Old 05-06-2011, 08:01 PM   #301
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Pic 1 Old tar removed, ready to blast and prime.
Pic 2 Drivers side fender, on work horse.
Pic 3 Pass fender had a bow along the edge.
Pic 4 Doesn't look bad in pic, but it was, had to cut some reliefs and weld it back.
oldman3 is offline   Reply With Quote
Old 05-06-2011, 08:03 PM   #302
oldman3
oldman3's Avatar
Pic 1 Inside of fenders in encapsulator paint.
Pic 2 Another view.
Old 05-06-2011, 08:04 PM   #303
oldman3
oldman3's Avatar
Another poor use of bondo, this was on the pass. fender and was a least 1/2" thick.
Old 05-06-2011, 08:06 PM   #304
oldman3
oldman3's Avatar
They had bondo starting at the top and going all the way to the bottom, at various thickness.
Old 05-06-2011, 08:09 PM   #305
oldman3
oldman3's Avatar
Pic 1 This is one of their reasons for bondo, fender was pushed way in at the bottom.
Pic 2 I made a couple of relief cuts, straightened and welded back together.
Old 05-06-2011, 08:11 PM   #306
oldman3
oldman3's Avatar
Pic 1 A few days later all repairs made, body work done and in primer.
Pic 2 Also primered the inside of front fenders, over the encapsulator paint.
Old 05-06-2011, 08:12 PM   #307
oldman3
oldman3's Avatar
The inner fender panels are next.
Old 05-06-2011, 08:15 PM   #308
oldman3
oldman3's Avatar
Here I have welded in partial exhaust tubes to form pockets. Pockets are to make it easy to get to alignment bolts for front end. Will also weld in piece to cover old hole for steering.
Old 05-06-2011, 08:17 PM   #309
oldman3
oldman3's Avatar
Not a good pic, but you get the ideal.
Old 05-06-2011, 08:19 PM   #310
oldman3
oldman3's Avatar
Pic 1 As before a few days later, all work done and in primer, back side
Pic 2 Front side.
Old 05-06-2011, 08:24 PM   #311
oldman3
oldman3's Avatar
Good place to stop for today, tomorrow, some more primer and maybe a little color
Old 05-07-2011, 01:53 PM   #312
oldman3
oldman3's Avatar
Posting early today, got plans for tonight.
Pic 1 Misc. parts in epoxy primer.
Pic 2 Console cover in epody primer.
Pic 3 More primered stuff.
Old 05-07-2011, 01:55 PM   #313
oldman3
oldman3's Avatar
Inside of front fender. I put 3 coats of bed liner on all 4 fenders, this is to help from getting stars in the paint from rocks, etc. It works great.
Old 05-07-2011, 01:58 PM   #314
oldman3
oldman3's Avatar
Pic 1 Grill frame in paint.
Pic 2 Most of the grill bars painted and installed, one to go.
Old 05-07-2011, 02:02 PM   #315
oldman3
oldman3's Avatar
Don't it look pruuuuudy. Paint is by PPG, single stage urethane, called Theatrical Teal.
Old 05-07-2011, 02:05 PM   #316
oldman3
oldman3's Avatar
Pic 1 Front fenders all painted (both sides).
Pic 2 Here is one rear fender with paint. With the bed liner it makes it look like they are fiberglass, but their all steel. You can also see part of filler tube for gas.
Old 05-07-2011, 02:09 PM   #317
oldman3
oldman3's Avatar
The following are pics of things that got painted.
Pic 1 Outside of rear fenders
Pic 2 Inner fender panels.
Pic 3 Running boards, hood stuff.
Pic 4 Bottom grill piece
Pic 5 Misc. items.
Old 05-07-2011, 02:12 PM   #318
oldman3
oldman3's Avatar
pic 1 Hood all painted.
Pic 2 Inside of bed.
Pic 3 Another view.
Old 05-07-2011, 02:15 PM   #319
oldman3
oldman3's Avatar
Pic 1 About 8 days of work here. 4 coats of urethane wood sealant on top and bottom of boards, drying between coats and light sanding.
Pic 2 Bed strips all painted.
Old 05-07-2011, 02:17 PM   #320
oldman3
oldman3's Avatar
Well, that's it for todays post. Hope to be back tomorrow, after Mother's Day doings. Happy Mother's Day to all your wifes. Jim
Old 05-07-2011, 02:20 PM   #321
Newtz67
Newtz67's Avatar
Looking good! Gotta love new paint
Newtz67 is offline   Reply With Quote
Old 05-07-2011, 02:33 PM   #322
oldman3
oldman3's Avatar
Don't know what I did wrong but pics of bed painted completely didn't show. So here they are
Old 05-07-2011, 02:38 PM   #323
oldman3
oldman3's Avatar
Thanks, paint makes everything look good.
Old 05-08-2011, 09:23 PM   #324
oldman3
oldman3's Avatar
Sorry so late, just got free. Back to the cab body. You can see all the rust between the upper and lower parts of cab. To keep this from coming back, I will spot blast a spot about 5" long between the body pieces. Weld it solid, then grind a line back in to match were the two pieces were attached. This took awhile, but I still have the body line and don't have to worry about rust.
Old 05-08-2011, 09:26 PM   #325
oldman3
oldman3's Avatar
Pic 1 Don't have a close up of repair, but you can see there is still a line. Here I have stripped the old paint, etc. Added some filler on the top piece.
Pic 2 Another view, still need to do filler work on the corner patch panels.
