05-22-2016, 12:05 AM | #301 |
SAVING ONE TRUCK AT A TIME
Re: 1961 Crew Max
Some progress. Unbolted the rear frame rails and started over. They were pretty beat up and bent. Used 4x3 3/16" and welded to the notches. We then fit the fuel tank at the back and kept some room in the front to mount two 5 gallon air tanks. Also using the viair compressor mounts 0ne on each side. The boss got the bed blasted and we did some mock up with it and overall not bad. The drivers side tail light panel will need to be replaced and maybe the rear stake pocket. Some minor patching and some hammer and dolly and it should be pretty good. Next will be making a new inner bed structure to support the raised floor. Thanks CHIZZLER
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
05-22-2016, 12:10 AM | #302 |
Re: 1961 Crew Max
Couple more.
05-22-2016, 02:48 AM | #303 |
Re: 1961 Crew Max
[QUOTE=CHIZZLER;7600844]Couple more.[/QUOTE
The truck Is totally cool.Get excited to see more updates each time.
The Snortin' Bull |
05-22-2016, 03:12 AM | #304 |
Re: 1961 Crew Max
Dude, that thing is so killer!
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
05-22-2016, 07:45 AM | #305 |
Re: 1961 Crew Max
Great work. The truck is really coming together!
05-22-2016, 09:21 AM | #306 |
Re: 1961 Crew Max
Looking great .
05-22-2016, 10:20 AM | #307 |
Re: 1961 Crew Max
Nice work and packaging. Are the tanks 5 gallon tanks?
05-22-2016, 11:08 AM | #308 |
Re: 1961 Crew Max
Yes doug 5 gallon tanks. They are 33x7 without the mounting bracket.
05-23-2016, 08:38 PM | #309 |
6>8 Plugless........
Re: 1961 Crew Max
That looks sweet! I really like your tank and nice choice to redo that rear frame. It looks so much nicer and will be way stronger too.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-23-2016, 09:21 PM | #310 |
Re: 1961 Crew Max
Thanks Chizzler, I am having second thoughts on my 5 gallon capacity.
05-24-2016, 08:17 AM | #311 |
Re: 1961 Crew Max
That looks great having the box back on. Are the air tanks going to be showing when the bed gets put in?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
05-24-2016, 11:00 AM | #312 |
Re: 1961 Crew Max
Nothing will be showing. The bed floor will be raised just over the notches.
05-24-2016, 11:17 AM | #313 |
Re: 1961 Crew Max
Impressive tanks and compressor!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
05-30-2016, 11:31 PM | #314 |
Re: 1961 Crew Max
More progress on the bed. Started building the raised bed with original crossmembers. Also used a rear bed crossmember and welded it at the end by the tailgate so the wood will sit like factory. Next we will cut the rear wheel tubs down and shorten them. Got another hood and pre fit it. Overall not bad. Thanks chizzler.
05-30-2016, 11:44 PM | #315 |
Re: 1961 Crew Max
On a sad note. Got the 40 fired up and had a major fuel leak from one of the three carb's and had a engine fire. Figured it was easier to pull the motor/trans to fix wiring and clean everything. Luckily I was able to get the fire out fairly quick and it didn't do any major damage to anything else. You can see how hot it got by the smoke ring on the wheel and the tranny seal let go. The trans had been making a weird noise so it's a good time to have it looked at. Chizzler
05-30-2016, 11:45 PM | #316 |
1961 crewcab
Re: 1961 Crew Max
crew is lookin' good! I am secretly working on mine as well...
too bad about the 40.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-31-2016, 11:00 AM | #317 |
Re: 1961 Crew Max
That Crew is looking Badass and you will have the 40 back in no time.
05-31-2016, 11:08 AM | #318 |
Re: 1961 Crew Max
Nice work on the Crew, sorry about the fire
05-31-2016, 12:50 PM | #319 |
Re: 1961 Crew Max
Wow, glad you saved it! I had one once due to a stupid move on my part and it scared the crap out of me...gonna lose the truck and the shop I thought. Got it put out quickly though.
And crew is looking awesome! |
05-31-2016, 11:14 PM | #320 |
Re: 1961 Crew Max
Nice work on the crew and sorry to hear about the 40. Good thing you got it put out though!
06-01-2016, 01:59 AM | #321 |
Re: 1961 Crew Max
Your crew is looking bad ass!! Glad there was not much damage on your 40.
06-04-2016, 01:56 AM | #322 |
Re: 1961 Crew Max
Man you are a hustler.Sorry see the thermal event (FIRE) .Though in the end little problem's will be resolved.
The Snortin' Bull |
06-23-2016, 10:56 PM | #323 |
Re: 1961 Crew Max
need to see some progress pics on the crew! Thing is bad @ss
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
06-23-2016, 11:25 PM | #324 |
Re: 1961 Crew Max
Couple update pics. Progress is a little slower as the weather gets better. Got this amazing dipped hood off CL for $300. ZEROOOO rust. Also started playing with rear wheel tubs. More to come soon. CHIZZLER
06-24-2016, 10:55 PM | #325 |
Re: 1961 Crew Max
Man oh man Chizzler are you killing it on this crew cab. I have not been following this one as close as I should have.
Nice work... Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
