Old 01-16-2011, 05:30 AM   #301
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: 1969 Chevy Stepside Restoration/Build up
Originally Posted by 68GMCCustom View Post
Lookin' great and I really like those GMPP LSX valve covers!
Thanks, I really like those valve covers as well! I think they really set off the engine, looks so much cleaner than with the engine covers I had on the 5.3L.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-16-2011, 11:41 AM   #302
killer71
killer71's Avatar
Nice, clean build up! Good work!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-07-2011, 01:18 AM   #303
whiteyandreddy
Matt, Nice work. I just finished reviewing your build thread. I can't believe how much you get done in such a short amount of time. You're very talented. Thanks for posting your build.
Check out my project: 1972 Chevrolet Stepside- Shortbed
http://67-72chevytrucks.com/vboard/s...d.php?t=392386
. . . . . . . . . . .__
. . . . . ______l__l\___
. . . . .l_[(O)]_____(O)]
whiteyandreddy is offline   Reply With Quote
Old 06-07-2011, 02:36 AM   #304
matthew20061
69' Chevy Stepside
Thanks for commenting haven't posted any updates on the project for awhile! I've got a nice heavy duty sway bar added to the front now and I did some repaint work to the passenger side door to make the truck even nicer!
-Matthew
Old 06-08-2011, 12:04 AM   #305
whiteyandreddy
Good work. May I ask if you have any photos or information on the bed cross sills on the frame? I need a blueprint of which cross sill goes where for a short bed stepside. I am not sure I have the right ones in terms of length or height as I never had the original bed sills. My truck had a piece of plywood in it and I have since collected different sills of different heights. Thanks.
Old 06-08-2011, 01:41 AM   #306
spike38
spike38's Avatar
I've always enjoyed your build. And would like
to see some shots of the sway bar. If you have any pics?
Spike
spike38 is offline   Reply With Quote
Old 06-08-2011, 02:07 AM   #307
matthew20061
69' Chevy Stepside
Got it off of a 3/4 72 and it was a huge improvement handling wise! I'm very glad I added it.
Here's another update ran it at the track a couple weeks ago but the tune is a bit rough so it was running rich and only did a 13.54 at 100. Here's the vid!
-Matthew
Old 06-08-2011, 02:48 AM   #308
spike38
spike38's Avatar
Great videos!
What size sway bar?
And are you planning on a rear bar as well.
Spike
Old 06-08-2011, 03:36 AM   #309
matthew20061
69' Chevy Stepside
Originally Posted by spike38 View Post
Great videos!
What size sway bar?
Spike
I can't remember exactly but I think it might be 1" 1/16? I thought about the rear bar as well but just haven't wanted to spend a ton in shipping to get one up here so it'll stay without a rear one for a while.
-Matthew
Old 06-16-2011, 11:14 PM   #310
lt155ruck
lt155ruck's Avatar
Just went through the entire thread, Very nice looking truck and exceptional work. I might have missed it in the build, but what headers did you use for the Ls swap?
lt155ruck is offline   Reply With Quote
Old 06-17-2011, 02:43 AM   #311
matthew20061
69' Chevy Stepside
Thanks! The headers I used are made by Sanderson for LS1 swaps into s10's and they are ceramic coated. I'm not sure if there the best flowing but they work good enough!
-Matthew
Old 06-17-2011, 10:26 AM   #312
lt155ruck
lt155ruck's Avatar
Thanks for the quick response, was there any fitment issues other than the small amount on the pass side? I'm trying to compile as much info and parts for my 72 blazer
Old 06-17-2011, 12:15 PM   #313
matthew20061
69' Chevy Stepside
No other than that they fit fine in the frame and actually the passenger side may fit without modifying anything. I know there are lots of other headers that are available that fit these trucks as well.
-Matthew
Old 06-17-2011, 12:20 PM   #314
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
definitely traction limited...which is costing your ET. Are you driving thru the water box or going around? I always go around with anything but slicks. I would also recommend a bit longer burnout to heat those tires up a bit more. Otherwise...get your tune right...control the traction issues and you should be deep into the 12's....and as said before.....If I ever get my trans leak/puking problems resolved so I can get mine to the track....'ll be gunning for you! I'm sure I'll have traction issues too until I get some drag radials for the back.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-17-2011, 04:19 PM   #315
ll____b0t____ll
ll____b0t____ll's Avatar
Very respectable truck!
All you need to do is cut them whipper blades from double to single blades and it will run 9's lol.
I kid but yeah nice.
ll____b0t____ll is offline   Reply With Quote
Old 06-17-2011, 08:20 PM   #316
matthew20061
69' Chevy Stepside
Well the only time I've been able to run it yet the track had no prep and they didn't have the water box going. So I just spun the tires a bit to get off any dirt. The second time around I didn't spin them at all and it seemed like I got more traction. I definitely need to get it tuned because its running really rich. I can't wait to see how your truck runs in comparison to mine! I'm sure I'll get there with it eventually.
-Matthew
Old 10-14-2011, 02:27 AM   #317
Hoot71Burb
Do you still have the coil covers for the 5.3l? If so, would you sell them complete with hardware? Nice build! I am building a 69 4x4 with ls1. Taking me a long time as I am not nearly as talented as you!
Hoot71Burb is offline   Reply With Quote
Old 10-14-2011, 02:56 AM   #318
matthew20061
69' Chevy Stepside
I still have them but I was going to keep them for my next build which is a 1957 Chevy Bel Air with a 6.0L swap, after I figure out how to motors going to be setup in a couple months they might be up for sale if you would like I can let you know if I do get rid of them.
-Matthew
Old 01-03-2012, 10:04 PM   #319
cjohnson6772
cjohnson6772's Avatar
I know this was a long time ago, but do you happen to still have this font? Or know where I can get it? I would love to print a new one of these to replace the faded one on my truck. Thanks in advance.
Originally Posted by matthew20061 View Post
Well after restoring my truck it never had the correct "vehicle information sheet" that goes in the glove box that lists the options the truck originally came with. Since my original was long gone I ordered a new one from LMC but it comes as just a sticker. This is a problem, I used some handy photoshop tricks and tapped the new sheet to a piece of printer paper and printed all of the options I wanted to list and my VIN. These are the results:
Sheet:
Finished Product! I found some special fonts that look completely original!
cjohnson6772 is offline   Reply With Quote
Old 05-24-2021, 04:25 PM   #320
Duck1
Update:
Just ordered some stuff for the 5.3L. Got a Cam, Springs, and Pushrods. The cam is from Comp Cams and its their LSR series. The specs are 215/223 .604/.610 112LSA it has a power band from 1300-6500 rpm so they told me I can get by with the stock converter. I also got Comp's 918 spring good for .625 lift. I found some 7.400" chrome-moly hardened pushrods for a good deal to so I got those. Next I'll get the computer tuned for the changes along with some other stuff! Can't wait to hear it once its installed, I'll post pic of the install and video once it runs.
did you use the same guy "Zippy" for the 6.0 cam
Duck1 is offline   Reply With Quote
