Old 08-21-2019, 06:28 PM   #301
CarlsLQ9SS
CarlsLQ9SS's Avatar
Re: TA_C10: Stage 1
Just read a few pages, looking good. Your welding looks really good to me.
CarlsLQ9SS is offline   Reply With Quote
Old 08-23-2019, 10:48 PM   #302
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Originally Posted by 1971Stepside View Post
I think I should have ran mine to the frame rail like that instead of all the way up front under the radiator. I thought it needed some air movement. Would have saved me a lot in braided hose.
From what I have read there is plenty of air on the side rails. We will see. And yours being up front should just be more of assurance its gonna work
Thanks man, took me a while to get used to it but I get more and more confident the more I weld.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 08-23-2019, 10:59 PM   #303
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Originally Posted by nlped View Post
Just an observation, but if that’s a truck pan and you’re lowered, that pan may be in jeopardy as it’ll be lower than the front crossmember.
Ok Update. And this one cost me more money... nlped thank you for keeping me up at night..... So I thought I was fine, no, I was not fine. The pan stuck like 1.5" below the x-member when I ran out in the garage to check. How did I ever think it was level???.... ugh.
So I ordered a Cadillac CTS-V oil pan. Bolts right up to my engine and gives me more clearance. Had to modify the windage tray to make it fit but no big deal. Painted it of coarse. Installed the oil filter assembly. Now I have a ton of clearance.
"It's only money".
Old 08-23-2019, 11:06 PM   #304
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Filled the new torque converter with fluid, installed it. Got the engine and tranny back in the frame along with headers and exhaust. Also installed the new trans filler tube. Going to have to modify the bracket as it's not right. Setup to hit an empty hole. So I will probably cut off the bracket and move it on the tube so it lines up with a proper bolt hole. Ready to finish exhaust now. And after painting and re-wrapping the coil pack wires they look so much better.
"It's only money".
Old 08-24-2019, 05:11 PM   #305
nlped
nlped's Avatar
Re: TA_C10: Stage 1
You ARE welcome.
As usual, every thing is looking really good!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-25-2019, 12:54 AM   #306
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
You ARE welcome.
Thank you sir. All I can think of is either the new springs finally settled some so it dropped, or I just plain never noticed and just thought I did.... And I really doubt the springs settled a whole inch much less 1.5.....
My sleepless nights are over with that new pan. For now anyways.
Now let's see some Walt!
"It's only money".
Old 08-25-2019, 09:49 AM   #307
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: TA_C10: Stage 1
I experienced the same insomnia until I changed my oil pan. LOL
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 08-25-2019, 01:57 PM   #308
Chris50
Re: TA_C10: Stage 1
Amazing write up. The details and seeing your progress is what motivates people like me to keep going. Even though, I did loose most of my day reading everything since your first post...LOL. Time well spent though. I'm ready for the paint and the open road pics. Keep up the great work!
Chris50 is offline   Reply With Quote
Old 08-26-2019, 12:00 PM   #309
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Glad to know I'm not the only one
Thank you sir. It's difficult to keep motivated sometimes but sometimes just digging in and grinding away will bring the motivation itself. Seeing progress.
:chevy
"It's only money".
Old 08-26-2019, 12:03 PM   #310
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Mufflers welded in.
That pretty much says it for this post. It took me 5 hours just to weld in the vband ends, 45's, and mufflers. But progress is progress. I think it's gonna work . I think I'm going to start working on my H-Pipe next before I finish the tail pipe dumps.
"It's only money".
Old 08-27-2019, 03:45 PM   #311
cebra
Re: TA_C10: Stage 1
What wheels/tires are you planning to use?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 08-27-2019, 07:06 PM   #312
LagunaGlide
Re: TA_C10: Stage 1
Looking good. I am new here and will definitely be following along. You are doing a lot of the stuff I will need and want to do, but at an accelerated rate.
LagunaGlide is offline   Reply With Quote
Old 08-28-2019, 03:29 PM   #313
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I'm going to be using the wheels/tires that came with the truck when I bought it. If you look at my first page there are some pics. They are 275/65R15 I believe.
Thanks! Motivation is key on these builds or you will be on it for years IMHO. Oh, and the money thing too...
"It's only money".
Old 08-28-2019, 03:33 PM   #314
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Change of pace. While I wait on a few more parts I started on my passenger side front fender. Appears the PO attempted to repair rust with mud... The new piece didn't quite fit right so I had to make some slices on the back side and improvise on the edges(STRETCH!). More on this later.
Current progress:
"It's only money".
Old 08-29-2019, 09:22 AM   #315
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
I found a repair like that on my rockers - except they used some kind of mesh along with bondo to fill in the holes.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 08-29-2019, 10:44 AM   #316
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Yeah I don't know which PO did this, but geeze. The cab was so bad I don't expect anything less. These old trucks have gone through too many hands.
