Old 08-28-2010, 07:27 PM   #301
JML55
JML55's Avatar
Re: Lurker OrrieG Progress Pics
I know what you mean, I'm back to square one with my paint job.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 09-01-2010, 12:44 PM   #302
OYMC
Very Cool Build...
Just a suggestion, but you might want to change the position of your upper front shock mount...
It is a very common mistake, but if the lower shock mount does not match the alignment of the top shock mount, your shocks will bind up through suspension travel and cause premature shock failure...
Other than that, keep up the good work!
OYMC is offline   Reply With Quote
Old 09-09-2010, 10:33 PM   #303
OrrieG
OrrieG's Avatar
I'll check it again, you might be looking at a picture of the first install (post 13) where the mounting bolts were not parallel and it was binding. I changed it (post 39)and compressed and expanded it as far as I could. I went out and looked and the upper and lower bolts are close to being parallel. The photos might make them look out of alignment.
OrrieG is offline   Reply With Quote
Old 09-10-2010, 01:30 AM   #304
OYMC
Good deal... It's surprising how many people make that mistake (Myself Included)
Old 09-11-2010, 08:01 PM   #305
OrrieG
OrrieG's Avatar
Yeah - I noticed mine on the first setup when I set the short block to mock up the steering and noticed the front did not drop much. Jacked it up and removed the shock bolts and found the problem. Thanks for the observation, the more eyes the better.
Old 09-26-2010, 03:28 PM   #306
OrrieG
OrrieG's Avatar
Picked up some more primer and the final sealer, base and clear for inside the cab, man paint has gotten expensive. Busy with my Dad's stuff next weekend, but following weekend hope to have the cab interior and firewall painted so I can get it back on the frame and have non-monetary assembly work this winter. Decided to go with GM Silver Birch, goes well with the leather seats I have and the future blue exterior. Get to use my new guns and HPLV for first time, from what I have read should be much easier than my very old pressure gun.
Decided to move the alternator to the driver side so A/C compressor will go on passenger and I can avoid custom A/C lines. Ram horn exhaust works for short water pump but the bracket need slipped forward about 2.75" to work with a long water pump found on 350's. Here is the results, kind of clunky but functional.
Old 09-28-2010, 08:57 PM   #307
munice
regular everyday normal guy
munice's Avatar
Hey, nice build so far! I keep checking back on this one! I've always been a fan of those old rough tread bias plies. (Seems every old car or truck left out in a field is sporting a pair on the back) Are you going to run anything like those again? I've been pondering over getting something like that for my truck, but can't seem to find a tire store that can get anything like those. Keep up the nice work!
cheers, Andrew
munice is offline   Reply With Quote
Old 10-10-2010, 09:44 PM   #308
OrrieG
OrrieG's Avatar
Andrew - will not run the bias tire, to noisey and rough. I toughed it out for about 6 years until they wore out then got a set of new Firestone m/s radials. Was amazed at the difference in ride quality and now quiet they were.
Progress today was good. Got the bed sides, rear inner fenders, bed front panel, dash and firewall primed for the second time. Now it just some blocking and final paint for the dash, inner cab and firewall. New gun is REALLY nice. Had a little hassle getting the air pressure right, but once I figured it out all went well. Also, low pressure left virtually no over spray, I forgot to toss a tarp over my tool boxes, etc. and they and the floor didn't even get dusted.
Old 10-11-2010, 11:31 PM   #309
OrrieG
OrrieG's Avatar
Firewall painted! Used Chassis Black so it will match the inner fenders. Sprayed on undercoating on lower sloped surface and inner fender areas, this truck will see some mud, water and snow when finished.
Old 10-12-2010, 12:04 AM   #310
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
It looks great!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-12-2010, 12:10 AM   #311
sgtusmc
sgtusmc's Avatar
Nice!
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 10-12-2010, 12:17 AM   #312
Kim57
Kim57's Avatar
Looks real nice.
Kim
Kim57 is offline   Reply With Quote
Old 10-16-2010, 01:31 AM   #313
bajabob
bajabob's Avatar
I dig your firewall, mine had a bunch of holes in it and I am still trying to get some of them filled before paint goes on. Nice work.
bajabob is offline   Reply With Quote
Old 10-16-2010, 11:34 PM   #314
OrrieG
OrrieG's Avatar
Yeah Bob, mine had 45 holes from screw size to 1-1/4". Luckily my wife went to stay with my daughter for two weeks when grandkid one was born so I got lots of hours in a short time frame. Took saturday to get to bare metal, sunday to weld up the holes, couple of evening to grind then a bunch of hours with the plastic, sand, repeat routine. I wanted to keep the stock ribs so that at a glance it looks stock, but those who know will know the work that went into it. Next trick is to reroute and a hide all the stuff that in a stock truck goes thru the firewall.
Old 10-16-2010, 11:40 PM   #315
OrrieG
OrrieG's Avatar
I'm stoked. Finally feels like progress. Painted the interior today and I LOVE my gun and these modern paints. You really can't see how deep the gloss is, the dash top sort of shows it if you see the reflection of the plastic sheet. Still need to cut and buff it, but over all not much orange peel. Used Nason sealer and base (2 coats), Dupont Chroma clear (3 coats). Color is GM Silver Birch, turned out exactly like I wanted. Can't wait to drop the leather seats in to see how it matchs. The dots in the pic of the cab back are reflections in the lense, not goobers!
Old 10-16-2010, 11:48 PM   #316
JML55
JML55's Avatar
Nice work.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
Old 10-16-2010, 11:53 PM   #317
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
That looks great!
Tony
Old 10-17-2010, 12:39 AM   #318
Kim57
Kim57's Avatar
Looks very nice.
Kim
Old 10-17-2010, 04:25 AM   #319
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Lookin Good!
ChuckDriver is offline   Reply With Quote
Old 10-17-2010, 02:23 PM   #320
sgtusmc
sgtusmc's Avatar
NOW...that's a dash! Looks really good. I can't wait to see it done.
Old 10-17-2010, 03:09 PM   #321
GeorgeVale
Really nice job looks fantastic love the colour.
GeorgeVale is offline   Reply With Quote
Old 10-17-2010, 08:55 PM   #322
bajabob
bajabob's Avatar
me likes the color and the work......
Old 10-17-2010, 09:04 PM   #323
OrrieG
OrrieG's Avatar
Cab is back on the frame. It is so nice to know that everything I did today was a final bolt in, not trial fitting. Checked the fit around the oil cooler and lines; ok. Checked the HEI; clearance is ok but WTF its crooked! Scratched my head, did I really install the engine out of level? Leveled the frame side to side, checked the intake manifold, right on level. I've been messing with SBC's for 45+ years and never noticed that the dist is NOT vertical because of the gear alignment with the cam. Also tossed in a picture with Ms. Joan my bride of 40 years next year.
Old 10-17-2010, 09:22 PM   #324
masshole
OKGMC4 said it best...this stuff is like porn to us and right now... YOU are the star!!! strong work, keep it up and the pics coming(no pun intended) Greg
masshole is offline   Reply With Quote
Old 10-20-2010, 01:50 PM   #325
bensimmons_05
bensimmons_05's Avatar
These are BIG steps. It is looking AWESOME, keep us all updated!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
