Old 09-29-2019, 03:33 PM   #301
FAKKY
Re: 57 Panel "FAKMLC" build
Well getting a few things done.
Did what jodoe/drsraven said and pulled the column back, got rig of the double joint at the column which was creating a bunch of issues and ended up here with straight rod, 1 single support bearing and all angles at between 30-36 degree's. No binding.
USed those measurements as well as this website to determine final angles
https://www.ginifab.com/feeds/angle_measurement/
Mocked out my PS lines ........ with my chicken strathc
And then as e015475 suggested ...... I replaced all fittings with JIC/6AN [16/18mm x 1.5mm] .... and ordered hydraulic hose from discounthydraulic hose which all came in like 3 days delivered to hose. Super quick.
Got the Radiator in with a little bit of trimming.
Now need to wrok on fan and shroud ....... them get it plumbed with the transmission cooler lines as well as coolant.
Getting closer to first start at least. Oh yeah fixed and finished bulk of my ls wiring ... obviouusly still a lot more to do ther ewith teh chassis wiring and connecting it all up properly to starter/battery and lights/gaauges etc.
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 09-29-2019, 05:15 PM   #302
joedoh
joedoh's Avatar
woop woop! nice work!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-29-2019, 05:47 PM   #303
FAKKY
lol - right now I feel like its a few of you guys on here building my truck - not me ..... but I'll take it in order to get to the finish line.
Old 09-30-2019, 12:04 PM   #304
joedoh
joedoh's Avatar
its easier to edit than it is to create, you are creating!
Old 10-05-2019, 12:43 PM   #305
FAKKY
So this is my final fan clearance. Its tight - but I think its ok - thoughts ?
A "little" anxious if there is going to be enough fan also ....... was a cheap ebay special I got cheaper in a package deal with shroud.
Basically one of these.
https://www.ebay.com/itm/ALUMINUM-RA...AAAOSw6WJdk7ib
Old 10-05-2019, 02:26 PM   #306
dsraven
I guess the other thing you could do is try a double fan unit so the motors would be offset from the centre, maybe give more room since the motors and the water pump wouldn't need to share the space. you would want to check clearance with engine torquing up as well.
Old 10-06-2019, 02:16 PM   #307
FAKKY
So as long as I cycle the suspenion -- and it doesnt have any interference - should be good ?
Think im going to need to get a straight water thermostat housing.....
https://www.summitracing.com/parts/spe-4932/overview/
Tried about 3 hoses I thought might work from auto parts store .... even with cutting its only a 50/50 chance.
Old 10-06-2019, 06:58 PM   #308
dsraven
you could always use some bent up aluminized muffler tubing and use rubber/silicone hose at the ends where the connections are. otherwise cut the housing and turn the outlet/inlet and have it welded back on and leak tested.
Old 10-06-2019, 08:04 PM   #309
FAKKY
Looked at cutting the housing like you said .... couldnt see a good way to get a clean cut with a 4.5" saw or a plasma cutter ..... so went with this.
https://www.ebay.com/itm/Fits-Chevy-...72.m2749.l2649
Finished off my main fuel line and also my transmission lines all in 6AN ptfe.
Bought the adapters (6an/ntps on transmisison side and 6 an 1/2-20 on transmisison cooler side).
Fuel neck filler also.
So once that all arrives ...... get it all plumbed in and thasts basically the plumbing done. Might be getting closer to to a hotwire start.
Probably going to buy one of these over the vintage air. They are local.
https://www.ebay.com/itm/A-C-KIT-UNI...kAAOSwCWRcBv23
I already have the compressor too. So should be a good price. Not sure about those hoses with ferrule fittings - but they say they work.
"This kit includes a complete FITTING SET
With FERRULES and CLAMPS
(We include both systems No special tools require DIY)
Clamps (made in the USA) Support 300Psi (Tested)
Old 10-06-2019, 08:13 PM   #310
FAKKY
Got those innner fendor mounts cut up to spec per your post dsraven .... they look good ..... so thats awesome. I really cant say enough about this product ....
https://www.jegs.com/i/JEGS+Performa...caAraSEALw_wcB
Obviously limited to slightly thinner material .... but for most of what I need ... awesome.
Those grommets are WAY expensive. Wonder if I can use/find some thick rubber somewhere. $15.
https://www.ebay.com/i/312050055902?...oaAp8sEALw_wcB
Old 10-06-2019, 09:45 PM   #311
joedoh
joedoh's Avatar
put the serpentine belt on before you get excited about a hose that fits! experience talking here.
