Old 07-03-2017, 12:52 AM   #301
59chevy310p
Re: What did you do with your truck today, Part 3
Got a itch today and turned to my wide thats 7 months pregnant and said I want to finish the motor and put it in the frame. So this is what we ended up with what a pain did it all on the gravel. But it didn't turn out too bad. Next step wiring and mount all the brakes lines again and driveline.
59chevy310p is offline   Reply With Quote
Old 07-03-2017, 12:58 AM   #302
la hi
Good luck getting the headers past the steering box. This would be a great time for an IFS install.
la hi is offline   Reply With Quote
Old 07-03-2017, 01:04 AM   #303
59chevy310p
Bought block huggers fits real nice. Use to have a 350 in it before I did the swap fit really nice and didn't hit the steering had about an inch of room. My only issue is the booster and master that are on the frame but mocked the exhaust around it
Old 07-03-2017, 06:25 PM   #304
Black_Sheep
Black_Sheep's Avatar
Finished up installing a new master cylinder and plumbing the hard lines...
Black_Sheep is offline   Reply With Quote
Old 07-04-2017, 06:31 PM   #305
mongocanfly
Post Whore
mongocanfly's Avatar
59 chevy...better not let your 7 month pregnant wife see this....haha..
"Got a itch today and turned to my wide thats 7 months pregnant".
"wide"???
Old 07-05-2017, 12:31 AM   #306
evilokc
dude that looks great.
evilokc is offline   Reply With Quote
Old 07-05-2017, 12:32 AM   #307
evilokc
is that a 5.3? looks good.
Old 07-05-2017, 12:35 AM   #308
59chevy310p
Yup it's a 5.3 took some time building it and painting it all up
Old 07-05-2017, 10:07 AM   #309
Black_Sheep
Welded up some holes in the firewall and the holes from the sunvisor screws.
Old 07-05-2017, 10:45 AM   #310
evilokc
did you do a general freshening or did you do upgrades?
Old 07-06-2017, 12:55 AM   #311
59chevy310p
I did some small up grades like different cam to make it so I can run turbos eventually had the heads gone through and arp everything so she will do alright. I wish I had people around me who knew how to do a independent front end swap I already have the front clip just not that smart in that area to do that. But it will do for now just thankful that the wife loves me having these trucks around.
Old 07-06-2017, 06:27 AM   #312
evilokc
my stock frame has a clip grafted on and honestly these days I think that's a silly way to go. they sell some really great front cross member sets with top of the line suspension for not much more than a subframe would cost. with a subframe there are a lot of things left to chance. when I went to start fitting sheet metal nothing fit. the front of the frame was in the way. I had to rebuild all the front suspension and guess what I have now? brand new 1979 suspension. if I had used a cross member I would have a frame that my sheet metal would love and the suspension and brakes would be far superior to what I have now. I will never sub frame again. its just too cheap and easy to do the cross member these days and get awesome results.
Old 07-06-2017, 04:05 PM   #313
Russell Ashley
Russell Ashley's Avatar
My son sent me this pic of my truck getting the BBW conversion. It's on for a trial fit here but he says he will complete it tomorrow.
Russell Ashley is offline   Reply With Quote
Old 07-08-2017, 01:29 AM   #314
Black_Sheep
I cut some panels out of 18 gauge steel and put them on with 3M panel bond instead of welding. After letting it cure for a day and taking off the clamps, I'm pretty happy with the result. The panels are smooth and flat so finish work should be minimal.
Old 07-08-2017, 04:21 AM   #315
dsraven
did you cut out the original parts or bond the new parts over the original panel?
Old 07-08-2017, 12:56 PM   #316
Black_Sheep
Bonded over the existing panels for maximum contact area.
Old 07-08-2017, 02:29 PM   #317
evilokc
was there damage you are trying to fix or is this a cosmetic thing?
Old 07-08-2017, 03:04 PM   #318
idbeast
Got the tailgate links installed...
idbeast is offline   Reply With Quote
Old 07-08-2017, 07:07 PM   #319
evilokc
received a couple of parts for the truck. I got the h.e.i. pigtail to replace the burnt wires and my new throttle pedal. its a lokar oval xl. looks nice. the truck has become a catch all storage over the last 10 months since it didn't move. now I need to clean out the bed.
Old 07-09-2017, 12:06 AM   #320
idbeast
... the truck has become a catch all storage over the last 10 months since it didn't move. now I need to clean out the bed.
ROFLMAO look at the above picture... I understand!!!
Old 07-09-2017, 01:05 AM   #321
evilokc
gave the motorcycle a little love today so the truck didn't get much of my time. I DID clean out the bed. I even climbed in and swept it. I work Sunday but a off Monday so I might get out there and solder on the pigtail.
Old 07-09-2017, 06:31 PM   #322
OrrieG
OrrieG's Avatar
Put in the back window. PITA.
OrrieG is offline   Reply With Quote
Old 07-09-2017, 07:23 PM   #323
Black_Sheep
Both
I wouldn't really call it damage, but the firewall had 28 assorted holes ranging in size from 1/4" to over an inch. None were needed anymore because the battery is relocated under the cab, the wiring is hidden, etc... Smoothing the firewall was an easy way to lose the holes and save hours of finish work vs. plugging and welding everything. Plus, I like the look...
Old 07-10-2017, 06:06 PM   #324
evilokc
[QUOTE=Black_Sheep;7987152]Both
I wouldn't really call it damage, but the firewall had 28 assorted holes ranging in size from 1/4" to over an inch. None were needed anymore because the battery is relocated under the cab, the wiring is hidden, etc... Smoothing the firewall was an easy way to lose the holes and save hours of finish work vs. plugging and welding everything. Plus, I like the look...[/QUOT
are you worried about rust? I'm not familiar with the bonding agent you used so when I saw that you didn't cut and weld my mind immediately went to future hidden rust. is the bonding agent a metal?
Old 07-10-2017, 09:23 PM   #325
handyhands
Welding inner and outer lower , door skin s10/Ad. Trying to figure out mounting radiator.
handyhands is offline   Reply With Quote
