Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 01-15-2016, 04:48 PM   #301
rocknss
rocknss's Avatar
Re: Camaro Caliper Brackets
That's why I went the salvage route, so I would have all the e-brake hardware. Because like you when I went looking for the calipers at auto parts stores I had a hard time determining if they came with all the hardware needed for the e-brake. The calipers i found from a salvage yard looked good so I tried them out and they are working great. If you don't want to chance it just pick up a set and use them as a core at a auto parts store. That's what I was going to do.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 01-24-2016, 11:34 PM   #302
crakarjax
crakarjax's Avatar
Is there a writeup on this site of the install of these brackets wirth capipers, lines etc? I'm kind of far out still but want to make sure I know what I'm doing and have the parts before I begin.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-25-2016, 01:31 AM   #303
Captainfab
60-66 Nut
I do not have an installation thread but one of my many customers may have something in their build threads.
Old 02-01-2016, 11:02 AM   #304
nuc_meltdown
nuc_meltdown's Avatar
CaptainFab do you know if any of the 94-96 B body rear calipers will work? I think the buick roadmaster was basically the same car and could probably get those cheaper at a salvage yard vs camaro or impala parts.
Edit!! I stand corrected. The 94-96 roadmasters did not have rear disc brakes .
1963 Chevy C-10 long stepper.
1984 Chevy K-10 lwb
nuc_meltdown is offline   Reply With Quote
Old 02-01-2016, 08:18 PM   #305
kameltoes2015
PM sent to CaptainFab
kameltoes2015 is offline   Reply With Quote
Old 02-02-2016, 01:41 AM   #306
Captainfab
60-66 Nut
The '94-'96 Caprice 9C1's did have rear disc brakes also.
Old 02-03-2016, 08:00 PM   #307
nuc_meltdown
I hope this isn't a dumb question, but it doesn't matter if i have the original 63 rear end or one from a 73-87 for your brackets to work, right? I just have to order the brackets for either the F body or the b body. Thanks.
1984 Chevy K-10 lwb
Old 02-04-2016, 12:29 AM   #308
Captainfab
60-66 Nut
If you have an original '63 12 bolt, you can not bolt on any rear disc brackets. The '63 had backing plates pressed onto the axle tubes. So there is no flange to bolt any brackets to. If you want rear discs, you will have to weld some caliper brackets onto the axle tube. The bolt on backing plates started in '64.
Old 02-04-2016, 09:43 AM   #309
nuc_meltdown
Thanks for clearing that up. I have an 83 c10 that has all the front and the rear end i just wanted to know if it was worth swapping out the rear. I'm trying to locate some rear calipers at this time. When i do I'm gonna buy your rear caliper and power steering brackets. Thanks again.
1984 Chevy K-10 lwb
Old 02-04-2016, 07:44 PM   #310
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I have the setup on two vehicles and it works well. I can answer questions if needed, shoot me a PM if you want details. Park brake works, you have to make some adjustments, but it works. If you do not have calipers, go to the yard and get a set. The new ones do not come with the little hockey pucks and the GM number is absolete. I have ordered from autozone and they did not come complete even though the description said it would be, still didn't have the hockey pucks. I can do pics if needed but please PM me. I am going to change my brake lines to the smaller size for the rear. I think this may make a difference, all new vehicles are like this, so why not. Brakes work with the different brake lines, but it may make them better.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 02-04-2016, 08:20 PM   #311
crakarjax
crakarjax's Avatar
Smitty
What hockey pucks are you talking about?
Old 02-04-2016, 09:12 PM   #312
71meangreenc10
On the bottom of the mounting bracket there is a long bolt, on the bolt there is a round balancing/dampner (looks like a hockey puck) that bolts to it. I got mine from complete assemblies. You won't get it from parts stores.
Smitty
71 C30 Wrecker
Old 02-04-2016, 11:57 PM   #313
Captainfab
60-66 Nut
Have you tried running without those 'dampners'? I just wonder if they are absolutely necessary.