Old 10-06-2019, 10:15 PM   #312
FAKKY
Hey joedog
You mean for lower hose >? Yes --- good point I need to order that .... pic looks like there should be ok clearance ....
https://www.ictbillet.com/catalog/pr.../category/163/
Old 10-07-2019, 03:31 PM   #313
dug224
dug224's Avatar
The back of my radiator cooling fan ended up about as close to the engine as yours. No problems so far. I'm running a late model corvette radiator sized for a 6.0 liter engine with no shroud and one electric fan similar to yours. Also added the condenser with two pusher fans and the engine stays right a 210 degree F on a hot day with the AC running.
dug224 is offline   Reply With Quote
Old 10-07-2019, 07:23 PM   #314
joedoh
joedoh's Avatar
Hey joedog
yes that should be fine, I am used to the belt going outboard there on the tensioner, not inboard like that one.
Old 10-09-2019, 07:54 PM   #315
FAKKY
Awesome.
I debated on Vintage Air and deciced to go local (because they are local) and cheaper.
Supposedly this gives 22000 BTU versus the Vintage Air Gen14 (18000) or Heritage heat/coool (12000). Obiously Im sure the numbers are all over the place for everyone.
http://coldmasterinc.com/product/ac-...no-compressor/
Old 10-09-2019, 07:56 PM   #316
FAKKY
Thx for keeping me in check and thinking of things I would typically just not think about.
Bought htis thermostat housing (swivel) at 45 deg.
Old 10-12-2019, 10:17 AM   #317
FAKKY
So thermostat from ebay is great - except the housing is about 2mm too small which means I cant get the OEM gasket/thermostat in ... its too tight.
So options
1) I did manage to cut the original thermostat housing to a point I think I can tig weld it.
Wish I had tried to begin with - but didnt think a grinder cutting wheel would have enough depth and I dont own a bandsaw. There was just enough depth to get it done.
2) Clock and mark the ebay swivel housing where I want it ..... then weld it so no leaks through the housing. Then use a small rubber gasket and gasket sealer to seal the thermostat inside ?
Thoughts ?
OEM housing cut and rotated
Old 10-12-2019, 02:27 PM   #318
FAKKY
AC blower in ..... kinda sucky job with that rear bracket and this was a bit bigger than I thought .... but going to swing with it.
Old 10-13-2019, 11:47 AM   #319
FAKKY
So was looking over this thread on the condensor setups ....
http://67-72chevytrucks.com/vboard/s...d.php?t=655540
Im going to be having a small pusher fan on front of condenser. I think I will need to pull out the core crossover support bits in order to fit all that ..... anyone see any issues ?
How much room is there for clearance until you hit something like the bumper or front grill etc Im guessing quite a bit ?
Old 10-13-2019, 02:12 PM   #320
FAKKY
Knocked that out ....... but put a big dent in radiator at same time when hammer slipped ... always something where I dont pay atttention.
Not 100% sure how to test for leak without a lot of air and a bunch of plugs .... probably cross fingers ...... and let her get up to temp before i put on any sheet meal front end.
Old 10-13-2019, 04:16 PM   #321
FAKKY
Not sure on pedal height - think its like ~2" too high ..... is there a way to get a measurement to set properly or just by what feels good for you.
So both will probably have to be modified.
Old 10-13-2019, 04:19 PM   #322
FAKKY
Part of problem with the brake pedal is the hydrobbost push rod. Its really not perfectly straight and just a biit too long.
I think most guys just cut and shorten and reweld ...... I have an adustable head if I can thread the rod ....... not sure I really want to pull it and try and get it back in clean ...
plus if the threading on rod goes sideways
https://www.dieseltruckresource.com/...thread-323472/
Old 10-13-2019, 06:09 PM   #323
FAKKY
Clocked and tig welded the thermostat housing.
Was such a crap job with my welding .... even after cleanup .... not sure if I feel good about using it.
Kind of blew into the seal area there.
Definitely a day of 1 step forward two steps back .......
Old 10-14-2019, 07:29 PM   #324
FAKKY
Ac condenser fabbed up for cross member fitment.
pusher fan.
Old 10-14-2019, 07:33 PM   #325
FAKKY
The #6 and #8 Ac lines for condensor are tight around crossmember .... thinking I might have to go with
https://www.summitracing.com/search/...rigerant-lines
Who knows of a good reasoably priced 5/8 tube bender ?
or
A long 45 degrees beadlock fitting
This will be too short
http://shorturl.at/jlrzK
