Old 02-28-2011, 12:30 AM   #301
bubba327
HOW long until spring??
bubba327's Avatar
Re: Bubba's recycling project
Originally Posted by Alan's Classic View Post
Progress is progress no matter how great or small. Warmer weather is right around the corner. We've been in the 70's here. Not bragging or anything.
Well we did get above freezing today and had no new snow. Slight chance of snow flurries for tomorrow. Weatherman hoping for 40's by Thursday.
I am beginning to under stand the snowbird theory. Father in law says it is really nice in Yuma this week!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 02-28-2011, 12:33 AM   #302
daverod
SSN 706
daverod's Avatar
I don't get it. Sit in the middle of the desert all winter. Not for me. Guess I'm to young. I kinda like the snow. Not the cold just the snow.
daverod is offline   Reply With Quote
Old 02-28-2011, 12:40 AM   #303
bubba327
bubba327's Avatar
Maybe that is why the FOP wander around the desert and collect rocks. Boredom is taking over . Something to do till cocktail time comes around again.
The winter cold is starting to hurt in all the broken and worn out spots in my body. Cannot wait till I turn 50 next year.
Old 02-28-2011, 12:44 AM   #304
daverod
SSN 706
daverod's Avatar
50 in Sept. I feel like I'm 20 though..I'm kinda lucky becuse when I start hurting at work I just going home.
Old 02-28-2011, 04:21 PM   #305
allaboutchevelles
allaboutchevelles's Avatar
Hey guys, I just thought I would let you know its 81 degress here today!
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 03-01-2011, 12:37 AM   #306
Vernski
I hope you get a sunburn ! It's been cold in north Idaho 10*-15* for a week warmed up to low 30*s this week. Come on Spring I've burned up a good share of my wood pile already...Vernski
Vernski is offline   Reply With Quote
Old 03-10-2011, 11:57 PM   #307
bubba327
bubba327's Avatar
Had to deliver some forgotten homework to daughter, and I thought Lola the truck looked pretty dang good, just waiting in the snowy parking lot till school got out!
Old 03-11-2011, 12:17 AM   #308
bubba327
bubba327's Avatar
Size:  33.3 KB Since adding the speakers behind the seat sounded a little muffled , I found a closeout on a pair of Pioneer 4X6 and whipped out some mounting brackets and mounted them up under the dash.
Local member Murdoc had a spare radiator from a truck he was parting out, So I will replace my leaking 2 row core with this 4 row. It holds water and does not leak so far. I spent a couple hours straightening fins. It has 3 weld jobs on the inside tubes from a fan mishap, but seems to be welded securely. Price has yet to be decided, we will see if it works first.
Thanks Murdoc!!!
Everything else around here has needed service or repair also. Yota needed full service and transmission filter,Struts are ordered from NAPA.
Powerstroke needed 75K mile service , transmission service and a howling carrier bearing changed.
Tractors need to get spring service also.
Not enough hours after work all day too....
Old 03-11-2011, 12:25 AM   #309
daverod
SSN 706
daverod's Avatar
Tunes Good idea on the speakers. I've seen them stuffed in the front vents also. What's all the white stuff?
Old 03-11-2011, 12:39 AM   #310
bubba327
bubba327's Avatar
Yeah I have seen the speakers tucked in the vent holes too. But maybe when I change the rockers and the floor pan, I will weld up the vents and add bigger speakers.
Trouble is, we all have big feet around this place and that is a good spot to get the speakers kicked in.
I will not cut the doors!!
I am still trying to get other stuff repaired and serviced so the truck can have the Offenhauser intake and new Holley carb installed. I ordered smaller jets to compensate for the higher altitude, I will also need a different power valve due to my low vacuum(big cam).
I have been reading on the Hydro boost brake system. The booster is plumbed in off the power steering pump and needs no vacuum. GM Astro vans and all diesel trucks have the Hydro booster so the parts are reasonable and plentiful. This may be on the list of things to do also!
Old 03-11-2011, 12:47 AM   #311
daverod
SSN 706
daverod's Avatar
You got a list? Maybe thats my problem I just kinda jump around. That reminds me. I found a 6 lug axle on craigs got to call the guy. It's a 1975 going to look tomorrow.