Smitty
Old 02-05-2016, 01:20 AM   #314
71meangreenc10
Nope, never tried.
I get complete assemblies, sometimes you cannot even get the park brake parts from the parts store replacements. Moving the spring to the new caliper is a pain.
Smitty
71 C30 Wrecker
Old 02-05-2016, 02:29 PM   #315
New_70'C10
New_70'C10's Avatar
Okay, I give. I've been looking over the thread and trying to figure out which year Camaro calipers will work with the Rear Disc Brake Bracket kit. I'm sorry if I missed it but if someone can help I would greatly appreciate it.
1970 SWB CST; 307ci, 200-4R, (Slow Motion)
New_70'C10 is offline   Reply With Quote
Old 02-05-2016, 02:53 PM   #316
crakarjax
crakarjax's Avatar
Yeah I feel your pain. 4th gen f-body (up through '97) calipers with '96 Impala rotors I believe.
Glock supplied a parts list with his brackets, let me see if I can find it... attached!
Old 02-05-2016, 04:12 PM   #317
nuc_meltdown
If i go to a yard do i just purchase the caliper or do i need the original caliper bracket too?
The f body calipers come with the e brake inside?
I need the e brake cable and the rear brake hoses?
1984 Chevy K-10 lwb
Old 02-05-2016, 04:24 PM   #318
New_70'C10
New_70'C10's Avatar
Hey, thanks a lot for the list. I'm gonna try to hit the LKQ this weekend and see about getting the calipers before ordering the brackets from the Capt.
Old 02-05-2016, 04:30 PM   #319
71meangreenc10
Yes,
I pull everything I can (except the rotors) and also I take the mounting tab that is bolted to the car for the rubber brake line, comes right off. The camaro calipers have the park brake built with the calipers. I buy new hoses and cables, but it doesn't hurt to have the old ones if needed.
Some parts stores have a sticker that asks for the old mounting bracket in with the core.
Also remember, the Z28's are the only ones that have rear disks, the regular camaro's are drum brakes.
Smitty
71 C30 Wrecker
Old 02-05-2016, 04:35 PM   #320
nuc_meltdown
Ok, thanks. I also wasn't aware the z 28 was the only one with rear disc!
1984 Chevy K-10 lwb
Old 02-05-2016, 05:38 PM   #321
71meangreenc10
You can validate, but every V6 camaro I saw had drums in the back.
Also, looks like Autozone udated their webpage and this is why you need to go get yard parts. I have recieved full calipers with the mounting plate from parts stores and I have also got with the same part number just a caliper.
http://www.autozone.com/brakes-and-t...p-5-7l-sfi-ohv
Here is what you are looking for from a parts store for a complete assembly with mounting bracket.
http://www.rockauto.com/en/moreinfo....035908&jsn=682
This one has the park brake mounting bracket (preferred one to get). Big spring is a pain in the rear to get on if you have to move it.
http://www.rockauto.com/en/moreinfo....035908&jsn=692
Smitty
71 C30 Wrecker
Old 02-05-2016, 05:49 PM   #322
nuc_meltdown
Will calipers on a firebird or trans am from the same period work as well? I figure they are basically the same car under the skin.
1984 Chevy K-10 lwb
Old 02-05-2016, 05:53 PM   #323
71meangreenc10
Rock auto says yes for Firebird. They also list them from 93-97.
Smitty
71 C30 Wrecker
Old 02-06-2016, 01:23 AM   #324
Captainfab
60-66 Nut
Post #11 tells you what year of calipers and rotors you will need.
All of my rear disc brackets come with a parts list as well.
Old 03-04-2016, 04:09 PM   #325
crakarjax
crakarjax's Avatar
I purchased a set of beat calipers and e-brake cables on ebay for $60 and then sprung for the Centric reman calipers. They have a $75 each core but are $55 each after core return.
One caliper came fully loaded but the other was missing the vibration damper and was deformed by the piston seal so I'm exchanging it. They aren't listed as including the damper so I may have just gotten lucky.