And just to comment on this repair. It's not easy like I thought it would be. That groove on the edge of the wheel well makes it really hard to grind down welds and keep that edge looking correct without thinning out the metal around the area. I keep having to fill the area up with weld and 'shape' it back. Whew. Hopefully I will finish it tonight... Sucks.
"It's only money".
Old 08-29-2019, 12:28 PM   #317
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
I try to leave as much original material as possible so the 'patch' panel can be trimmed to fit as necessary. Sometimes, you need to get 2 patch panels to make 1 the correct size/shape if it doesn't break the bank.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-01-2019, 01:11 AM   #318
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Yeah I'm learning that over time. This piece I made sure I cut above the cancer but below the style line. But that style in the wheel well couldn't be helped. Had to cut through it. That's good advice though Scoti.
"It's only money".
Old 09-01-2019, 01:19 AM   #319
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Passenger side fender
Finished the fender, patching and welding up all the little holes anyway. This thing had those large farm truck mirrors at some point. I ended up finding a lot of old patch work that needed fixing. Welded up a torn tab. Slapped a little paint on the welds until it goes to media blast.
I found a several of these little patches one of the PO's made as some point. They look to be a screw that is held on by a bracket on the back side of the sheet metal. Looks like the way they filled holes back in the day. The head of the screw was ground down to match and then mudded over. I got rid of 3-4 of them. Filled them with weld and moved on.
"It's only money".
Old 09-01-2019, 01:33 AM   #320
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - H-pipe Exhaust
Getting my H-pipe figured out. Never cut saddles before. I found it's easier than I thunk 😉 It's a little low right now, going to prob cut the 45° in half and draw it up to maybe 40° or so. It doesn't hang below the cross-members but there's plenty of room to draw it up.
I cut the saddles using a carpenter square. I marked a center first, then about a 1/8" away from center line I made my 35 degree marks and cut them. I don't have a band saw so this was done with a mix of large 6" cut off wheels and a sawzall.
The plan is that these 2 saddles will go on each side of the exhaust and I will use v-band clamps on their ends to join the center 45 degree section. This should allow easy removal in case of maintenance.
And these little guys I got from Summit. They are rubber isolators that should work real nice for securing the exhaust at the trailing arm x-member.
https://www.summitracing.com/parts/SUM-610332
"It's only money".
Old 09-01-2019, 11:25 AM   #321
siggyfreud
siggyfreud's Avatar
Re: TA_C10: Stage 1
Oh those isolators look nice! I'll have to incorporate them when I redo my exhaust!
The system is looking really nice!
siggyfreud is offline   Reply With Quote
Old 09-02-2019, 01:00 AM   #322
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks. I can't take credit for those isolators though. Both my H-Pipe and isolator ideas came from both @SCOTI and @gringoloco
"It's only money".
Old 09-02-2019, 01:07 AM   #323
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Trans dip stick mount
The trans dipstick and tube I bought were for a 2005 suburban off rockauto. The setup I have didn't work because the bracket utilized a blank in my bellhousing so I cut it off and relocated it up to a different hole in the passenger side head. Same bolt I'm using for all my engine harness grounds. Not much to it. I drilled out the spot welds. Moved the bracket up and welded it back on. I filled my drilled hole marks too and smoothed everthing out and shot it with VHT roll bar paint.
This first pic is the old location.
"It's only money".
Old 09-04-2019, 11:57 AM   #324
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Exhaust Hangers - Snappers
These little guys are really nice. Got them from Summit. Rubber isolators. I saw them in @gringoloco build. They worked perfect for my setup. However the hardware they send with them(button head bolt) wasn't the strongest. I was able to strip out the head(allen head) and then using channel locks I was able to twist the bolt in half pretty easily.
Now the reason I found all this out was because I decided to weld the nuts on the back side of my trailing arm x-member because after the 3" exhaust is installed, I won't be able to get a wrench or even a socket extension behind the plate I welded in/boxed in. No big deal, but I decided to try and weld in a nylon nyloc nut... I was hoping to weld it at the base and not melt the plastic but no deal, it friggin melted quick. Then of course I tried to run the bolt in it anyways to see if it would still work(at this point I didn't care about the locking function) and when I ran the bolt in, somehow a little sliver of metal made its way inside the melted plastic/nylon and got caught in the threads and my bolt was stuck. I ripped that sucker right in half without much effort. So I am probably going to get new bolts stage 5 should be plenty.
Here is the nut that melted. I ended up cutting that back off and welding a normal stage 5 nut on the back and they work great. I didn't take pictures of the final product.
And here they are installed. They work great. Let's hope they isolate well because this is a daily and I don't want vibrations and drone inside the cab. We will see.
Left side has button head allen bolt(came with hanger), right side is a stage 5 bolt I will probably end up using for both. And on the ground is the original button head bolt I twisted in half. You can see how short it is.
"It's only money".
Old 09-04-2019, 12:23 PM   #325
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
When boxing stuff in that requires hardware access, drilling some holes to pass wrenches through can help too.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
