08-21-2007, 11:05 AM | #301 |
Re: Killers 5.3L install
08-21-2007, 07:10 PM | #302 |
A guy with a truck
Hmmm... how are you pulling this one off? Aren't you using plate adapter mounts? Don't they get in the way?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-21-2007, 09:59 PM | #303 |
i had to trim a piece off the compressor mounting bracket, so the head of the bolt wont interfer....i have yet to install or even have a 00 truck compressor, but i looked at one at oreillys and did some measureing... so we'll see how it all works out here real soon...
08-21-2007, 10:11 PM | #304 |
worked on installing the vintage air evaporator unit under the dash today.... thought all i would have to do is fab some mounting tabs and hang it, but for some reason they thought it would be a good idea to prewire everything with about 10 feet to much wire.... its good to have to much wire then not enough, but dang!!..... so after i got it hung i went to work re-wiring the pre-wired harness...as you can see i mounted the relays and circuit braker in a nice and convenient spot, and cut about 9' of wire off and made it more neater....it also doesnt hang down to low to interfer with anything or get in the way of the passenger feet, and it has a factory look to it..
08-21-2007, 10:56 PM | #305 |
what unit are you using? At the rate you're going, I should just send you my Suburban and all the parts and let you finish it, .
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-21-2007, 11:40 PM | #306 |
It's a vintage air generation IV. it's supposed to be there most current and efficient unit to date and is rated well enough to cool a suburban...so you you should definit. check it out! 68 short step doesn't fool around!!! I'm sure killer is beginning to get in the way tho.
R.I.P. Killer 71 10/26/07 |
08-21-2007, 11:57 PM | #307 |
08-22-2007, 12:05 AM | #308 | |
"yelp", i miss my hotrod...pretty boring around here without it...
08-22-2007, 10:13 PM | #309 |
get the interior back together... installed a flameing river chrome /tilt/ auto steering column, looks great, the gear indicator will be switched for a OD one...still working on the wiring .... and mocked up all the hoses for the heater core and a/c, on the inside....
08-23-2007, 12:16 AM | #310 |
sexy...
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
08-24-2007, 12:27 AM | #311 |
ok here ya go gringo the a/c compressor fit, the only clearances i had to do, beside the bracket itself, way the frame so the adaptor fitting will clear.. ill post pics of that when its installed so you can see what im talking about..
08-24-2007, 03:41 AM | #312 |
Wow, what a beauty!!! Great work, great job...she will be stunning when you are finished!!! Fact...she is stunning now!!!
Alex
Alex 1971 Lil' Red 350 SBC 700R4 |
08-24-2007, 10:17 AM | #313 | |
WTB this ad
08-24-2007, 11:27 AM | #314 |
No SEE TEN it's not a sure fit. You can check it out on the home page of va. It's a fly by wire set up...wanted to get away from all the cables and vaccum actuators and so forth...
08-24-2007, 07:45 PM | #315 | |
R
08-24-2007, 08:09 PM | #316 |
That is a good idea.
08-24-2007, 09:26 PM | #317 |
are you going to have to custom-fit a glove box since it's not a sure-fit? or can you use the one from the sure-fit kit?
08-24-2007, 10:18 PM | #318 |
It's looking like i'm not gonna have one...a few ideas have popped in my head as to what we can put there tho. Just gotta check with the BOSS!
08-24-2007, 11:08 PM | #319 |
laughing at myself for I never having clicked on this thread because I thought it was just a 5.3 install... Then I finally said "this must be one sweet 5.3 install to be such a long thread." So I dive in to find some of the cleanest work on the board! Wow
08-24-2007, 11:30 PM | #320 |
WOW...That definitely means something coming from you as 68ss will say the samething. I was wandering earlier if you had checked this build up out! Glad you approve.
08-25-2007, 12:13 PM | #321 |
This build is way beyond what I've done as far as finishing work is concerned. You guys are at the level I'm (and I think most guys are) working towards in that regard. ...and you're doing it all with the quality these trucks deserve. If I could just stop coming up with ideas I might get there Keep it up I'm tuned in now
08-27-2007, 10:30 PM | #322 | |
will do, the kit come with some wrap just for that reason... not foam, but more like sticky 2.5" wide tape wrap.. but is for the same reason.. |
08-27-2007, 10:48 PM | #323 | |
Next project: 1970 K10
Looking awesome 68ss!! You are doing a fantastic job!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-30-2007, 12:42 AM | #324 |
Questionable
any updates?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-30-2007, 12:19 PM | #325 |
Shifty, he's got me where he wants me and makin me sweat these last few ones out!!!!
