered as well. I am over 6'3" and don't have a tummy(180 lbs.), but my legs/back start to hurt after a while of being kinda cramped in the stock bench seat.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
06-27-2006, 10:52 PM | #309 |
Nothing clever
this is great stuff (not that I can do anything with it) I am currently looking for someone to do some work like this in the South Bay area of Los Angeles. Anyone?
Got "the Midas Touch!" |
06-27-2006, 11:14 PM | #310 | |
Do not even think about it! The back of the seat is non adjustable and very up right. The seat bottom is flat and short so the back side of your thigh would be very sore after a short drive. It is fine for a back seat that you know going in the back door that it is not as good as a front seat. But I really think it would make for a bad front. Also it must fasten to the back of the cab so you would need to have the gas tank somwhere else. Just my $.02 but I have thought about it and long since forgot about it as well! Kevin LFD Inc. |
07-10-2006, 12:18 AM | #311 |
rokcrln......what frame was used? is it extended? where? thanks..
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
07-10-2006, 09:54 PM | #312 |
Old School, New Style
Whats new?
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
07-15-2006, 03:09 PM | #313 |
As of now the truck is gone! It will be getting media blasted and sealed then come back to my shop in a few months. Right now I am finishing up a few things on his extended cab (roof, frame, seats, extended rockers and cab corners. Then starting next week will be the start of project Lemon Drop a sweet 68 step side show truck!!! It will be getting all metal finished and ready for paint.
Kevin LFD Inc. Last edited by Rokcrln; 07-15-2006 at 03:10 PM. |
08-22-2006, 09:43 PM | #314 |
KIDHLR
Sweet build we look forward to the return of project penicillin!!!
Christopher Johnson Project - Grafted In AKA the "KIDHLR" Conversion - KIDHLR Meets LPG KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup) Romans 11:17-22 "Branches were broken off so that I could be grafted in" Last edited by chris@bigjranch.com; 08-22-2006 at 09:48 PM. |
08-27-2006, 11:54 AM | #315 |
what did your wheelbase end up at, and some of the best work i have seen.
09-12-2006, 06:36 PM | #316 |
Here ya go, here is a pic of mine in case you need some motivation...lol......
72 Chevy 4x4 SWB crewcab TPI Vette 350 700r4/205 x-fer 4" lift 35" Swampers/Weld wheels 98 grey Suburban interior Black-n-Beautiful 1970 K5 Blazer Bend, Oregon ------------------ |
09-12-2006, 07:22 PM | #317 |
Does the 4TH door open? Did the build include using a Suburban? Is it a long bed or short? It looks like a short bed to me but I have been wrong before. What frame are you using and what engine and trans? I am getting ready to do some more work on the crew cab just my daughter having kids makes it tough.
09-12-2006, 07:31 PM | #318 |
09-12-2006, 10:12 PM | #319 |
PROJECT 7DEUCE
Sweet looking truck looks like a sub donated the cab portion and the rear door looks like it works very kool..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-12-2006, 11:20 PM | #320 |
09-13-2006, 12:09 AM | #321 |
72 crew...did you buy this back...Jeff told us he sold it on ebay??
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
09-13-2006, 09:01 AM | #322 |
Chief Honcho In Charge
This should be stickied.
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
09-13-2006, 09:31 AM | #323 |
What is post tools...is there a web address?
09-13-2006, 09:43 AM | #324 |
Wasn't that truck on ebay not too long ago?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
09-13-2006, 10:04 AM | #325 |
No I didn't buy it back, he sold it on Ebay, I built it though, can't remember the wheelbase, was on a stock 72 Suburban frame, stretched it about 24" and cut about a foot off the rear. 4th door was a dummy door, look at my signature to see what I was running in it.
