09-08-2009, 11:48 PM | #301 |
Re: Project: Bad Bagged '68.5
i have to agree
http://www.tandscustomcars.com/ My Quad Cab build:http://67-72chevytrucks.com/vboard/s...d.php?t=352342 IT"S GOT A ROOF NOW WHOO HOO!!!! 65 GTO Build (If you wanna check it out) http://67-72chevytrucks.com/vboard/s...40#post4503040 |
10-07-2009, 10:37 PM | #302 |
Here's a little progress. The major project I still am in the middle of is the firewall. I think I'm going to do it completely smooth. There are just too many variables with me to do a bead roll in it. So here are the steps I took thus far:
before shot: Step one was to remove the top of these supports. Then I cut along this seem and left all the spot welds intact. Here is the whole thing out. I then proceeded to cut away about 6 inches of the pinch weld at time and welded it back up. Here is a shot of it completely welded up. In order to mate up a new piece of sheet metal, I bent the bottom lip. This is how I did it. Yes, those are from wonderful Harbor Freight! |
10-07-2009, 10:43 PM | #303 |
Three more pics of the hardlines. I am now completely finished with those. This pics shows the two tanks connected and the check valve.
I didn't think about hardlines when I did the panhard bar, but somehow, it magically worked out. |
10-07-2009, 10:46 PM | #304 |
Here are two pics of the rear brakes mocked up. These are Summit brand kit that is actually SSBC. They are for an impala which has a 5x5 bolt pattern. I just had to make a new caliper bracket and they worked perfectly.
10-07-2009, 11:28 PM | #305 |
p/n?
10-08-2009, 12:18 AM | #306 |
10-08-2009, 01:49 AM | #307 | |
It'd be alot cooler if you did
I vote single or smooth. I also think that if you are to do one on the driver side it should be reciprocated on the passenger side. |
10-08-2009, 09:48 AM | #309 |
Thanks. Good info for future reference.....
10-10-2009, 09:47 PM | #310 |
SWEET!!!!! Its all in the details!!!! Great Job!
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold Last edited by abadsvt; 10-10-2009 at 09:51 PM. |
10-11-2009, 01:12 PM | #311 |
I wish i had just done that for the firewall... nice work so far!
Bagged/Turbo 1970 GMC C-10 Crew Cab 1984 Chevy R-20 |
10-30-2009, 09:30 PM | #312 |
Got the firewall pretty much done. Have to plug some holes and deal with the floor supports, but other than that, its done.
I did this in two sections just so it would be easier to work with. Here is the driver side tacked in place. Here it is primed. Here here it is complete. It looks a little plain-jain, but once everything is together and the motor is in, I think it will look nice. Here is one last random picture of a patch panel I made. Last edited by jlaird; 10-30-2009 at 09:32 PM. |
10-30-2009, 10:12 PM | #313 |
One day...
Man that's coming along nicely! Awesome work
10-30-2009, 10:21 PM | #314 |
Well, that turned out nice!
10-30-2009, 10:51 PM | #315 | |
btw - how do you like my new avatar? Much closer to the final look.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 10-30-2009 at 10:56 PM. |
10-31-2009, 10:18 AM | #316 |
looking good!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
10-31-2009, 11:38 AM | #317 |
67cheby
DETAILS is what wins shows and respect, my hats off to you nice work !!
10-31-2009, 12:28 PM | #318 |
Sunburst C10!!!
wow that looks good
Gage 1967 C10 Shortbed Stepside |
10-31-2009, 10:02 PM | #319 |
VA72C10
Looks good. I've got to decide how much I want to shave mine....
Looking for a 67-72 swb or blazer project in or around VA. |
10-31-2009, 10:39 PM | #320 |
Firewall came out nice! Well done.
11-04-2009, 10:01 PM | #321 |
soon to be bagged64sub
Looks good. I think Im gonna do mine like that.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
11-06-2009, 11:33 PM | #322 |
Nice to see another New Yorker. Project looks great!
DROB_NY |
12-02-2009, 04:23 AM | #323 |
Looking great!....Any latest update?
12-22-2009, 11:26 PM | #325 |
Sunburst C10!!!
can ask something
pb dropmember?
