Old 08-04-2014, 10:45 AM   #301
99 to Life
99 to Life's Avatar
Re: 1954 3100 C4 Tube Chassis Build
looks real good, engine mounts are a good idea, nice to think a head. I often make stuff a bolt on application just for that "incase" factor. For instance my running board brackets, I welded some tubing to the frame that the brackets bolt to, so they aren't in your way all the time on the rolling chassis. Maybe something to think about for yours.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-10-2014, 10:36 AM   #302
skymangs
skymangs's Avatar
Looking killer Josh.
skymangs is offline   Reply With Quote
Old 08-10-2014, 03:30 PM   #303
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Thanks guys, made some progress on the cab today. Got the inner and outer cowl panels and firewall cut out and fit all new stuff. Big props to Dynacorn for the best fitting patch panels Ive ever seen. Here are some pics, more to come once its all welded up.
--Josh
Old 08-10-2014, 03:31 PM   #304
STOCKISH
STOCKISH's Avatar
O yeah, dont be hatin' on my home made cave man like press brake!
--Josh
Old 08-10-2014, 04:22 PM   #305
Billys68SS
Billys68SS's Avatar
Originally Posted by stockish View Post
o yeah, dont be hatin' on my home made cave man like press brake!
lol
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120
1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806
1966 C10 SB Custom Cab, Fleetside, BBW.
1968 Chevelle SS 396
1937 Chevrolet Coupe
Billys68SS is offline   Reply With Quote
Old 08-10-2014, 07:16 PM   #306
Advanced Design
Advanced Design's Avatar
Nice! The press brake looks like it is doing the job.
Advanced Design is offline   Reply With Quote
Old 08-11-2014, 04:38 PM   #307
68 Four on the Floor
68 Four on the Floor's Avatar
This build is a BAMF! Seriously considering this as an option now for my 53.
68 Four on the Floor is offline   Reply With Quote
Old 08-20-2014, 12:36 PM   #308
STOCKISH
STOCKISH's Avatar
Sorry Ive been so slack lately. I have however made some small progress. I cut out all the fishplates I needed to strengthen the joints in my chassis over the axle. Also ordered my rear coilovers from Flat Out. Now I need to decide how to mount them. I thought Id seen guys putting them on the factory Corvette shock stud on the spindle but not sure about that. Anyone whose done the Vette rear have any opinions on this? Thanks guys. Hopefully some progress pics soon.
--Josh
Old 08-20-2014, 01:31 PM   #309
mcbassin
Still Learning
mcbassin's Avatar
Very nice work on the cab Josh. Looking good.
mcbassin is offline   Reply With Quote
Old 08-20-2014, 06:10 PM   #310
STOCKISH
STOCKISH's Avatar
Thanks Mike!
--Josh
Old 08-21-2014, 12:20 PM   #311
BIGglaSS
BIGglaSS's Avatar
I have not done it yet, but been doing a lot of research. I noticed that they are mounted to a bracket that spans between the shock bolt and upper dog bone. Look closely at the pic on flat out's website.
BIGglaSS is offline   Reply With Quote
Old 08-21-2014, 03:20 PM   #312
STOCKISH
STOCKISH's Avatar
I've seen that bracket as well. There is also a small bracket available that mounts only to the spindle where the shock stud mounted. I'd think with no more weight on the rear of a truck than there is it'd be ok? Seems to be a popular option on a lot of the road course web sites I've seen.
--Josh
Old 08-21-2014, 11:14 PM   #313
skymangs
skymangs's Avatar
Looking great man. Looks like I'll be doing a vette suspension under one of these this winter. I'll be referencing your thread for sure!
Old 08-22-2014, 10:52 AM   #314
BIGglaSS
BIGglaSS's Avatar
I'm sure the transverse mono spring mount would be more than adequate, since the factory designed it to carry the weight. I haven't looked at it close enough yet to figure out a way to make it work. I'm undecided on coils or bags.
Old 08-22-2014, 04:56 PM   #315
STOCKISH
STOCKISH's Avatar
I'm sure the mono spring would be ok, but won't let me adjust as much as I want. I'm definitely using the coil overs.
--Josh
Old 08-22-2014, 10:16 PM   #316
BIGglaSS
BIGglaSS's Avatar
I'm definitely ditching the monospring, too. What I meant was to fabricate a bracket that attaches to the knuckle where the monospring attaches vs. using the shock mount. I haven't looked at it close enough to see if there is clearance behind the half shaft.
Old 08-23-2014, 04:28 PM   #317
STOCKISH
STOCKISH's Avatar
That point is waaaay too high though. I'll get back on it next week sometime.
--Josh
Old 08-26-2014, 03:22 PM   #318
ccreddell
ccreddell's Avatar
Im planning on putting a C4 IRS in my 95 C1500. Im going to fab a cantilever behind the suspension somewhat like a KP 6-link and attach at the stock spring mount. I'll most likely use an airbag too, but its not necessary.
ccreddell is offline   Reply With Quote
Old 08-27-2014, 03:41 PM   #319
BIGglaSS
BIGglaSS's Avatar
Stockish, I see what you mean about the spring mount being too high. I found this closeup pic on the net:
http://www.customclassictrucks.com/t.../photo_28.html
ccreddell, I'd love to see how you do this. LFD's Tahoe build did a bag behind the axle, but it's not cantilever.
Old 08-27-2014, 10:23 PM   #320
STOCKISH
STOCKISH's Avatar
Just out of curiosity, why a cantilever setup? That is designed to keep the axle centered under the truck during suspension travel. You dont have that issue with an IRS setup so it seems like a lot of extra work. Youll still need to solid mount the batwing and trailing arms so Im not sure what the cantilever would even do except just sit there, look cool, but have zero function.
--Josh
Old 08-28-2014, 03:05 PM   #321
ccreddell
ccreddell's Avatar
No, not the locating links, or Panhard bar. The links parallel with the frame that holds the truck up.
Heres what they look like on a truck.
[IMG][/IMG]
You could put a coil over there in place of the bag. Or you could put a coil spring in there and run the shock in the stock location.
Old 08-28-2014, 10:58 PM   #322
STOCKISH
STOCKISH's Avatar
I dont understand how thats supposed to work with a C4 IRS though.
--Josh
Old 08-29-2014, 05:48 PM   #323
ccreddell
ccreddell's Avatar
Im not sure what to tell you. Either youre not familiar with the C4 IRS, or Im not being clear enough. Maybe this pic will help....
[IMG][/IMG]
Here it is hooked up.
[IMG][/IMG]
And here it is from the top.
[IMG][/IMG]
Old 08-29-2014, 09:48 PM   #324
99 to Life
99 to Life's Avatar
at first as I look at that setup, I wonder, how conflicting it might be. But.... there are guys running it. http://www.s10forum.com/forum/f125/i...n-here-429547/
I didn't even look too far into it, if your not bagging it, I think its overkill.
Old 08-30-2014, 02:36 AM   #325
Nut Case
Nut Case's Avatar
I'm still in the planning stages of a 57 GMC with 1996 C-4 both front and rear suspension. I'm calculating how much to remove form the vette fiberglass leaf so I can use a shockwave shock.. I figure use the original design, adjust the mounting points for the shockwave and have the leaf carry about 60-70% of the weight and have the adjustibility from the air system, you know adjust on the fly and all. Just thought I'd through more gas on the fire..
Been there, wrecked that
Nut Case is offline   Reply With Quote