Old 03-11-2011, 11:22 PM   #312
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Attachment 712065
That's just cool!!
Alan's Classic is offline   Reply With Quote
Old 03-11-2011, 11:43 PM   #313
AmmoSS
IYAAYAS
AmmoSS's Avatar
I don't know, I did kinda like the old speaker box, even though it was a cardboard box!
AmmoSS is offline   Reply With Quote
Old 03-16-2011, 10:53 PM   #314
cokeb
I know Ammoss that was one of the nicer center consoles I'd seen, and now he has gone and ruined the classic look he had going.
Craig
cokeb is offline   Reply With Quote
Old 03-16-2011, 11:10 PM   #315
bubba327
bubba327's Avatar
Are you guys laughing at my cardboard "speaker box" ?????
It served the purpose for a time and the towel over the box hid the speakers from unwanted attention in the high school parking lot.
Crazy spring -it is snowing again,We had 2 inches by noon and all melted by 5:00 pm
It is back in the garage for a couple of days, I changed the oil and went to a 15/40W diesel oil.
I had the electric fuel pump wired to work from an oil pressure switch only, and now the thicker oil holds the fuel pump on after the motor is turned off a little bit too long.
Time to make things right and wire the fuel pump through the key, add a crash safety switch and the oil pressure switch.
I am thinking of adding a primer button in the dash to run the fuel pump to help fill the carb after sitting for a time and when the carb has evaporated the fuel or drained back.
Old 04-15-2011, 12:36 AM   #316
bubba327
bubba327's Avatar
Wow it has been a month since last update. Cannot get the truck back from daughter long enough to work on it.. It has gone 3200 miles since school started back in September.
Daughter has summer weekend job now.. Working at the local Speedway circle track selling tickets and concessions on Saturday nights..
Hope this will include lots of free tickets to the races for Dad..
I now have a lifter clicking at random times after changing the oil to the 15-40 diesel oil. Sometimes in the cold at start-up but not always .sometimes when it is warmed it will click for a while then quit. Wonder if I stirred up some sludge and now have a lifter that is not pumping up??
This might be a job for Marvel Mystery Oil!!
Old 04-15-2011, 12:40 AM   #317
daverod
SSN 706
daverod's Avatar
You need a new truck. one for u
Old 04-15-2011, 12:45 AM   #318
bubba327
bubba327's Avatar
Yeah the 71 is next to be built , but my wife claims it already.. But she also wants a 396 big block in it!!
I am planning a midlife crisis soon. I already have the red Chevelle convertible.. Just need a bunch of gold chains and maybe shave my head and get an ear ring.
Old 04-15-2011, 12:47 AM   #319
daverod
SSN 706
daverod's Avatar
Has'nt she seen the price of gas. If you do all that your going to have trouble with the cops.
Old 04-15-2011, 12:49 AM   #320
bubba327
bubba327's Avatar
I am thinking about an electric truck. Line the bed with batteries and lower it at the same time with the weight.....
Old 04-15-2011, 01:04 AM   #321
daverod
SSN 706
daverod's Avatar
Or a windmill in the bed. That way when you drive the wind would turn it and it could charge your batt. Or better yet just forget the batt. and hook it up direct drive.
Old 04-15-2011, 10:10 PM   #322
allaboutchevelles
oh yeah bubba!! Im needing to see some pics of that CHEVELLE!!! Im getting ready to put some older pics of mine up on here before I tore it down for the rebuild.
Old 04-16-2011, 12:45 AM   #323
bubba327
bubba327's Avatar
oh yeah bubba!! Im needing to see some pics of that chevelle!!! Im getting ready to put some older pics of mine up on here before i tore it down for the rebuild.
A little dusty under the cover , It has a car cover it spends the winter under..
Old 04-16-2011, 12:55 AM   #324
bubba327
bubba327's Avatar
You know , I just realized that I have a three car garage and my Chevelle and my old truck sit inside while my wife's new GMC Yukon and my 2003 F^%D sit out in the weather.. But then my crewcab longbed truck will not fit in the garage anyway unless you leave the garage door open....
Old 04-16-2011, 09:34 AM   #325
allaboutchevelles
WOW nice chevelle. I think I have your cars twin. Mine is also a malibu. check out my build thread, getting ready to post a few older pics.
