06-28-2011, 04:38 PM | #301 |
Re: 68 pro touring, auto cross c10 (mid life crisis)
I was going to have one made from billet & coated. Just as expensive I would imagine
06-28-2011, 04:43 PM | #302 |
he can use the mold again, but! the trick is making the framework the same to fit the mold. he would not give me a break on multiples, i tried. i was going to run a few to soften the blow from mine.
my build threads, 68 pro touring, auto cross c10 (mid life crisis) http://67-72chevytrucks.com/vboard/s...d.php?t=464109 website http://www.sauersgarage.com/ |
06-28-2011, 05:31 PM | #303 | |
Still plays with trucks
I rolled some 1" round rod 6061 into the diameter I wanted then milled the finger grooves into it. Welded the spokes to the rim then chucked it up and turned it down to clean it up. A short trip into the debur shaker to soften the edges and it was ready to go. It was kind of slippery so we ended up making another one that I knurled the round rod before fabrication.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-28-2011, 05:33 PM | #304 | |
Ask him if you can have the mold since you paid for its development.
06-28-2011, 05:35 PM | #305 |
that would have been awesome to get atleast a limited run. but now your's is even more unique.
06-28-2011, 08:18 PM | #306 |
all i need as a stock wheel to cut down. i made a fixture in case he would work with me but no luck.
06-28-2011, 08:57 PM | #307 |
VA72C10
That's a pain and seems like pretty poor business if he now has a mold and won't give you a break on it???
Looking for a 67-72 swb or blazer project in or around VA. |
06-28-2011, 08:58 PM | #308 | |
http://www.smooth-on.com/Castable-Ep...295/index.html Pretty inexpensive if you have the time to do the grunt work yourself. I am going to make some stuff that isn't available this way.
06-29-2011, 10:42 AM | #309 |
I'd be in on a billet style vintage steering wheel like that, is anyone doing any style of vintage wheel in billet, for our trucks?
Jon
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 |
07-06-2011, 08:34 PM | #310 |
radios showed up, things are moving slower buying parts fro two rig at the same time. am/fm/ipod front/rear pre amp outs!
07-06-2011, 08:51 PM | #311 |
Nice radio! By the time I'm ready to order mine an Ipod will be a thing of the past :-)
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see." - Thomas Jefferson 72 C10 SWB "Work in Progress" |
07-06-2011, 09:03 PM | #312 |
i know that drill! when i was a kid i would get a set of tires and wheels and they would be outdated before i got close to finishing it.
07-07-2011, 04:18 AM | #313 |
You are an amazing metal worker.
What a sweet build thread!
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
07-07-2011, 04:38 AM | #314 |
is the AM/FM still work and plays ipod ?
72 chevrolet 4wd 350/350 swb fleet green mean army machine |
07-07-2011, 12:19 PM | #315 |
auto crosser doesn't need a radio; just the sound of wumpf, brake, screech, wumpf, brake, screech.
07-07-2011, 12:41 PM | #316 |
you gotta get there! its not a trailer queen.
07-07-2011, 01:04 PM | #317 |
i'm just messin'. love all the modded OE parts (dash cluster, radio).
07-07-2011, 01:14 PM | #318 |
i know! just givin it back. i dont know how to make a cage look oe yet?
07-07-2011, 01:16 PM | #319 |
the radio is awesome, truck i socming along any progress on the steering wheel?
07-07-2011, 01:18 PM | #320 |
Do you have a build thread on the other project? I don't remember seeing one.
07-07-2011, 02:14 PM | #321 |
thanks, should be here next week.
07-07-2011, 02:15 PM | #322 |
in the suburban thread "the soccer mom"
07-07-2011, 02:19 PM | #323 |
07-08-2011, 12:39 PM | #324 |
Found it, thanks.
http://67-72chevytrucks.com/vboard/s...ght=soccer+mom Thinking heavily about building an LSx swap 67-72 Suburban to replace our Tahoe.
07-08-2011, 01:09 PM | #325 |
I've been thinking about that for my imaginary track truck build. How about a halo hoop pushed all the way to the roof with A-pillar bars following the windshield frame, thru the dash, and attaching to the floor and firewall, and the B-pillar bars following the curve of the back window wall to the floor. You could also attach a harness bar just lower than the top of the seat(s). In keeping with your OE look, you could run a bench seat, maybe scoop-out the foam a bit more for comfort and bum control, and run harnesses that could hide behind the bench when you are not racing and just use the lap belt portion, but then when you take to the track, flip 'em over, strap yourself in until you can barely breath, tighten some more, and let 'er rip. You could even put OE fabric over the halo hoop for a headliner. And you could hide a dash bar behind the dash too.
