01-29-2008, 06:29 AM | #301 |
A guy with a truck
Re: How to: Ruin a perfectly good Blazer...
Thanks! Now I just need 5 more and I'll be at your level
I thought so. I may shave the bumpers down a bit- maybe half height- to give me a little wider opening but still keep it from hitting the core support. Kind of a comfortable median...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-29-2008, 08:13 AM | #302 | |
Kevin LFD Inc. |
02-12-2008, 11:13 AM | #303 |
A guy with a truck
Started dorkin' w/ the rear brakes. Spent most of my time tearing everything apart and cleaning/painting. I figured it was a good time while I was in there to replace bearings/seals.
I am using Glock's brackets, but for whatever reason they are not a 'bolt-on' for me. The bolt heads for the caliper bracket hit the rotor, even after switching to the smaller diameter allen head bolts. The spacing is about 1/2" off from aligning the rotor/caliper correctly. I think my axle/flange spacing is off a little from a 2wd axle, so I will have to modify them to work for me. The last pic is just a mockup showing what they could look like...
02-13-2008, 03:12 AM | #305 | |
Those don't look like the same brackets. You may have the Caprice brackets there. Those look like camaro calipers...? Last edited by Frizzle Fry; 02-13-2008 at 03:14 AM. |
02-17-2008, 04:48 AM | #306 | |
A guy with a truck
02-21-2008, 10:13 AM | #308 |
1972 Chevrolet SWB
Any new progress to report?? Just checking in to get more motivation.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
02-21-2008, 11:05 AM | #309 | |
A guy with a truck
My love lies waiting silently for me... Looks like she's been sippin' the cervezas while I'm away too
02-22-2008, 02:19 AM | #310 |
On the fast track to nowhere..
Looking good Gringo! Don't you LOVE this weather!!!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
02-22-2008, 06:12 AM | #311 |
A guy with a truck
Temperature is great, just wish it would stop raining for more than a day at a time...
02-23-2008, 08:20 AM | #312 | |
02-23-2008, 08:27 AM | #313 |
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
02-29-2008, 09:40 AM | #314 |
A guy with a truck
I did some trading with a boardmember(thanks Shifty) for a mildly used ECE tubular transmission crossmember. I immediately put together plans to hack it to pieces to fit my needs. Unfortunately, ECE uses an oddball size rectangular tubing I could not find locally, so I had to wait for the stick I bought to be delivered.
I started by screwing it down to a piece of 2x6 to keep everything aligned. I then sectioned out the center, with the crossmember flipped upside-down. I made filler pieces out of the 1.5" x 2.5" .120 wall rectangular tubing. After squaring everything up, I welded and ground it smooth. Turned out pretty nice, me thinks... This will put the tailshaft in the proper position for the Dropmember and allow me some clearance for exhaust tubing. I've got plenty of tubing left over- I think I'm gonna build one from scratch for my pickup.
03-01-2008, 10:02 PM | #316 |
A guy with a truck
Thanks! Here's a couple pics of the finished product. You can see that the transmission mounting surface is about 1" higher than stock. Also, the new crossmember does not hang below the framerails at all- the stocker hangs about 1.5" below. With that and the increased exhaust clearance, I'd say this little project is a success...
03-20-2008, 01:26 AM | #318 |
Havent been on in a while, this thing is turning out amazing.. keep it up man, awesome job!!!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
03-21-2008, 09:03 AM | #319 |
I love it, i want one of the PB members for mine, just to many irons in the fire. your ride hight is just sweet. great job. cut it up it feels good
03-21-2008, 06:19 PM | #320 |
03-23-2008, 06:05 AM | #321 |
gringo, Ive got that same crossmember but its from performanceonline.com Why did you need more exhaust clearance? isn't there plenty of room to run it above the x-member? Also, why did you move the mount 1 inch up? I wasnt planning on hacking this thing up.
03-23-2008, 07:32 AM | #322 |
I belive he did it because the DropMember moves the engine up so the tranny needs to move up as well.
Not sorry, this is a full on Hijack! 1lo67 we need more info on your ride. That thing is sweet! Would you mind sharing some pics of your hinge set up and rear latch? Kevin LFD Inc. |
03-23-2008, 04:58 PM | #323 |
its just $$$$$
03-23-2008, 07:32 PM | #324 |
Looking real good Gringo! Keep up the great work.
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
03-23-2008, 07:46 PM | #325 |
Looking real good! Now all you need is a set of these..........
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
